The RCINFORMER FREEWING F-14 Thread for any and all Q&A on the Freewing F-14 TOMCAT
  • RCINFORMER
    • Dec 2013
    • 13
    Hey Folks, I am trying to Get out all the information on the Freewing F-14 that I have included in my videos and circulated around, for folks that would like to ask questions and get help on this epic model. I have put in a lot of effort on this model and wanted to share everything about it and some of the improvements I have made to it. I have made many Improvements to the model that many may have already seen. I wanted to create a place where folks can ask questions and get help:)
    Here are the videos I have created so far:
    Unboxing► https://www.youtube.com/watch?v=Bnygfe48tXs
    Assembly► https://www.youtube.com/watch?v=77Ue4We-B5s
    1st Flight► https://www.youtube.com/watch?v=eNjviFTK1Tg
    2nd Flight► https://www.youtube.com/watch?v=hko89Pb_QDc
    3rd Flight► https://www.youtube.com/watch?v=UPxCnz24bW0
    SEFF 2019 demo 1► https://www.youtube.com/watch?v=Lb6py2gS1OU
    SEFF 2019 demo 2► https://www.youtube.com/watch?v=OGZPct9EkeE
    SEFF 2019 NOON demo► https://www.youtube.com/watch?v=bXo5IpU7_gk
    UPGRADES VIDEO► https://www.youtube.com/watch?v=M1gcECZESg8
    Gooniacs centerburner flight at NIF 2019► https://www.youtube.com/watch?v=dMFdEQN-KMo
    Gooniacs centerburner Installation► https://www.youtube.com/watch?v=h93UcHBkKaE
    Wing Platter Upgrade video► https://www.youtube.com/watch?v=Ud6EOxgaefg
    There's a lot of great information here all in one place, I'm sure it will help many. Thanks for posting and sharing it, Rich!
    • RCINFORMER
      • Dec 2013
      • 13
      I know its only 12 videos and one squawk... Its not for the lack of trying:)
      • Johnnyrabuse
        winner wolf
        • Apr 2020
        • 136
        • NY
        On mine I fly tailerons only for both swept and extended wings
        On wings extended I use 100 percent throw tailerons with regular flaps half is 50 percent full is 100 with some up elevator mix
        Wings swept I use 65 percent tailerons
        I use flight mode one and two one trims wings extended two trims wings swept
        It really simplifies things and in both configurations it flys easy
        Lands easier
        I don't use the board except for lights flaps and gear
        I like the scale performance without aerolines
        I don't use full span flaps
        I was going to use a 9 channel radio but HH botched my order delivered it to whereabouts unknown and doesn't reply to my email nor answer the phone
        So I'm using an 8 channel receiver and shut off the aerolines via travel adjustment I might pull the servos and set them as fixed or convert to full span flaps and cement then to the existing flaps
        Hope this helps
        P.s Rich Bakers videos on this jet are very detailed his modification is advanced in my case I went with really simple since I'm old and slow
        • Johnnyrabuse
          winner wolf
          • Apr 2020
          • 136
          • NY
          Thanks so much for creating the two new jets the mig andband has 39 of which I'm really looking forward to tinkering with keep up the good work
          If you create a B 58 hustler my wife will divorce me
            • 8766
            I've viewed all of your videos on this plane along with RC Geek's vids. They have been very helpful.
            I'm in the process of the F--14 build. Just finished the retract mount reinforcements. My question is in regards to installing a gyro. I've seen RC Geek touch upon it but noone has actually given any specific details on the set up. I don't mean where to physically place it but rather, where in the electronics path is it placed? Between the RX and control box or between the control box and the servos? Do the servos need to be plugged in differently (different ports)? Does it only affect the tailerons? Settings on the TX (eg. wing type)? Settings in the gyro (wing type)? I'd like to use a HobbyEagle A3-L. I'm familiar with using the A3-L in many planes but this one has a slightly higher level of complexity as far as the gyro is concerned.
            • RCINFORMER
              • Dec 2013
              • 13
              Did you use the lower wing plates from Dustin?
              Regarding the Gyro/Stabilizer.... do not have one in my F-14, I fly it without any stabilization of any kind. it flys that great!
              The only Stabilizers I have are the ones that are already installed in E-flight models & already set up... However, I will probably be setting up one soon in a new model, so stay tuned to the RCINFORMER YouTube Channel.
                • 8766
                No, after watching your videos, I did my own mod for the retracts using the philosophy you pointed out about the weak areas.
                • RCINFORMER
                  • Dec 2013
                  • 13
                  show me a picture....
                    • 8766
                    A picture of the reinforcement on the mains won't show anything as it's already covered. I basically embedded a 1/4" square CF solid rod (about 6" to 7" long) into a carved out trough (about 1/2" deep) using epoxy to glue the rod in and fill in the trough. The rod end slides under the lip of the retract mount box and extends aft of the box. Since any force on the main retract acts as a lever in that direction, the end of the rod gives that end some support and makes that whole foam area very rigid. Since it's on the underside, it's not visible either on the ground or whizzing by in the air. It's not nearly as strong as that single heavy duty metal plate your friend made, but I'm hoping I won't nail the thing into the ground too hard too many times.
                    Then there's the nose retract. I used your idea to help support the load on the retract in the way the force would push it. I took a slightly different approach. The picture attached shows a metal band that I installed over the long section of the retract as it makes for a better lever to counter the load placed on it in a hard landing. That thin metal band goes through the foam on both sides of the retract tubular section and into the interior of the nose as seen from the top. The band overlaps itself and is secured with a screw in case it needs to be removed for replacement of the retract. I've also epoxied a block of wood at the end of the stock strut brace. That whole section where the wood block is, is filled with epoxy to make for a bigger "backstop". It acts somewhat like one of those 3D printed strut braces that people have made for their front retracts on A-10's and Avanti S.
                    Your mods are way more sturdy and attractive but I did what I could with what I had on hand.
ID:	271493Click image for larger version
                    • mshagg
                      • 541
                      • South Australia
                      As with all aspects of this plane, there are many ways to skin this particular cat. And it will depend on how you plan on configuring the surfaces.
                      If you plan on setting the jet up as freewing intended - i.e. tailerons and wing ailerons active all of the time, then you must configure the gyro as a 'regular' plane (seperate aileron and elevators) and use the mixing board.
                      If you plan on disabling the wing ailerons with the wings swept back, then you need to make some decisions. I would start with the premise that - it's going to be difficult getting gyro stabilisation on the wing ailerons if you want them disabled on wing sweep.
                      My set up is based on RCGeek's tune - primary control from tailerons, with trailing-edge-up-only wing ailerons (only with wings extended) and full span flaps. For this, I am still using the freewing mixing board - the gyro and tx are configured as a 'regular' plane and the tailerons have stabilised pitch/roll. The wing ailerons go straight to the receiver (actually two receivers - things got complicated lol) and are not gyro stabilised. Having the gyro working on tailerons only is enough to stabilised the plane. You could achieve a very similar result running the tailerons direct to the gyro, but you'd have to make sure it was configured with delta mixing. For most gyro/rx systems that have this feature, the radio is stil configured as a regular (seperate ail/ele channels) plane.
                      Happpy to dive into it in any more detail if you like, she is still in one piece and flying perfectly. For a radio programming geek this thing is a dream - logic conditions and all sorts of mixing going on lol.
                      Rich - if I may - your vidoes on the F-14 were invaluable. I went down a 3D printed path for both the battery tray mods and various gear reinforcements, but your detailed analysis of the plane could not have been more helpful. I also find your content well researched, clearly presented and above all - entertaining. Thank you for all of the work you put in to the channel.
                      While we're swapping war stories from the grass operations theatre, here's some pics of how the various mods ended up. The external elements look much better post paint/weathering i promise lol. There's been some inadvertent stress testing and it's holding up beautifully.
                      Click image for larger version  Name:	20200728_221625.jpg Views:	0 Size:	84.7 KB ID:	271511Click image for larger version  Name:	20200805_174833.jpg Views:	0 Size:	164.7 KB ID:	271512Click image for larger version  Name:	20200726_205208.jpg Views:	0 Size:	77.4 KB ID:	271513Click image for larger version  Name:	20200726_210059.jpg Views:	0 Size:	49.1 KB ID:	271514Click image for larger version  Name:	20200807_173142.jpg Views:	0 Size:	69.4 KB ID:	271515Click image for larger version  Name:	20200801_162013.jpg Views:	0 Size:	103.9 KB ID:	271516
                        • 8766
                        I would love to discuss more details and clarification about the gyro thing but this topic may be outside of the scope for which Rich intended for this thread. Perhaps I could message you in the future when I get to the point of installing a gyro?
                        BTW, I really like your strut brace but lacking a 3D printer and the skill to use one, I went another route. Same for your nose brace.
                        • mshagg
                          • 541
                          • South Australia
                          Yes I think it would be appropriate to pick it up elsewhere. Can chat in the main thread but feel free to send a PM.
                          • RCINFORMER
                            • Dec 2013
                            • 13
                            I like the nose wheel brace. I have found 3D printed items to be a bit brittle... All good ideas!
                            • e4dragongunner
                              Living the dream!
                              • 876
                              • Arlington Heights Il.
                              Hey Guys
                              My F-14 ARF Arrives tomorrow. Reinforcement Kit ordered from Dustin Holloman, Great guy!
                              Undecided on power at this point.
                              A10 Setups ?
                              T-33 Fans with A10 ESC's ?
                              FMS 2100's ?
                              And undecided on Center burners
                              I have a few lite burner modules
                              But Gooniac and RCGEEK also are contenders.
                              Control surface setup still up in the air.
                              I fly Jeti and will be utilizing a REX12 Assist receiver (Gyro Equipped ) and a MUI telemetry module to measure battery capacity in flight. Have these in all my Jets :-)
                              And yes! GREAT vids Rich. Appreciate all the wonderful work you did and continue to do!
                              • e4dragongunner
                                Living the dream!
                                • 876
                                Reinforcement kit has arrived!
                                • Mizer67
                                  • 374
                                  How did you order the reinforcements?
                                  • e4dragongunner
                                    Living the dream!
                                    • 876
                                    PayPal Dustin Holloman 111.00 and it arrives :-)
                                    • Flyingace123
                                      • Apr 2019
                                      • 5
                                      • Huntersville, NC
                                      Is there a spot here that explains the programming for disconnecting flaps when in swept wing position-I have an 8 channel spektrum with DX9
                                      • balsadust
                                        • Jul 2022
                                        • 6
                                        Does Dustin still make the reinforcement kits? Where can I purchase it?
                                        thanks
                                        -Matt
