  • C17loadmaster
    All of my jets have the opposing limitation issue. It’s only when pushing the control surface to the absolute limit. It’s because you can’t center the control arm onto the spur gear of the servo. The two separate elevator servo control horns are always about one tooth off of dead center. If you push full down elevator it will be the opposite effect. I trim it out by limiting the opposing servo in that direction of travel, then limit the same servo for the opposite direction. I think both servos on mine set up like this...(Right Elevator 150% UP, 135% DOWN) and (135% DOWN , 135% UP on the Left Elevator. So your true maximum throw either direction is 135%. (Those numbers are just an example)
    Kinda hard to explain. To answer your other questions, I think my plane did require a bit of trimming, but once set it stayed true. I don’t know what would cause uncommanded radio trim values t o change. More like stripped servo, loose connection, or something along those lines. I regrettably run a Spektrum iX-12 with 12 channel receivers. It’s awesome when functioning correctly, but pisses me off when it’s not because of the price tag.
  • TangoVector
    Receiver thoughts for Sam CS:
    If you switch the servos on the receiver, you will notice if the throw is changing (never mind if they travel the wrong way) If the same servo throws more, it's servo-related. If the other servo increases, it's receiver-related. I would have thought a reduction of the output to the max throwing servo would be an easy workaround to get the servos to match. Are you using openTX on the Taranis? If so, when you simulate in the companion, do they look to be moving exactly the same?
    Regards
    Tobias
  • Sam CS
    Thanks for responding,
    I am using X9D+ and x8r receiver with 2 decoders to get 16 channels. The ailerons and stabs are plugged directly into the receiver, each on its own channel.
    This was first time i noticed that servos got out of trim. I might have tweaked the trim by accident or something in the channel mix could have caused the stab servo go out of trim.
    The question is about aileron trim on the pictures i attached. That's a lot of trim for a new model.. don't you think? It gets me level flight, but i just wonder if you had to have that much trim for your Su out of the box?
    Another thing i am dealing with is stab servos aren't synced.
    I used x8r on my FW F16 and noticed significant roll to the right every time i flare up the model before landing. So, i measured the throws of my elevator servos and found that they aren't synced. One servo would give more travel than the other causing uneven elevator. I got same problem on Su and beginning to wonder if it's x8r related.
    To better explain... On the radio all numbers are the same for both channels except one channel is reversed. All mixes are the same. Both servos are centered when in neutral position. However, when i give full elevator, one has more throw than the other. The work around i found is by using curves in the mix.
    C17LM what radio do you use by the way?
  • C17loadmaster
    Are you using each stab and aileron on their own channel? If you did a good amount of trimming on your last flight and didn’t look at the control surfaces, at least they counter one another. Just a thought..,
    Radio system are you using? I’ve had issue with some receivers and especially gyros in this plane. Also, the control horns become soft after a while due to the way they mount. I tightened mine further than necessary, then epoxied them in. Basically making them permanently part of the control surface
  • Sam CS
    Need help or advise;
    I replaced original FW stab servos with these KST DS215MG. Last time i was out flying, the model was trimmed, that was about 2 weeks ago. I went out this morning and noticed that my left stab was out of trim. Radio hasn't been touched and i could have bumped the stab while moving it, but on power-on it should have came back to it's fixed position.. Also, servos are buzzing on and off. Right stab seem to be okay.
    Is it normal for a servo to get out of trim?
    What would cause the servo to get out of trim (not including radio TX)?
    Another thing too, take a look at the pics, notice the aileron trim - this is my level flight trim. Is this normal? IMO its a bit excessive.. don't you think?
  • C17loadmaster
    Once you get it worked out and get to start seeing what the plane can do it will all be worth it. Nothing flys like the SU.
  • Sam CS
    I was planning on gaining some altitude and diving down under 45* or so without any thrust to see if i still get the roll effect. After that is done, go into level flight and throttle up to 100%, by doing so i should get an idea if TV needs trimming. I never done this before so it's only theory at this point. Hoping to get this accomplished this weekend.
    You know, with TV nozzles, I'd check those first before suspecting the ailerons. Even if the nozzles are just a little unequal, you can get a slight roll, even at low speed. The more thrust that goes through them, the more affect on roll and yaw.
  • Sam CS
    Copy that C17LM, I agree, too many factors to consider. I'll start with stabs and move to TVs.
    Its definitely going to be a project to get this thing trimmed right.
  • C17loadmaster
    Also, there are a bit more possibilities to cause this plane to not fly straight compared to others. 1. Is the nozzle alignment 2. Motors/ESCs not calibrated together 3. The lower fins out of alignment (I call them strakes, like on the C-17) 4. The wings can be secured uneven due to the round brace in a square hole. 5. Standard control surface trim and alignment.
    After a while the wing braces can gain play in them causing them to chatter when taxiing and in flight. I wrapped the circular wing insert with metal ducting tape to eliminate the noise and slop and in the wings from causing issues in flight.
  • Sam CS
    Thank you guys for the suggestions, looks like rotary knob is what i will do.
    S.
  • TangoVector
    Disclaimer: I'm quite new to OpenTX but this is the way I would try to do it and it should be relatively easy. Add the left rotary knob S1 in the INPUT, with maybe 20% weight. MIX for both CH4 & 5.
    INPUT
    name TRIM
    Source S1
    Weight 20%
    MIX
    Add on ch4 and 5
    name trim
    Source TRIM (actually there will be a I: and a number prior to TRIM)
    Make sure one of the channels are set to -100% for different travel.
    I don't have my OpenTX computer with me, so there is no testing being done, but it "should" work. Once you are happy with it you can make the necessary hardware changes and remove the rotary knob from everything. Test on ground first
    Originally posted by Sam CS
    Anybody flying this thing on OpenTX?
    Cant figure out how to trim stabs in-flight independently. Example: my horizontal stabs set to ch4 and ch5. Aircraft banks left, im almost positive its due to stabs being out of trim. Is there a way to setup trims to ch4 & 5 and trim it in-flight?
    I used ail trim to achieve level flight but ail not the problem.
    Any thoughts?
    The best way is to manually trim them via rod length on the ground, but to do it in flight, you'd have to have mess with servo sub-trim while flying, which could be somewhat dangerous. I suppose you could also put one of them on the rotary knob (assign to one of the channels) and mix it so you can adjust during flight and then use elevator trim to adjust the whole thing if it needs it. But then, this would have its hazards as well in that the next time you fly it after flying something else, the rotary may have been moved.
    Personally, unless you're talking about a huge amount of AIL trim to correct this, I'd eyeball the elevators as best you can and just leave it.
  • Sam CS
    Any thoughts?
    Yeah, I guess. My SU-35 is my second one. My current F/A-18 V1 is my third one, but none of the crashes were due to failed anything except my first SU, which melted the Dean's connectors. The rest were dumb thumbs or gopher dirt mounds when landing. I just kept buying them till I figured out how to fly them.
  • Sam CS
    Don't get me wrong X, i just want to see better quality gear installed on critical components (like stabs for example) on a $400.00 model... that's all.
    From what i red on multiple forums the fail rate is high.
    I guess if we don't wreck them, we wont buy them... right lol? ;)
    I'm guessing I've had a couple dozen (probably more) Freewing and FMS planes over the years and I only recall out of all those, 2 servos gave me cause to change them out. I think they cost the manufacturers maybe 5 bucks each but they seem to work just fine. If they suddenly put in $30.00 servos just to appease a few "critical" owners, we'd see an increase, on average of $100.00 per plane. I doubt I'd have purchased nearly as many planes as I have. They are getting more and more expensive now due to better quality of fit and finish and detail. I can't afford a lot of the ones that really appeal to me. Add another 100 bucks and you can strike off several more.
  • C17loadmaster
    They definitely aren’t top notch, but they’re not complete garbage. I’ve read about them a lot, especially for the F-14, and they still work fine. I don’t think there is anyway you will tell the difference in flight, but I had the same perspective as you do when I first got them. Some models need to have their servos swapped out immediately IMHO. The F-86’s ailerons and flaps are plastic geared with large control surfaces. The flaps have gone out on mine plenty of times from any type of pressure applied to them.
    I did swap out the control rods and connectors to ball link from the F-15. I added small washer on the outside of the ball link side, and fuel tube on the white retainer to prevent a disconnection in flight. The standard snap on plastic connectors and S bend rods are in the box of spare parts
  • Sam CS
    I just dont understand why they sell a pricy model with cheap ass servos.
    I wouldn't mind paying $30 per servo as long as it fixes the problem.
    I had same issue on 70mm f16v2... seems like freewing going cheap on servos 😞
  • C17loadmaster
    ***I just re-read your comment and apparently I missed that you were looking for digital
    I have currently have 3, and have totaled another 2. They all have the sloppy elevators, and all the other flight controls as well. You can see the slop more on the full flying stab.
    I replaced them on the F-14 and it made it a bit better using the same linkage and connections. They were Hitec HS-85MG. They are the same size as the SU-35. They do feel and sound much than stock, and they won’t break the bank. They have the standard version as well for $10 cheaper.
    https://www.towerhobbies.com/cgi-bin...SABEgJEoPD_BwE
