Glue for securing servos in foamies
  • Glue for securing servos in foamies
    Glue recommendations for securing servos in the little compartments of foamies?
    Thanks, Bill
    Re: Glue for securing servos in foamies
    For just securing the servos. I've found the servo tape has worked just fine. No issues....yet....I frequently check them.
    Lon
      Greetings Bill.
      I agree, servo tape does the job quite nicely.
      I and I'm sure many others have also used hot glue at times as well.
      Although I would recommend the newer "Cold" hot glue.
      Servo tape leads the pack though.
      Clear Skies
      Bill L.
      in Okla.
        Thanks guys, I appreciate it.
        Bill
          First wrap the servo with blue painter's tape (provides texture for 'grab'), then secure in place with a pea-sized dab of hot glue.
          Makes future replacement a breeze - the tape peels away cleanly from the servo & you can get at the hot glue & remove; rubbing alcohol will dissolve it, no damage to the foam.
            Thanks.
            On Tue, Sep 16, 2014 at 5:04 PM, StarHopper [via Motion RC Forum] <
            > servo & you can get at the hot glue & remove; rubbing alcohol will dissol=
            ve
            > If you reply to this email, your message will be added to the discussion
            > below:
            > http://motion-rc-forum.1075610.n5.nabble.com/Glue-for-securing-servos-in-=
            foamies-tp3829p3889.html
            > To unsubscribe from Glue for securing servos in foamies, click here
            > <http://motion-rc-forum.1075610.n5.nabble.com/template/NamlServlet.jtp?ma=
            cro=3Dunsubscribe_by_code&node=3D3829&code=3Ddy5lL mJlYXNsZXlAZ21haWwuY29tfD=
            M4Mjl8LTg1MzAzNzQ0MA=3D=3D>
            > NAML
            cro=3Dmacro_viewer&id=3Dinstant_html%21nabble%3Aem ail.naml&base=3Dnabble.na=
            ml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabbl=
            e.view.web.template.NodeNamespace&breadcrumbs=3Dno tify_subscribers%21nabble=
            %3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nab=
            ble%3Aemail.naml>
              RE: Glue for securing servos in foamies
              I use Liquid Nails Projects repair adhesive on my foamies now. It is white, paintable, can be sanded, slightly flexible, and can be easily cut for removal. It also washes up with water. It does take a little while to cure. Very strong. The Doctor
