New Dynam Gloster Meteor f8
  • Shauncat
    • Jul 2020
    • 17
    Hi Guys, I'm having difficulty with the CG between 125 and 130mm from the leading edge of the wing as per the manual. I using a 4Cell 5000mah battery and even with the battery way back, it's still nose heavy. Anyone else experiencing the same issue.
    Regards,
    Shaun
    • Jetnut
      • May 2023
      • 9
      My Dynam Gloster Meteor has been THE most frustrating and worst model I have ever purchased.
      after re- engineering the stab/ fin/ rudder so they don’t fall off mid flight I found neither main retract worked, the right esc was shot, both winglets crushed out of the box, and more than six servos had GLUE inside the cases, and two servo extension wires not connected and glued to inaccessible foam channels.
      I would NEVER recommend purchasing a Dynam model if this is the way they are made. Nothing fits properly and nothing worked as it should. Even the motor fan was not fastened with the right screw.
      Beware of this manufacturer.
