New Dynam Gloster Meteor f8
  • Evoman
    Originally posted by yf22raptor View Post
    Mirage 2000 3 -D printed cock fits perfect with little mod just finished weathering painting and add green led light..
    Great work with the cockpit detail! That green cockpit light is a great idea and a nice touch rarely seen in this level of scale modeling. I might just do the same in my next airplane. :Cool:
  • lmramos44
    Successful maiden today 3 flight ...
    she flys nice rotates fast and is a floater on landing
    no flaps need .
    will need elevator mod 9grm servo and thier set up
    not enough for a full speed dive will add independent
    elevator servos and upgrade to 19gram metal gear .
    OK, I have a long review of my two first flights. Tell me what battery you used, flight duration.....etc. Rtracts working ok?
  • yf22raptor
    no flaps need .
    Originally posted by lmramos44 View Post
    I agree.....
    I cant wait to see how she does, hope you can get a good video when she rotates into the wild blue!
  • yf22raptor
  • lmramos44
    Originally posted by rifleman_btx View Post
    Indeed and that static numbers, should be even better in air :)
    I agree.....
  • lmramos44
    Coming along , upgraded 6 cell fms edf and inunner motors
    smoked conopy and will try a few other canopy options will be adding new wheels. Gonna try sm 90 mm yak struts, A -10 gun pods, inlet rings weathering etc .
    maiden this week ...
    Very nice, inspiring me to do more. The Robart wheels look great on mine. Probably going to fly using a six cell, numbers say it will work and funny enough, it cg’s perfect with a 6s 4000.....go figure.
  • yf22raptor
  • lmramos44
    Six cell meter reading
  • lmramos44
    Ok so I hooked the meter up to the Gloster and plugged a 6s 4500mah 65c in. I reluctantly slowly pushed the throttle to full and here are the numbers:
    102 amps
    2028 watts
    4.91 lbs of thrust
    so I still have plenty of head room as far as the esc’s are concerned, but that does not mean the motors are going to last pushing the extra voltage . I also consider the fact that the fans do not “unload” like they would while moving through the air. Sooo, I am going to maiden this baby tomorrow and take a six cell if I feel lucky. Fingers crossed.
  • fhhuber
    Well I will put the meter on them and see what I get running a 6 cell....let you know.
    I suspect the fan rotor wouldn't handle 6S even if the motor can.
    I've seen the results of an EDF rotor burst. You don't want it to happen inside your model. It could rip the Meteor's wing apart.
    But you do want a significant amount of foam to absorb the energy of the blades getting thrown off the fan or you want to be behind a Lexan shield...
    Depends on the capacity and c rating. If its low on either then yeah thats gonna hurt the pack, but if its say a 5000, 40+ c rating, shouldn't be any issue
  • lmramos44
    Just ran power test using a 4s 4500mah 45c (full throttle)
    101.79 amps
    1407.99 watts
    4.75 lbs thrust
    Thats asking a lot from a 4 cell. What do you guys think?
    Thanks
    Get some video!:Cool:
  • lmramos44
    Ok, so I installed the Robart wheels and finished the paint. I am still undecided on the stock decals. Going to hook it up to the meter tonight and see exactly how many watts/amps it pulls. The maiden Sunday. Saturday we have a Jet Fly In at Lodi, Ca. All the big money will be there. I will post some pics.
  • lmramos44
    Originally posted by TiredIronGRB View Post
    I realize that but the motor ESC looks like it would be fine on 6S.
    Yes and as for the extra weight, one could always lighten the load with lower capacity packs.
    Esc’s do not determine your input voltage. That is dictated by what motors are turning those edf’s. ;)But I agree a jet of this size should have a 6s power system. I will see how well I like this jet and decide if I should invest in a 6s power system. If I do it will either be a Freewing or RC Lander set of fans.
    Looking forward to seeing how it turns out!!! Good luck with the maiden!! :Cool:
