  • WintrSol
    Looks like you've got that airbrake mastered; great landing, BTW.
  • urrl
    Morning flights
    Excellent! Thankfully is was just an easy TX to RX technicality to correct. I'm glad it all worked out. Have fun on the maiden flight!
  • Jackrabbit416
    Okay. Years ago my mother called AAA because her car wouldn't start. The mechanic came by, and put the car in park -- engine started!
    Well...lesson learned here...BOTH SATELLITE ANTENNA NEED TO BE CONNECTED TO THE RECIEVER.
    Oye. Thanks for playing everyone
  • Jackrabbit416
    Thanks t-cat, that will be my next step (video of it all). You're right, sounding link a transmitter binding thing. For the record, the T-45 worked on first try and flies great.
    I'm also going to try binding to my dx8 and see if that does something.
    Thanks again for the time and help!
    Hmm, this is interesting. It certainly sounds like the receiver is not bound to the TX for whatever reason. The continually beeping ESC and servos stuck in a default position when powered on is usually the result that occurs. I'm assuming it's something with the TX (transmitter) since the same thing occurs with the F18, and the chance of having faulty components in both jets at the same time is rather slim.
    Are you using a new TX by chance with different receiver binding procedures?
    Hopefully we can help figure this out. Any videos of it all occurring and for us to see the way things are hooked up to the receiver and TX?
  • Jackrabbit416
    Thanks so much for the response guys. The UBEC is stock and indeed plugged into the receiver. Power is crankin -- LEDS are on and the flap servos are over extending and grinding. Even the nose gear light is on. I switched over to the AR9020 just in case. Same issue.
    Beep.....beep......beep....with no servo control
    Believe it or not I don't have a battery with a servo lead to isolate the power to the receiver and just try the servos on their own (will get today). I may have 25 years flying experience, but I'm a plug'n play moron :-)
    Crazy question. So power is split off right at the battery lead to the BEC. That goes to the receiver (and we can be fairly certain there are no power issues). Why then would a beeping ESC prevent the receiver from telling the servos what to do? As far as I can tell, the servos are home runs to the receiver (exception of the gear sequencing and LEDS).
    One more fun fact, I'm having the exact same issue with the Banana Hobby F18
  • urrl
    I might try the simplest things first, like bypassing the circuit board altogether and hooking up only the motor/ESC and perhaps a spare servo you have laying around. I think this would start you on the way.
    We'll start with the more obvious possible solutions first, and work our way to less obvious solutions because it may very well be a simple thing being accidentally overlooked.
    Do you have the external BEC servo lead plugged into the receiver whether that be Y-harnessed together with another channels servo lead, or in a separate channel by itself? This jet doesn't have an ESC with a built-in/internal BEC because an external one like the one used may provide better reliability when used at these 6S voltages. Therefore, the external BEC is powering the electronics and when not plugged in, you will not see any response to the servos, lights, gear, etc.
  • Jackrabbit416
    Hi guys. I just got my Eagle and I'm finding myself in an odd situation with my receiver and ESC (and servos for that matter). I have a feeling I'm just missing something stupid, but I'm stumped.
    DX9 Black
    AR9350 9 channel AS3X receiver
    Freewing 90mm F15 stock parts and servos
    I plug the servos into the correct positions on the receiver, plug in the battery lead. Bind it to the transmitter -- binds just fine. But then I simply hear from the ESC "Beep...<2 seconds>...beep...<2 seconds>...beep..." ongoing. Nothing works, not one servo. In fact, upon binding the first time the ailerons and rudders deflect full on direction and hold.
    I've looked around online for solutions and have tried the following with no success:
    1) Connecting battery to plane while transmitter on with full throttle, then reduce to idle.
    2) Reversing the throttle 'servo' on the transmitter
    3) Rearranging the order of turning things on
    4) Trimming the throttle idle all the way to its lowest setting
    5) Using a different AR9350 -- same issue
    Am I missing something? Has someone ever used this receiver/transmitter package with this aircraft?
    Thanks for any help!
  • Shirty
    Excellent job. :)
    Thanks guys :). Since I have been airbrushing lately, I figured I minds well go for a new paint job. I really like the look of the 2005 Tiger Meet of the Americas paint scheme. Now, that is only for the E-model, but I'm not going for any scale awards, so I made this C-model into that paint scheme.
    I used Createx water based airbrush paint in opaque black and opaque coral colors. There is also a couple costs of gloss Minwax Polycrylic clear spray on the jet. I forgot to take pictures of the sides of the aircraft because there are tiger stripes painted along the fuselage as well.
    I'm really pleased with the way it turned out.
  • Shirty
    Yep, plus 1 mate. The exhausts look awesome. Great job. :)
    Thanks Aros :). It's a fun and simple mod that'll look good while the jet is static and in pictures on fly-by's.
    Nice job T-Cat!
    Thanks Alpha. The F-15 has some of the best looking exhaust nozzles out of any jet. Very cool and unique!
    Those pictures Bajora... talented, you are, my friend!
    Nice nozzles, T-cat! Yes the white plastic was chosen by design instead of being painted black. I once climbed INSIDE an F-15's burner can on the flightline decades ago. I remember it being white with those dark areas, exactly as your picture shows.
    One thing I've wanted to do from the get-go was paint the inside of the exhaust nozzles to make it a bit more realistic. Having the plastic being white is perfect because all that's necessary is to make the black shading. It's easy as pie with an airbrush and a couple minutes time, as well as some water-based opaque black Createx color.
    Thanks Shirty :). I'll let you all know when I maiden the F14.
    Great pics Bajora!! Aros is right, those pictures look so real, and it is indeed an amazing time for foam RC aircraft.
    Wow. Is that the real thing or what?? What a glorious time to be in the hobby.
