New Dynam Gloster Meteor f8
  • fhhuber
    • Aug 2015
    • 1476
    Adding power adds weight every time, if you want to maintain the same flight duration.
    Carrying that weight requires more power for minimum airspeed to maintain controlled flight. The increased minimum airspeed needed is directly related to weight. The power needed has a CUBIC relationship to the increased airspeed.
    You have to have 8X power to double airspeed, before you get there you can easily be too heavy to fly.
    The 4S Dynam 70mm fans are pretty decent. The 60 amp ESCs Dynam supplied previously were marginal for the fans. They work much better with Castle ESCs.
    • lmramos44
      Jet Pilot
      • Mar 2014
      • 199
      • San Leandro, Ca.
      The Gloster now comes with 80amp esc’s. First run up went well. We will see......
        Looking forward to seeing how it turns out!!! Good luck with the maiden!! :Cool:
          Originally posted by lmramos44
          Esc’s do not determine your input voltage. That is dictated by what motors are turning those edf’s. ;)But I agree a jet of this size should have a 6s power system. I will see how well I like this jet and decide if I should invest in a 6s power system. If I do it will either be a Freewing or RC Lander set of fans.
          I realize that but the motor ESC looks like it would be fine on 6S.
            Yes and as for the extra weight, one could always lighten the load with lower capacity packs.
            • lmramos44
              Jet Pilot
              • Mar 2014
              • 199
              • San Leandro, Ca.
              Well I will put the meter on them and see what I get running a 6 cell....let you know.
              • lmramos44
                Jet Pilot
                • Mar 2014
                • 199
                • San Leandro, Ca.
                Ok, so I installed the Robart wheels and finished the paint. I am still undecided on the stock decals. Going to hook it up to the meter tonight and see exactly how many watts/amps it pulls. The maiden Sunday. Saturday we have a Jet Fly In at Lodi, Ca. All the big money will be there. I will post some pics.
                  Get some video!:Cool:
                  • lmramos44
                    Jet Pilot
                    • Mar 2014
                    • 199
                    • San Leandro, Ca.
                    Just ran power test using a 4s 4500mah 45c (full throttle)
                    101.79 amps
                    1407.99 watts
                    4.75 lbs thrust
                    Thats asking a lot from a 4 cell. What do you guys think?
                    Thanks
                      Depends on the capacity and c rating. If its low on either then yeah thats gonna hurt the pack, but if its say a 5000, 40+ c rating, shouldn't be any issue
                      • fhhuber
                        • Aug 2015
                        • 1476
                        I suspect the fan rotor wouldn't handle 6S even if the motor can.
                        I've seen the results of an EDF rotor burst. You don't want it to happen inside your model. It could rip the Meteor's wing apart.
                        But you do want a significant amount of foam to absorb the energy of the blades getting thrown off the fan or you want to be behind a Lexan shield...
                        • lmramos44
                          Jet Pilot
                          • Mar 2014
                          • 199
                          • San Leandro, Ca.
                          Ok so I hooked the meter up to the Gloster and plugged a 6s 4500mah 65c in. I reluctantly slowly pushed the throttle to full and here are the numbers:
                          102 amps
                          2028 watts
                          4.91 lbs of thrust
                          so I still have plenty of head room as far as the esc’s are concerned, but that does not mean the motors are going to last pushing the extra voltage . I also consider the fact that the fans do not “unload” like they would while moving through the air. Sooo, I am going to maiden this baby tomorrow and take a six cell if I feel lucky. Fingers crossed.
                          • lmramos44
                            Jet Pilot
                            • Mar 2014
                            • 199
                            • San Leandro, Ca.
                            Six cell meter reading
                            • yf22raptor
                              Love to fly
                              • 75
                              Coming along , upgraded 6 cell fms edf and inunner motors
                              smoked conopy and will try a few other canopy options will be adding new wheels. Gonna try sm 90 mm yak struts, A -10 gun pods, inlet rings weathering etc .
                              maiden this week ...
                              • lmramos44
                                Jet Pilot
                                • Mar 2014
                                • 199
                                • San Leandro, Ca.
                                Very nice, inspiring me to do more. The Robart wheels look great on mine. Probably going to fly using a six cell, numbers say it will work and funny enough, it cg’s perfect with a 6s 4000.....go figure.
                                  Indeed and that static numbers, should be even better in air :)
                                  • lmramos44
                                    Jet Pilot
                                    • Mar 2014
                                    • 199
                                    • San Leandro, Ca.
                                    I agree.....
                                    • yf22raptor
                                      Love to fly
                                      • 75
                                      Mirage 2000 3 -D printed cock fits perfect with little mod just finished weathering painting and add green led light..
                                        I agree.....
                                        I cant wait to see how she does, hope you can get a good video when she rotates into the wild blue!
                                        • yf22raptor
                                          Love to fly
                                          • 75
                                          Successful maiden today 3 flight ...
                                          she flys nice rotates fast and is a floater on landing
                                          no flaps need .
                                          will need elevator mod 9grm servo and thier set up
                                          not enough for a full speed dive will add independent
                                          elevator servos and upgrade to 19gram metal gear .
