Originally posted by Tom
View Post
Should we put Inrunners in all 90mm jets?
Originally posted by Ks.jetflyer View PostI would like to leave it as is, an option. Inrunners add cost as well as weight. I fly off a 300 ft. paved runway, so weight is a factor in landing speed. The current offering of outrnners give respectable speed imo. I also have to deal with a limited hobby budget.
But Tom also stated that The inrunner setup they were testing would be the same weight as the current outrunner setup. So there would not be a weight penalty. You would actually be a able to lighten the load with a smaller lighter battery for the same flight time.
So it would be better to just go with inrunners for everything because the additional cost would actually pay for its self because less batteries would be needed to fly for a certain period than before.
I quite honestly can't think of a good reason to even bother with outrunners anymore for EDF jets... :Confused:My YouTube RC videos:
Originally posted by Evoman View Post
Yea, but with inrunners being more efficient as in better flight times the additional weight is offset by being able to run a smaller lighter battery.
But Tom also stated that The inrunner setup they were testing would be the same weight as the current outrunner setup. So there would be not weight penalty. You would actually be a able to lighten the load with a smaller lighter battery for the same flight time.
Good points Ks.jetflyer...I think it's also a matter of efficiency as the inrunners are much more efficient motors and are ideal for these jets. One thing to consider - and please do not take this as a smart alec response as that is not my intent - is to use your throttle stick to manage your speed. I know folks who have even changed their throttle end points so their 100% power is actually 80% or so on. Just food for thought.My YouTube RC videos:
Absolutely, inrunner w/ 12 blade fan all day long. Its a great combination of efficiency, power & sound.
I’d gladly pay 20-30$ more for it ... better than the hassle of replacing outrunners with 180$ (minimum) i runner units ... do the right thing guys... it makes FULL sense to go inrunner on 90mm jets.
and now that i’m thinking about it can you please also BRING back lights (nav, landing, exhaust) on 90mm jets ... if its was possible w/ older 90mm jets like f16 then i’m hoping it wont break the bank on the new ones.
Instead of 20-30$ increase for inrunners only make it a 30-40$ but with lights.. plzzz!!!
Originally posted by Luqman Khan View Postand now that i’m thinking about it can you please also BRING back lights (nav, landing, exhaust) on 90mm jets ... if its was possible w/ older 90mm jets like f16 then i’m hoping it wont break the bank on the new ones.
Originally posted by Luqman Khan View PostAbsolutely, inrunner w/ 12 blade fan all day long. Its a great combination of efficiency, power & sound.
Some other considerations:
Inrunners are heavier.
Inrunners motors are difficult, if not impossible, to balance. Outrunners can be balanced (counterweighted) since the rotor is on the outside. This is separate from balancing the fan blades.
The "afterburner" LED units that seem all the rage these days cannot be mounted on outrunners.
Originally posted by RCjetdude View PostTom has stated earlier that the particular inrunners they are looking at are no heavier than the outrunners.
I am sure these particular inrunners will be shipped completely balanced, and as for the Centerburner, I am quite sure there will be a fix for that.
IN runners can be balanced and typically come better balanced than out runners. Out runners have more mass away from the center of rotation making it more critical. The 90mm out runners that Freewing currently use have fan shrouds that have a rear cone on them so you can do the fan mounted AB lights on them too.
Typically the in runner is heavier, but the in runner is also typically more powerful, even though Tom says the ones they are looking at are similar in weight.
Originally posted by Ron1950 View PostI guess I really don't know how I feel about inrunners in the new jets...I want them yes but cost is slightly up and I live in one of the states that makes the shippers collect state income tax on all internet products so I get it coming and going...but yes give me the power lol
I believe the Powers That Be are still mulling it over but I would think it's headed in the right direction.My YouTube RC videos:
Aren't the in-runners brushed motors? For the same size you might get higher KV but lower torque. So you end up with a heavier brushed motor doing the work of a similar, lighter, out-runner.
Granted, it will do that work at higher KV. But I don't see the reason to go heavier and a little faster.
At our club, we jet guys have to blast our way out of a hay field. I will always trade heavier/faster for lighter/more static thrust. Plus the current 1650KV motor in the T-45 pushes that airframe to it's limit.
I cannot understand why you would want more speed and more weight in something like that.
So my personal opinion, which pretty much goes against the grain, is it's not worth the extra cost and loss of static thrust. At least not to me. So I hope Motion continues to offer an out-runner option.Meridian Aeromodelers, Meridian MS
