3d Printed Part Sets - Freewing 90mm F-22 Raptor
    Originally posted by mr.frankenjet View Post
    Does anyone have the complete cockpit set files, likely they are out there but I don't know where (story of......
    FJ, page 1 of this thread. .
    No worries, most guys have forgotten that's where all the STL files were originally posted, on or near the opening pages.
    And you can call me LB, but whatever you do, don't forget to call me for dinner.....
    Best, LB
  • mr.frankenjet
    Originally posted by Elbee View Post
    mr.frankenjet, Very clever, Sir. Best, LB
    Thanks Elbee, much appreciated !
    Does anyone have the complete cockpit set files, likely they are out there but I don't know where (story of my life )
  • mr.frankenjet
    front wheel hub, really thin, print w raft base and leave it on, compress a bit and epoxy to fit concave taper
  • HarmLess
    Originally posted by Radar-Guy View Post
    Here is an ESC cover (designed for the 6s 130A unit).
    Hi Radar Guy, would love to install your cover, where can I find the STL?
    Edit: Stupid me, it was there, just didnt click on the right thing...
  • kallend
    Jasony, Motion RC took down all the 'freebie' add-on files from their website,
    However, you might find the OEM STL files on page 1 Post #2 of this Official F-22 Thread. Best, LB
    I didn't see them there, but a quick search on Thingiverse found this.
    This is a file dump of the 3Dpup parts available on the F-22's support page. I am in no way taking any credit for the creation of these models. I simply wanted to make sure they were available from another source in case something ever happens to the original download link.Please visit the product's support page to get the original files:https://www.motionrc.com/products/freewing-f-22-raptor-90mm-edf-jet-pnp#support-tab
    Originally posted by Jasony View Post
    I cannot seem to locate the stl for the weapons bay, launcer, and rocket. did they get moved?
  • Jasony
  • Con Papaioannou
    Click image for larger version  Name:	1625964618373(1).jpg Views:	0 Size:	188.4 KB ID:	318871
    3D cockpit parts.
    Click image for larger version  Name:	1625964618387.jpg Views:	0 Size:	146.0 KB ID:	318872
    Click image for larger version  Name:	1625964618359.jpg Views:	0 Size:	130.6 KB ID:	318873
    Freewing 90mm F-22 3D parts cockpit
  • Con Papaioannou
    Originally posted by RCjetdude View Post
    Brad, I did it with an arm I designed and mounted to the inside of the door. The only real mod to the door is to remove the horn on the outside of it and a little bit of a rib on the inside of the door. You have seen this before haven't you?
    Awsome looks nice and clean
  • Con Papaioannou
    CP, Beautiful work, Sir. You've saved this one. Best, LB
    Cheers LB Glade you like
  • Con Papaioannou
    Decals applied
    Now for the under belly with some yellow.
    Finished build
    Hope you like
  • Con Papaioannou
    Hi All Hope you are all well,
    I have done something a little different with my Freewing F22 Raptor,I know its not to scale but its my favorite scheme.
    I purchased this as an arf kit it was a little beaten up so i decided to do it my style.
    Take a look any comments welcome.
    Click image for larger version  Name:	1625964162393.jpg Views:	0 Size:	81.8 KB ID:	318263Click image for larger version  Name:	1625964162404.jpg Views:	0 Size:	65.9 KB ID:	318264Click image for larger version  Name:	1625964162415.jpg Views:	0 Size:	76.6 KB ID:	318265Click image for larger version  Name:	1625964162381.jpg Views:	0 Size:	59.5 KB ID:	318266
    This is the original condition before mods
    Click image for larger version  Name:	1625964313939.jpeg Views:	0 Size:	94.7 KB ID:	318267Click image for larger version  Name:	1625964313974.jpg Views:	0 Size:	78.3 KB ID:	318268Click image for larger version  Name:	1625964313955.jpeg Views:	0 Size:	103.2 KB ID:	318269 .
    After some repairs& Primer added did some more sanding Click image for larger version  Name:	1625964463469.jpeg Views:	0 Size:	123.3 KB ID:	318271Click image for larger version  Name:	1625964463404.jpeg Views:	0 Size:	113.1 KB ID:	318272
    Click image for larger version  Name:	1625964463449.jpeg Views:	0 Size:	129.6 KB ID:	318270
    Click image for larger version  Name:	1625964463426.jpeg Views:	0 Size:	142.0 KB ID:	318273
    Repairs and primer done..
    Click image for larger version  Name:	1625964463502.jpeg Views:	0 Size:	169.5 KB ID:	318274Click image for larger version  Name:	1625964463485.jpeg Views:	0 Size:	157.8 KB ID:	318275Click image for larger version  Name:	1625964463517(1).jpeg Views:	0 Size:	62.1 KB ID:	318276
    Click image for larger version  Name:	1625964253537(2).jpeg Views:	0 Size:	109.0 KB ID:	318279Click image for larger version  Name:	1625964253560(2).jpeg Views:	0 Size:	150.3 KB ID:	318280Click image for larger version  Name:	1625964253598(2).jpeg Views:	0 Size:	86.5 KB ID:	318281Click image for larger version  Name:	1625964253621(2).jpeg Views:	0 Size:	77.3 KB ID:	318282
    Now for some white paint to start off the scheme.
    Click image for larger version  Name:	1625964463380(1).jpeg Views:	0 Size:	38.2 KB ID:	318278
    Click image for larger version  Name:	1625964463533(1).jpeg Views:	0 Size:	106.1 KB ID:	318277
  • Pacro
    Hi there, this is my first post on Hobby squawk but I am no way new to RC jets.
    I've had one of these since it came out and I have yet to assemble it.
    I have read through this thread about the 3d parts, and as I will be having a set printed I would like to double check. Are the files in this part/original post the same as the ones on the MRC website. As I do not have a stl file reader so I'm not sure which files to give the printer shop. Can anyone give me a heads up/on which are the correct ones.
    Here are the .stl files I have created to be able to make the opening canopy mod like I did it. Could the parts be improved upon? Absolutely. I was able to make a slight change to the tab on the underside of Alphas canopy frame to make for a stronger attachment with the pivot arm I designed. I am still learning Fusion 360 and had to have some help from a friend who is more skilled at it than me to make the change to the canopy frame and create the missing inlet cover but we both learned a lot in the process. I will try to put together a mod thread with more pictures and videos to help make it easier for anyone who wants to give the opening canopy a go. I have also included the missing Starboard Inlet Cover below. All together, with the 3D printed cockpit parts, stock pilot figure and a 17 gram metal gear servo the mod added just under 4 ozs. total to the stock canopy/cockpit tub. I did have to shift my batteries (8S) back a little more to get it to CG but it did without much effort.
    Steve
    [ATTACH]n169349[/ATTACH]
    [ATTACH]n169350[/ATTACH]
    [ATTACH]n169351[/ATTACH]
    [ATTACH]n169352[/ATTACH]
    [ATTACH]n169353[/ATTACH]
    [ATTACH]n169354[/ATTACH]
    [ATTACH]n169355[/ATTACH]
    [ATTACH]n169356[/ATTACH]
  • PaulZ
    Originally posted by IHW View Post
    The tires have key marks on them and the wheel hubs have tabs or keys that slot into those marks on the inside of the tire. If they slip off the tabs on the hub, the tire will become "bumpy" and spin uneven looking. It's not easy to spin the tire on the rim by hand. But it can be done. Once you have them properly seated, I suppose you could glue them in place. Maybe some foam tac or E6000. I don't know, I haven't tried doing that yet. I've just stubbornly been fixing them when they slip. But I do agree. Rubber or rubber jacketed tires should be the norm on these 90mm and larger jets.
    Thank you - good advice. I rotated the tires and they "popped" into the grooves and are now round. This is a really bad design!
  • IHW
    Originally posted by PaulZ View Post
    Landing gear wheel tires: Have you all had problems with the tires on this model? They seem to be made out of some soft foam that deforms after a few landings. and then becomes "bumpy". This is not rubber like it should be. Any ideas what to use as replacement wheels?
  • downwindleg
    Thanks for that Tom. I actually already have some of those that I got from Keith some time ago. Not tall enough for the rudders or elevators but the right idea. I was hoping Steve or someone with that capability could come up with one tall enough to work in various applications on this plane.
  • Pogo
    Originally posted by downwindleg View Post
    Hey Steve, what do you think about styrene or other material for push rod exits for the rudders? Being that you are the creativity leader among us I thought I'd throw a challenge out there. If you look at the real plane, there is sort of a hood that covers the pushrod controlling the rudder. This is the most exposed surface on the airframe and an oportunity to "clean up" another control surface. What do you think?
    Brad, the trouble with that is the servo, rod etc. are at right angles to the control surface, as they need to be, but not to the airflow and so fairings, or blisters, would look goofy. The elevator servos, on the other hand, are crying out to be "faired", like the big 'uns, so I used some vac- formed shapes from :
    https://parkflyerplastics.com/cart/ Keith is a good guy and has all kinds of interesting stuff on his site. :Cool:
    Tom
  • PaulZ
