3d Printed Part Sets - Freewing F-4D Phantom II
  • Dirty Dee
    • 768
    • Northern Illinois
    Originally posted by Wobisch
    I have printed the center tank and I am super excited. My new ABS with anti warping technology works fantastic. Thank you Chris.
    Looks, great! What brand ABS are you using?
    • Wobisch
      • 83
      • Merenschwand, Switzerland
      Hi this is a special ABS S filament which has less shrink rate. This allows to print long pieces lying on the print plate. I don't know because I am new in 3D printing, but I guess this is a local brand here in Europe or Switzerland. Is it allowed to post a link to a webshop?
      • Wobisch
        • 83
        Biggest progress I made using this ABS S filament combined with a Lokbuild adhesion plate and a cover for my ultimate 2+. I also switched from Cura to Simplify 3D Software. Since then I can do much better parts. I had to learn using less temperature (230°) instead of 250° I started with. Build plate is heated up to 90° instead of 100° to avoid "Elefant Foot".
        Since then printed a lot of DirtyDee's Parts. I really appreciate his work for the community.
          • 4875
          W0-B, Thank you. I am familiar with ABS-S filament. Parts look great.:Cool:Best, LB
          • Dirty Dee
            • 768
            • Northern Illinois
            Absolutely! No issues posting webshop links
            • Wobisch
              • 83
              At the top of the page you can change the language to english.
              ABS-S Spezial Filament 2.85mm - schnellfliessend mit AntiWarp Technologie für sichere ABS prints!
              • apmech1
                Warbirds old and new
                • 266
                • CVG Airport, Kentucky
                Not to be duplicating efforts, but I made a 600 gallon centerline tank as well. Bartered with dlxpkg for a pair of wing bags for my A-10 in return for a printed centerline tank:)
                Some design differences from apmech1's, like utilizing the stock FW hardware as well as I added the aft sway braces. Will upload to thingiverse after I finish printing them and make sure they are good.
                I wish I would have thought of putting the females on the tank instead of the males.... great Idea! And to Steve's idea to put 2 on there. I will probably re-do some of my parts incorporating these changes as well.
                • apmech1
                  • 266
                  Here is the centerline tank. 94g with ABS and printed in 3 parts. I should have it up on Thingiverse tonight.
                  Is that 145 a scratch build or a kit? I would love to get a hold of a CRJ900.
                  • Tooeleflyboy
                    CS Agent
                    • 508
                    Just finished my cockpit, the parts look really good and it was a fun project now to do the nozzles and the pilots are from Jet Hanger Hobbies.
                    • fhhuber
                      • Aug 2015
                      • 1476
                      Just vampire-downloaded all the printer files....
                      Now if they will start letting us order the Ghost Grey....
                      • Dirty Dee
                        • 768
                        • Northern Illinois
                        Scratchbuild. I posted plans on RCGroups under my blog. Im actually considering selling it to make room for my current A333 project.
                        • dkalwishky
                          Warbird Lover
                          • Sep 2015
                          • 1382
                          • Des Moines, IA
                          If you decide you are going to sell it let me know. I'm interested and being in Iowa I can drive over to get it.
                            • 4875
                            Derek, That looks outstanding. Great work. Best, LB
                            • Tooeleflyboy
                              CS Agent
                              • 508
                              Thank you !
                              • Bobaroo
                                If it Ain't Right on the Ground...
                                • Dec 2017
                                • 327
                                • Newburgh, IN
                                Any suggestions or requests for 3d parts for these airplanes?
                                Hey,.. I have a few requests...
                                If you could work on:
                                A TailHook for this that'd be WaaaaayCool !! Printed in (L)(R) Halves that would be bonded to a Center Structure for increased strength and Durability !! The Wire Capture Ends would need to be Removable as well due to their getting Ground Down on the asphalt upon landing. The pivot assembly and Attachment Forebody should have an internal framework of Plywood or Carbon Fiber with the 3DPSkins or Outer Shells attached to that !!
                                Operating Canopies// Frames and Pivot assemblies
                                Also a Standard ARM for my WildWeasel and some AGM-88s Please !!
                                • Jhnybgd
                                  • Dec 2017
                                  • 262
                                  +1 on everything you said!
                                    • 4875
                                    Q: What's a Navy Phantom without 'Launch Hooks"? A: Carrier Hood Ornament. LOL What a 'dork'. :Silly: Best, LB
ID:	181138 ​​​​​​​ Click image for larger version
                                    • Bennet86
                                      • Mar 2019
                                      • Kleinheubach, Bavaria
                                      Hey guys,
                                      is someone here from Germany, who has experience with F-4 parts and can print some for me? I want to upgrade mine with a centre Tank an some Sparrows.
                                      Thanks a lot! Bennet
                                        Welcome to HobbySquawk. Reach out to Radar-Guy. He is in Germany and is actively creating parts on the thread for F-22 3D printed parts.
                                        • Dave Matrix
                                          Pilot
                                          • Jan 2019
                                          • 30
                                          • Amsterdam Netherlands
                                          Hi Derek,
                                          Pilots looks very awesome! Did you use the 1/10 scale or 1/12 scale pilots?
                                          regards
                                          Dave
