Bylaws, beautiful work on your PJ50. What color blue did you use? TIA!
R
All-New Freewing PJ50 Twin 70mm EDF Jet - Official Thread
Reposting….edits would not save for some reason.
Good deal and I have my gyro set at roughly 60% as judged by the adjustment pot on top.
First…Set the aileron throws by the book. After that is done, then adjust each aileron up 5 mm as measured at the trailing edge. You are done.
Initial flights on low rate, but eventually you will settle on high rate as the default. High rate is better for aerobatics and windy days.
Thanks! I have a gyro installed and it's set up per the manual. You're saying adjust the linkages so the ailerons are 5 mm up like the manual suggests for the elevators?Originally posted by GliderGuy View Post
Nicely done! She’s my favorite bird, BUT ONLY after I put a gyro in her.
Any wind/gust will set up a Dutch roll on final….making landing a challenge. The gyro stops this.
Also, adjust each aileron 5 mm up when the stick is neutral. This helps reduce the tip stall.
Have fun!
PS - If you heed this advice, you will love the PJ-50! If you ignore the advice….well DON’T ignore it.
Would you adjust the aileron throws after that or leave them at whatever they are after the 5 mm up?
Nicely done! She’s my favorite bird, BUT ONLY after I put a gyro in her.Originally posted by bylawes View PostPJ-50 turned into C-20G with the help of Callie Graphics.
Haven't had it in the air yet, hoping if flies as good as it looks.
Have fun!
Haven't had it in the air yet, hoping if flies as good as it looks.3 Photos
For the PJ50…The best advice is PUT A GYRO IN IT!”Originally posted by f4u ausie View PostJust about ready 4 my maiden waiting 4 callie and dryer weather,,, my 6000 hrb r here hoping 4 some f.ying info,,,, hav watched amost all u tube vids( seen 2 tip stalls) wanto avoid that,, so i have mixed a small amount of rudder with aileron..( hoping thinking that will help... keep up the speed...... looking 4orward to some advice
Start with 60% gain. Without a gyro, she gets to Dutch Rolling on final in much wind/gusts and can be a challenge.
I wouldn’t suggest a rudder/aileron mix.
To minimize tip stall, set each aileron up 5 mm from the streamlined alignment.
Have fun!
Reference post 497 above…about the top of the wing. Now, for the bottom of the wing.
I noticed where the bottom wing section pieces fit together within about 6 inches of the fuselage the sections were beginning to develop a case of the “spread apart itis” under a positive G load.
So I added several mini carbon sheet spars all along the wing piece joints to stop the spreading under load. I added 6 mini spars sunk into the foam skin from near the leading edge back to near the flap. Did this to both wings.
See drawing below.
I flew her this morning and had to make a little aileron trim adjustment. Apparently the wing had been slightly twisting under load. She’s tight now and solid. Filled, sanded, painted…can’t see them.
Eventually, I am going to wear this bird out. She’s my all around favorite EDF, so she gets a ton of stressful fast and aerobatic flying which is wearing on her. And all this flying, only one aileron servo has needed replacement. Truly amazing for these tiny servo motors.
Hi Nick….
Somewhat of a subjective question and depends upon pilot skill level.
First, plan on buying a gyro with the bird. Before I installed a gyro, I was about ready to stop flying her. Any gust on landing can start a Dutch roll action that makes landings DIFFICULT. After I installed a gyro, she is a tamed animal. EASY to land.
Second, adjust aileron linkages to raise each aileron up so that with neutral stick, each aileron is about 5 mm up. This helps kill the Dutch roll as well because it reduces the tip stall.
My experience level would be classified as HIGH, so take this into consideration. I have over 1000 flights on the PJ-50…..no kidding! The below is stated from a COME IN COMFORTABLY…not on the hairy edge of a stall.
For short fields…which is probably why you are asking your question: She is a floater…low drag bird. She will glide FOREVER if you are fast on approach. You gotta be prepared to kill the power very early on base leg, or come in very low. Even with full flaps….and do plan on using full flaps for short fields. WITH A GYRO and 60% gain,!she has no bad flight characteristics at slow speed. It is possible to land slow. But, if you operate on hard pavement, give yourself 250+ feet to land and stop in a zero wind condition. If your hard runway is wide enough to make a wide J turn as she slows down, you can get by with 150 ft to land and slow down plus another 100 ft of roll to do the wide J turn at the end. I measured where I fly via Google Earth for these numbers.
She flies well in STRONG wind conditions WITH THE GYRO. In a good wind, you can get her stopped much shorter.
As with any slow flying bird, a stall and fall is always a concern. Your skill level will determine “how slow you can go”.
WITH A GYRO, she is my all-around favorite bird to fly in all types of wind and turbulence conditions.
Without a gyro, I was ready to hang her from the ceiling as a display-only bird. Especially in windy/turbulent flying conditions. Calmer days = Just fine without a gyro….but only on calmer no gust days.
Take-offs are VERY short. She has a TON of power, accelerates fast and with 1/2 flap is airborne after a very short run.
Slow flight with gear down and 1/2 flaps…nice and stable WITH A GYRO!
I am planning on purchasing this jet. I am fine with fast flight, but does anybody know if this jet can takeoff and fly and somewhat slow speeds? If so, how slow? Thanks!
Update to my post 491….almost 2 months later and several hundred more PJ-50 flights.
The Bondic held up, but the amount of flexing the wings still do caused the paint to crack. UGH and UGLY! The crack in both wing tops is about 1/4 the way to the tip and both cracks run chord-wise….almost from leading to trailing edge.
Back to the drawing board.
This time I Dremeled out the cracked paint and then Dremeled in span-wise trenches 90 degrees to the crack. Then I epoxied in some mini spars/stiffeners made from a carbon fiber sheet.
Filled, sanded, painted. Looks like new. The stiffness and resistance to flexing is vastly superior than to the Bondic-only prior repair attempt.
I’m betting the top wing paint won’t crack again. Not in this area, anyway.
The following visually depict the above and show the final results before I overcoat with polyurethane.
When I wear this bird out, the next PJ-50 will get an additional carbon fiber spar glued to the inside of the top skin like my AL37. That’s a real solution.
The designers of the PJ-50 weren’t counting on a thousand or more flights done with aerobatic flying.
SUCCESS!!! The Bondic UV-cure glue repair of the wing’s top skin, foam cell boundary stress cracks passed test # 1 (see my earlier post above).
Made 10 flights and didn’t baby her. Aerobatics and high speed flying. Neither the left or right wing’s cracks opened back up.
Time and more flights will tell, but the initial results look VERY promising!
Yepper, even if my estimate is 50% too great, that still speaks well for the PJ-50 wing design. Most folks will get years of flying before the cracks appear.
Noteworthy, I don’t baby her. She’s flown fast and with loops, inverted, snap rolls and spins (sorta…not a great spin bird). Also, she’s my go-to “windy day” bird, so lots of fast flying thru rough/gusty air that makes the wings flex. Windy day bird = only after a gyro was installed.
Also, this is a stock wing. No mods or internal reinforcement done.
Holy Moly, GG! 1000 flights! My most flown planes are my sailplanes and I might get 60 flights a year on any single one of them (I have 3, about to be reduced to 2). My other planes, even my favorites ones, might get 30 flights in a whole season. My least favorites one, even though I still like them, might get 4.
Estimated….around 1000 flights
Received in early 2022
Here’s the math / probably very close to reality, but it is ONLY an estimate based on my flying habit
365 days x 0.7 days flown = 256 days
30% of those days were PJ-50 flight days = 77 days flown
When flown = 10 flights minimum (often 20 flights)
So 77 x 10 = 770 flights
77 x 20 = 1540 flights
1000 flights won’t miss it too far. 😃 Only recently started to show the top skin cracks. I am impressed by this wing!
Your AL had many hundreds of flights. How many on the PJ before the wing cracks showed?Originally posted by GliderGuy View PostThe PJ-50’s wings are just now showing stress cracks on the wing top skin after a lot of flying + aerobatics. The PJ-50 wings resisted cracking far longer than the AL-37 wings (which have the added stress of the nacelles).
Always looking for “better ways” to do cosmetic repairs….especially foam cell boundary cracks in areas under stress.
I’ve tried, without great success, in the past to use various fillers, but the cracks return.
So…trying a new approach and experimenting with UV curing glue = Bondic.
1) Cut along the crack to widen it a bit…1 mm or so and almost down through the top skin thickness
2) Filled the crack less than full with Bondic and cured it with UV light
3) Finished filling the crack to level with the top of the skin with another layer of Bondic and cured it
4) Sanded smooth, painted, then added a coat of Minwax One Coat Polyurethane UV protectant
Now to see how this fix holds up. The Bondic bonds very strong to the foam. We’ll see after more flying + aerobatics.
