Freewing 80mm F-5E Tiger II
  • Originally posted by Johnnyrabuse View Post
    It's not the same yaw as say rudder but for me it's like the nose gets mushy on the final turn ....
    That long door is flapping away plus the front wheel is creating drag and on this one if you don't get it right and yo have a crosswind on that final landing into a headwind boom it's the tip stall spiral of death especially on five thousands seen it a few times at my field actually three times
    Guys flying five thousands and dumping it either on final or dumping it on initial rotation take off into headwind turn with wind .... Gear down takeoff flaps deployed and boom dead ....
    My trick thus far is take off ...
    Gradual climbout gear up immediately no flaps needed keep it flat with rudder then tear up the sky on landing I deploy flaps on final approach not base turn ease off throttle level down and flair
    Which is why I'll try to stick with 3300 to 4000 mAh battery's
    This doesn’t sound like anything to do with yaw caused be gear doors. Rather you’re too slow and not adding enough power to overcome the increases drag and allowing the nose to drift up. I’ve only flown mine with 5200mah and it’s solid during the entire landing phase.
      Take a close look at the strut if it's not flush in mount they do that
      When you see what in talking about you might notice a gap
      Tighten that sucker up
      Good tip, thanks! I’ll look into that.
      • Originally posted by John Bergsmith View Post
        Well they say that if one person says your a duck your might not be ....
        If two say it I am
        I'll try it your way and practice a different angle of attack I'm very used to warbirds and ...
        F16s but now that I reflect about it I think both of you just gave me food for thought I'll try it with my lighter packs and then toss the good old 6000 in
        Get five minutes ....
        It's sure to stop the floating
        I'll also order another kit now so I won't have to wait for it ...
          If two say it I am
          My guess is you’re not off by much.
            I've got 12 flights in and twelve landings it's still in one piece I don't like heavy planes busts retracts scrapes wings I like to land like a ballerina you know all twinkle toes ....
            Every time I load up for bear with say five thousands on a high wing load I pay for it
            Guess I'm a fraidy 🐈
            • Question. Has anyone here had any issues with the nose landing gear not fully retracting in flight? I just flew off flights #7-10 tonight. On the second flight I noticed the nose landing gear to be hanging partially out and had to cycle the landing gear a second time to get it to fully retract. The third flight went off without any issues. On the forth flight however the problem returned and it took multiple cycles of the landing gear to get the nose to fully retract.
              After returning home and putting the jet on the bench I noted the nose retract has just enough power to retract and close the gear door. If I add even the slightest amount of resistance it will stall out. Maybe the retract itself is weak?
              Thanks!
              • Originally posted by flyinhigh042 View Post
                Thanks!
                I did have that happen once. Like you, I just cycled the gear and it was fine. Since it only happened the one time out of twenty flights I haven't worried about it yet.
                • Ordered one (HP) as well. I'm not happy with the paint, it starts to flake off already on the work bench. Plus crooked/misplaced decals and a missing clip to secure an aileron control rod. 😡
                  I've modelled a nose gear brace and a receiver tray. Both are available for download on Thingiverse.​
                  Click image for larger version  Name:	IMG_3812.jpg Views:	0 Size:	63.5 KB ID:	260869Click image for larger version  Name:	IMG_3814.jpg Views:	0 Size:	91.9 KB ID:	260870
                    Thanks!
                    Possibly a low voltage situation? Have you tried putting it on a servo tester with a fully charged battery? If it works as advertised there I would check the voltage from the BEC.
                    • I’ve flown the F5 a few times and with the CG Spot on (using the front of the plastic cover that hides the wires) the plane takes off great, flies level, but when throttle goes below 30-40% In a Turn, with a clean configuration, the nose rises and the plane gets VERY mushy. Almost to the point of a stall. Adding power corrects it. But it’s almost like the ailerons become ineffective. And when I add flaps I have to keep the power well into the 70% range when turning base and base to final or it’ll nose up and drift. Almost as if the CG is aft, but it’s balanced perfect. I’m going to try to read thru some of these posts to see if anyone has had similar issues.
                      The problem is that keeping the power up while trying to land means a long final and/or a HOT approach. Not ideal.
                      Using 6s 5000
                      Thinking about trying 6s 4000.
                      High performance model with inrunner
                      Thoughts?
                      • Originally posted by Mwhite1911 View Post
                        Using 6s 5000
                        Thoughts?
                        That is a mystery...how much flap deflection do you use on final? I ask because I routinely use 80° and it always gives me a nose down attitude on final. I don't have the inrunner version, but this is one of the few planes that I use the stock CG with. Usually I move the CG back from manufacturers specs, but I'm using the same CG you are. I fly her with 4000mah all the way up to 8400mah and no issues like what you describe have ever manifested themselves.
                        One thing that may explain your faster landing approach would be if you have up elevator programmed to mixed with your landing flaps, is this the case? I've never found a need to mix any elevator with my take off or landing flaps with this plane.
                        Wouldn't explain why it happens in a turn, but I do have a theory about that also. It maybe depending upon your bank angle in a turn that with 30 to 40% throttle you don't have enough speed and are approaching a wing tip stall.
                        The first thing to happen in a lot of jets is a pitch up when a wingtip stall is imminent. Say you were in a left bank with insufficient speed, while maintaining altitude with elevator. If you wing tip stalled her, she'd pitch up and right, opposite of the turn. The outside wing would stall first, the resultant lift vector as that wing stalls increases lift as that wing drops and the aircraft levels itself, exacerbating the reduction in speed before completley flipping over.
                        Sounds to me like you've saved your plane from this multiple times. Flying with a 5000mah in a banking turn, with only 30 to 40% throttle in an F-5 with it's short wings,...i would only do that in a descending turn, not one where I was trying to maintain altitude, thats asking for a high speed stall IMHO.
                        If this theory is correct, 2 things has saved your plane, the over exaggerated camber Freewing built into the wing, and the stability of the F-5's design which good ol Chuck Yeager has raved about many times.
                        By the way, this is one of my slowest landing jets even with 8400mah on board, but I don't land her like most here. I land her in a conventional nose/pitch down attitude during the entire approach, almost power off. You can find my landing technique in this thread, if not let me know I'll find and direct you to it.
                        Most folks I see landing her on YouTube are landing her like an F-16 or a delta wing with a high alpha attitude and 40% or greater throttle, with minimal flap deflection. That's why she's landing like a bat out of hell. Folks make this same mistake landing their F-104's in this manner.
                        • Thanks. You make some very great points. And it may very well be that I am in a turn with minimal throttle trying to maintain altitude in the turn and the outside wing is stalling causing the nose to drift towards the outside wing.
                          But as I mentioned, above 50% throttle, great plane for me. Predictable. No bad tendencies.
                          I’ll see how it works in a descending turn. And I’ll try the 4000 6s as well. Maybe a lighter battery would result in the need for less speed and less of me trying to nose up to maintain level flight in a turn with less throttle.
                          The way the nose would drift and the ailerons get mushy almost seemed like I had receiver loss. Only thing that got me out of it was adding power.
                          ill try to test it out tomorrow morning. 👀
                            May I suggest increasing your throw on your ailerons as well, this may remove any mushiness you feel. The F-5 doesn't really roll like a drill bit like the Mirage 2000 and the A-4, so it can stand more throw.
                            • Originally posted by Phantom View Post
                              Thanks. Yeah I’ve increased the throw on all my planes. I don’t add expo or Dual Rates. Maybe I’ll turn on the gyro and that might counteract the pitch up when I cut the throttle.
                              It’s a great plane, don’t want to lose it off something silly. I’ll keep testing it out. Appreciate the feedback.
                              • Originally posted by Bogietrim View Post
                                Thanks for the reply. The retract operates without issue during ground testing. I did check BEC voltage, it showed 5.2v. I’m using a Castle Creations BEC so I upped the input voltage to 5.4v which for some reason showed 5.3v on the meter. (Tapped into the receiver) After doing this I had three consecutive flights without any issues, so I figured it was fixed. However subsequent flights have once again had issues with the nose gear not fully retracting. On a couple of the flights I had to roll the jet inverted in order to fully retract the nose gear. I’ve since ordered a new retract. When I have time I will install it and see if the issue persists.
                                  Are you using a separate RX battery or tapping off of the main battery? If tapping off of the main battery have you checked your BEC voltage under load? When having a retract issue tried reducing throttle to drop the load and then retract? Just a thought. But, could just be a weak retract as well.
                                  • Update:
                                    Much better characteristics with 4000 6s instead of 5000 6s.
                                    Used a Gyro and made the plane a little more rock solid.
                                    Full flaps base to final with less than half throttle, plane still mushy and wanted to pitch up and drift.
                                    Full flaps added when already on final, much better.
                                    Ultimately will fly with 4000 6s. Gyro, and use half flaps / takeoff flaps for landing.
                                      I’m just tapping off the main battery. Good idea checking BEC voltage under load and varying the throttle setting. I’ll give that a go before swapping out the retract. Thanks.
                                        I've had the same issue repeatedly on my Mirage, which uses the same retract and spring to close the gear door.
                                        I don't believe it's voltage related. I fly off sandy, clumpy grass and believe it is either "gunk" related (slowing/binding of the worm gear) or just damage related, as the gear stalls out at any resistance. Rolling inverted works sometimes for a short while, given the gravity assist, but the only long term fix I've found is a new retract.
                                        • Originally posted by Mizer67 View Post
                                          Thanks for the info. I’ll prob just go ahead and replace the retract. I have one in hand and ready to go.
