I agree Team Gross! It’s one of those planes where you don’t want just one of. I want one or two military, a couple commercial, and an aftermarket turbo-prop!
What's next from Motion RC?
If the air force wants a SINGLE engine ground attack plane a turboprop has to be the worst engine choice possible. Put the P 47 or Corsair back in production.
they would be more survivable in ground fire than any turboprop. History is proof, this is why the A 10 is designed as it is. If they want go with turbine power
the A 10 is the logical choice....proven, not theory.Comment
Thanx Valk............am very familiar with that vidOriginally posted by ValkpilotHere's a little video for WBC and the other "Bronco Busters":
Here is the ultimate vid that should quiet any further naysayers about the :ov10 not being an actual warbird and push Alpha into announcing to us the first SuperScale foam OV-10 Bronco by Flight Line RC.
OV-10 in Perspective :Cool:Warbird Charlie
Has anybody "strapped" a GAU-8 onto a Bronco? And I bet you could pack a lot of lead in the utility bay.
OV-10 in Perspective :Cool:Comment
It's 2 tonsCurrently flying: Twin 80mm A-10, 80mm F5, 80mm A6, 70mm Yak-130, 70mm F-16v2,90mm Stinger 90, 70mmRC Lander F9F, Flightline F7F TigerCat, Phoenix 46 size Tucano, Flyzone L-39
I Want: 80mm A-4, twin 80mm F4J PhantomComment
In a way, the idea of the A-10 was upgrading the Bronco to jet power and the big gun.
The weight of the GAU8 would keep the Bronco grounded even without ammo.
Bronco... 40 ft span. Take-off speed 73 knots (can't find stall speed )... A-10 span 53 ft. stall 120 knotsFF gliders and rubber power since 1966, CL 1970-1990, RC since 1975.
The A-10 is for sure the best ground-attack airplane ever and I believe all of the tooling to build those airplanes is at the Boneyard in Arizona.
it would be pretty easy to put them back into production, there's nothing exotic about them.Comment
Decided to break out my soap box and elucidate some observations. One of my biggest gripes around here is that people want a plane, but only if it's X,Y, and/or Z. Why not just be glad that it exists in mass production, in stead of you having to go "down to the garage" and scratch build it yourself, IF you are talented enough. Another is that once one IS in production, there's a specific thing that you don't like about it,
such as the powerplant. Well, not to seem ungrateful, but there ARE other sites out there that do offer KIT versions of MRC models, or perhaps we need to lobby for more ARF and ARF+ kits at MRC. And yes, I'll admit I'm guilty as well for griping about a lack of EDFs 70 mm or less, but if you want to know why, check out my post "The Corridor".Comment
Hi Valkpilot, good question! I'm answering that question right now on RCAfterhours.
EDIT: The short answer is that every manufacturer has a different logic tree for what to do with molds. Retire them, recycle them, repair them, resell them. It simply varies.Live Q&A every Tuesday and Friday at 9pm EST on my Twitch Livestream
The reason I asked is that one of your "partners" FMS, had some great 64 mm planes, and I was wondering what type of campaigning it would take for them to bring them back?Comment
Hi Valkpilot, it would most likely depend on the actual model, and whatever reasons they had for discontinuing it. The best route would be to contact www.MotionRC.com/support and ask them to inquire with FMS about that model and if it is available or what it would take to make it available again.Live Q&A every Tuesday and Friday at 9pm EST on my Twitch Livestream
Thank you.Hi Valkpilot, it would most likely depend on the actual model, and whatever reasons they had for discontinuing it. The best route would be to contact www.MotionRC.com/support and ask them to inquire with FMS about that model and if it is available or what it would take to make it available again.Comment
Alpha,
I know the molds are very expensive and appear to be when things are nearing production. However, if a tweak in the mold was needed to be made (without making an entirely new mold) or a company found it was important to do so, is it possible to modify? If I can be modified, is the decision to do so depended on the degree of change that would need to occur, or the cost to do so?Comment
Hey T-Cat, that depends on the tweak. As negative molds, certain tweaks are easier to execute than others. Removing material is always more feasible than adding material. Most tweaks tend to be additive, however. Ultimately, it always comes back to cost. Tweaking very quickly becomes retooling, at which case one might as well make a new mold, at which point one might as well make a new design. Things can snowball quickly, so the general rule of thumb is finish everything before the mold is cut.Live Q&A every Tuesday and Friday at 9pm EST on my Twitch Livestream
