FMS F-18F Super Hornet 70mm EDF Jet
  • Junior_Hairston
    • Apr 2019
    This question is more directed at people who own both the FMS F-18, and the E-Flite F16. Both are similar prices, but I was wondering which was better quality/value, and a much more enjoyable experience to fly. Which one for you recommend for someone wanting a 70mm EDF?
    • Tom
      Super Moderator
      • Sep 2013
      • 905
      They are close to the exact same plane so quality and value should be the same. Clearly different airframe but same power systems and EDF and made by the same factory.
      • Ron1950
        Retired ATC
        • Oct 2015
        • 887
        • brandon ms
        I don't know tom as my f18 has rough edges and nose cone doesent fit as snug as id like...if eflite doesent do a better job of qc on the f16 id find that strange...the eflite f4 is so smooth and well done in my opinion
        • gooniac33
          The Original Gooniac
          • Jun 2016
          • 1047
          I have both planes so can speak from experience. The F-18 will probably do better on grass too and is built better than the F-16. Its a stronger plane with better landing gear. It is painted really well as well. The F-16 is bare foam with bits of paint here and there... It flies great but the gear leaves some to be desired... F-18 is the winner to me...
          • gooniac33
            • Jun 2016
            • 1047
            my flights from this past weekend.
            • Ron1950
              Retired ATC
              • Oct 2015
              • 887
              • brandon ms
              had to order another f18 today after I turned my old one into a fence post when the tail feathers on one side came unglued and fell off Click image for larger version
              • Rcfiddy1
                Professional Crash Test Dummy
                • Aug 2015
                • 186
                • Manalapan, NJ
                Also the f18 has a smaller battery bay and short esc wires where as the f16 you can fly different size batteries and have room to get your CoG. The f16 feels cheaper with but flies great. You will probably break the main gear cover since it’s not supported and the front gear is soft. I tend to fly my f16 more because it will high alpha with ease and just flies lighter. The fa18 looks great and flies good but needs a bit more runway to rotate due to nose gear being shorter. I personally love the fa18 for its looks and sound but the f16 for the fun factor.
                • Ron1950
                  Retired ATC
                  • Oct 2015
                  • 887
                  • brandon ms
                  used the vfa 31 undamaged tails on my new f18 just witing for callie graphics for a few more decals then back in buisness
                  • Skyscraper
                    • Oct 2017
                    • 7
                    • Baltimore, Maryland
                    Have mines just can’t find the right cg spot
                    • Ron1950
                      Retired ATC
                      • Oct 2015
                      • 887
                      • brandon ms
                      hey sky look for a box about 3 inches back on edge of the wing that's where I found a good cg...its actually the book cg lol
                      • Rcjunkey
                        Love that RC stuff since 1990
                        • May 2018
                        • 23
                        Depends on when he purchased it when I purchased mine the manual came at 80mm from the Leading Edge but I was one of those ones that pre-ordered when it was first released big mistake on my part look like somebody already crashed it. But for some after the first release the manual said 70 mm so it's been confusing for a lot of people.
                        there was even a fellow on another Forum that said 72 1/2 millimeters was The Sweet Spot LOL.
                        I have no idea how you figure out that half millimeter:Thinking:
                        • Ron1950
                          Retired ATC
                          • Oct 2015
                          • 887
                          • brandon ms
                          just measured where my cg is and it turned out to be 75 to 80 mm's I think that's with a roaring top 6s 4000 that's done with the finger methiod upside down gear out and then back in...I do like a slightly nose down cg though
                          • RanGee
                            Ducted FUN!
                            • Aug 2017
                            • 64
                            Had a great time with my F-18 this weekend, I haven't flown this bird for quite a long time so this flight was pure enjoyment!
                            • gooniac33
                              • Jun 2016
                              • 1047
                              Haven't posted here in way too long... here are some highlights from the last few flying sessions! It is currently down for maintenance since it gets so much flying time! I really do love this bird!
                              • Daneflyer
                                Aviation is my life
                                • 13
                                • Centennial Co.
                                Dang vertical stabilizer screws. They don’t line up with the threaded inserts. Anybody Else have this problem, and if so what did you do to remedy?
                                • gary ritter
                                  i had the same problem, didn't want to rotate, pulled out front strut as far out it can go, now the stance is correct and takes off fine ,used some jb weld
                                  • Smitten4jets
                                    • 5
                                    • Central California
                                    that was a bit of a struggle. True story, after getting a bit frustrated with this I took a break then handed the task to my son. He had the las two screws in within minutes. The tolerances are tight and I had to pull the wings back a bit while working the threading in a couple turns at at time going back and forth between screws. Once completed they’ll be more forgiving if you take the wings and stabs off and on for transport.
                                    Scott M
                                    • Johnnyrabuse
                                      winner wolf
                                      • Apr 2020
                                      • 136
                                      • NY
                                      Maidened mine today 3300 all the way forward I have one thing to say ....
                                      OMG
                                      Three clicks of up noflap ballooning and under fifty foot rollouts
                                      Tracks on ground like dream
                                      Does take 170 ft to rotate low angle of attack but that same aoa keeps it on the ground when landing
                                      3 minute 3300 mixed throttle 9 to 14 left on battery
                                      I'm very satisfied
                                      On a sad note I lost my FW f16 to the evil sun God today my fault almost didn't do maiden hate loosing two in a day but it went well and honestly the F18 lands better and is better built
                                      I'm going to get anotherf16 this week if possible I'll get the FW and the eflitein t bird
                                      • Peteremus
                                        • 11
                                        Anyone know if you can get another pilot for the rear seat in the F18F?
                                        • Josefimbres@comcast.net
                                          • Jan 2021
                                          Just received my fms f18, running 3200 6
                                          s 30c smart battery, cg placed at 75/80 in tray blancedon gp balancer , does that sound ok. Want to get it right before maiden.
