Freewing Fiat G-91 90mm
  • #21
    Good to hear that Motion will focus on other models. Now for the twin 80mm camo F4!!!
    • #22
      Originally posted by Alpha.MotionRC View Post
      To be clear, we at Motion RC don't have any plans to stock the Freewing 90mm G-91. I wasn't happy with it back when it was first developed, and I'm not impressed by it now. Key parts of the aircraft weren't changed; it's essentially a repaint in response to some requests Freewing received from European customers. The ones I saw on the production line here at Freewing's factory still had the older fans in them, even. A lot has changed in the past three years..
      What a shame it didn't get updated. It would be great to see a V2 for the US market with a 80mm unit instead. But it would have to be in any camo livery or in tricolor.
      • #23
        I wonder if the new 8S system from the Yak-130 V2 would work in this?
        • #24
          No reason why not .. It'll be a straight fit & it's a matter of battery space & attainig the CG..
          • #25
            Motion still Rocks
            • #26
              I'm glad Motion isn't behind this one... It's a waste of foam looks wise.
              Bring on the 80mm Rafale!!! :)
              • #27
                Originally posted by dkalwishky View Post
                Finally a plane from Freewing that I don't want, my wallet thanks you. :)
                I kinda feel the same... Never liked the look of this plane. Kinda like a messed up F-86.... no stanks!!! And dangit FMS has 3 planes that I want now.... the end is near I tell you! Oh and the A-4 is on my list as well....
                • #28
                  Now that is one I would love to see!!!!
                  • #29
                    Yeah buddy! :)
                    • #30
                      I wonder if this is the next offering from Motion and Freewing. It is a Fiat 90mm with a 1550kv motor. I found it on RC Castle's website and here is the link and specs. Looks like it has a functioning parachute system.
                      http://www.rc-castle.com/index.php?r...roduct_id=7190
                      - Scale And High Performance 90mm EDF Jet.
                      - With 90mm 12 Blade EDF Installed.
                      - With Functioning Flaps & Parachute System.
                      - With Scale Cockpit & LED Navigation Lights.
                      - Electronic Retractable Landing Gear With All Metal Shock-Absorbing Struts.
                      With Foam Plane Stand include.
                      Specs:
                      Material: EPO Foam
                      - Wingspan : 1160mm (45.7in)
                      - Length : 1,365mm (53.7in)
                      - Flying weight: Around 2,500g (Not Include Battery)
                      - Servo: 2 x 9g Metal Gear Servo . 9 x 17g Metal Gear Servo (Installed)
                      - Landing Gear : Electric Servoless Retract Landing Gear (Installed)
                      - Ducted Fan: 90mm Special Metal Ducted Fan , 12 Blade (Installed)
                      - Motor: 3748-1550Kv Outrunner Brushless Motor (Installed)
                      - ESC: 130A Brushless ESC (Installed)
                      - Battery: 6S 22.2v 4000 - 5200mAh 30C (Not Include)
                      - Radio: 7 - 9Ch (Not Include)
                      Not crazy about the chosen power plant. I would prefer the 90mm 1680kv inrunner set up on 6s. Anyway, let the comments commence.
                      • #31
                        They already said they were not doing this.
                        • #32
                          How about you just cut the parachute out and put it into the F-4 or make it an upgrade set
