North Texas, sounds like a nice place to live. Here...😖
Yikes! Texas is nice about 2-3 months a year (I’m not originally from here). 21C now, but average 35-40 C everyday from April-September :hot_face:. Quite fond of Sweden. My family heritage is from there and some still live in Eksjö. I have been fortunate enough to visit them a few times.Comment
Yeah, 104° at my house today on the east side of town. Summer is not releasing it's grip on us yet. Either that, or whatever God's been cooking here isn't done yet.
PatComment
Who are you asking? Representatives of Motion RC has never posted anything specific on any new plane's arrival date. I've never seen any of them say, "the container is travelling to us at this moment and we will start sending them out on XX month and XX date". What you see on the product webpage is what we all get - "Late October". If you're asking the rest of us, noone knows. The first sign of something happening is when the first buyer gets his "shipping notice". An "idea"? OK, between now and Oct. 31 for N. America.Comment
Hi folks,
coming back to the wiring and gyro question. I think best is to use the canards first only with elevator and not with aileron .
The gyro is not connected to the canards. You do your elevon mixing in the gyro, but the canards connect directly to the receiver. The canards receive their signal over elevator mixing to Aux2 and Aux3 in the transmitter. Rudder, Aileron and Elevator go into the gyro, where the elevon mixing happens.
In total you only need one 8 channel receiver and 1 gyro.
In that way the canards are not bothered by the gyro.
Folks, it is open for discussion. An advanced pilot probably wants the canards with Aileron, but not me.Comment
If you don't want the canards as "elevons" and just act in consort with ELE, then you can either "Y" them (might need one servo reverser) and do a single mix or have them separate into their own channels, then do 2 mixes so they act like ELE. The option with the "Y" would need 6 channels. The other option would need 7.Hi folks,
If you only want the gyro on the elevons, then set TX to "normal" wing/tail. Set gyro for elevon. Since you're mixing for the canards, the gyro shouldn't affect them.Comment
Sounds good.Hi folks,
Don't consider pitch only canards a downgrade or inferior solution though - in fact it is the very opposite. Using canards for roll as well is purely a marketing gimmick and far from ideal aerodynamically anyway.
As for gyro, having the operate canards too would clearly be ideal, but I'm sure your stabilized elevon, unstabilized canard setup will work just fine. Just make sure you never have any sort of mode where you remove pitch input to the elevons (since that would make your gyro fight the pitch changes you command through the canards)Freewing A-10 turbine conversion: http://fb.me/FreewingA10TurbineConversionComment
Yes of course in the transmitter “Normal wing” setup and only in the gyro “Elevon mixing”.
This idea probably only works well , if you use the canards purely coupled with elevator. If you leave the canards neutral on aileron input , your plane will stay more stable. Probably not what an advanced pilot wants. For my flying skills it would be sufficient.
The canards on elevator is important for take off .
The gyro reacts on wind disturbance. The canards would stay neutral. It will feel like less gyro gain. But it should work. People are using this setup in our club.
In fact, it should be exactly what any pilot wants.
Absolutely no canarded fighter I have ever seen uses canards actively to produce roll rate. And there are good reasons for that.
First and foremost, canards are there to improve airflow over the main wing, especially at higher levels of alpha. Significant canard roll deflections directly goes against that purpose.
Secondly, it is not hard at all to get more than enough roll authority from elevons (or tailerons in the case of non-delta canarded platforms such as the SU-27 family). Even at very slow, very high alpha flight, roll authority is never really a problem. What does at some point become a challenge is yaw authority, but that is a different discussion altogether.
In short, canards do their job far better if left alone to do just that and not a whole lot more.
