I am so far from an expert I can't even see the "E" but I offer this for what it is worth since they are similar airframes. Like you, I am running 2 LiFe batts for my Rx in the CGRC (Spektrum 2310 Powersafe 12 ch.) but also running a separate 7.4V batt for the landing gear which are older model Century Jet (R.I.P.). Not sure what D&L requires for power? I found I needed the extra nose weight anyway so it is not a burden. Bottom line is I have 7 batteries total to get the pig airborne.
I charge those LiFe at 1c as I do all of my LiPo's for my other planes, unless I am really in a hurry. Then I charge at 1.1. Ha ha. IMHO, there is just no need to force feed the battery any harder. The time savings of a few minutes of my day charging at 2.0 C for example, is not worth the overall risk. With a couple packs in rotation, by the time I am ready to fly again, so are the batteries if that makes sense. I store the LiFe's at or at least "government work close enough" to the 3.3V that OV10 showed above.
As far as charging, my main charger now is a 1000W PowerLab 6 Touch. This thing can tie my shoes and make me coffee and it probably has features I don't even know about yet but I like the battery parameter history and the different geeky charge details it records, even if I don't know what they mean. It also has a Bluetooth connection to an app on my phone that says "...Hey idiot, your batteries are done..." I use it with a parallel board and can charge 4 batts at once but normally only charge 2 at a time so I don't tax the solar system at our field. 2 6S 5000's at a normal "fill up" takes 30 minutes or less - about the time the pizza arrives. I don't use the RFID "bump tags" the charger comes with. Honestly, they are really cool but the total time savings is about 7 seconds since the batteries are stored in the charger memory. A couple button presses and you are off.
Hope that helps. PS. My A-10 obsession probably requires professional help. I forced (sic) myself to buy a T-33 and also have a F-100 "Hun" on order so I could make myself feel normal.
Cheers.
Inquiring minds and all...Here is one of many explanations that are out there:
