Originally posted by leithalweapon
View Post
Official Black Horse Viper Jet MKII 120mm EDF Discussion Thread
The struts that come with the kit are not the 5mm struts are indicated in the description or on the plans. They are 10mm male shaft struts, which makes them almost impossible to use. The kit also does not come with the thrust tube, which I think is really strange. I think the easiest thing is to replace the struts with something that will fit on 5mm retracts. very disappointing.
These retracts have a 10mm pin and are a perfect fit. The mounting holes line up and they seem well made. The connecting pin on the stock struts is painted. In order to get it to fit in the retract I had to remove the paint with stripper. Also the retract has to be taken apart to remove the pin it came with.
This retract fits the stock front strut after the paint is removed from the connecting pin. I just need a screw to put in the trunion to retain the strut and allow it to rotate.
US $42.72 5%OFF | All Metal Nose Landing Gears/ E- Retracts 050 with W/ Block Axle Shaft Steering For Giant RC Plane
Originally posted by Mud Duck View PostWe’re using Hitec HS-645MG’s on everything.
Originally posted by bigd5963 View Post
Okay, I have not started building mine yet. Someone said the standard servo would not fit and had to use mini servo's in the elevator and rudder. Thanks for letting me know! I see people are buying the lights from Dave's RC Electronics. Do you know which ones or are they all the same? Getting ready to buy everything I need for the build. Thanks!
Finished with Minwax Polycrylic spray. It runs easily so have a brush ready to smooth out the drips as soon as possible. if you miss some and they dry( like me). Wait a few days for it to harden and then carefully shave off the drips with a razor blade. I will either put a sticker over it or very carefully hand rub it. The coats of poly applied don't bond with each other so be careful not to sand through the last coat if your going to use sand paper. If you do it will leave an eye shaped mark that you will see.
Oh Geez! Honestly we’re still building ours too. We bought the servos on the recommendation of Motion R/C; I sure hope the whitecaps fit without having to do a bunch of modifying, I’ll have to check.
As for the lights from Dave’s R/C electronics we’re using his 8mm lighting system in a custom configuration
Leithalweapon are you really happy with the results of the Minwax Polycrylic? I have been on the fence - actually I sided with NOT doing it at all for fear of getting runs or uneven spray and ruining the already nice finish. We test sprayed the ventral fins on the bottom and I have to admit they turned out better than I expected in the end, but those are small parts compared to the size (and visibility) of the fuselage.
Originally posted by Mud Duck View PostOh Geez! Honestly we’re still building ours too. We bought the servos on the recommendation of Motion R/C; I sure hope the whitecaps fit without having to do a bunch of modifying, I’ll have to check.
My advice, if you can get a paint gun and a compressor and then buy the brush on polycrylic and thin it as recommended. You can mix it a tad thicker and maybe still get a good finish.
The plane looks a thousands times better with clear on it.
We have finished the clear coat and it does look better; consistent finish makes it look nice instead of having one party gloss and another flat.
So now we’re trying to locate servos that will work at the size shown in the manual which is;
Servos size: (32.3x16.8×31) mm.
Has anyone found good quality servos in this size? Thanks for your recommendations.
What's everybody doing with the intake ducting? I think I'm going to either completely eliminate it or just use enough to cover the first couple of formers on the interior side of the fuselage. Seems pretty flimsy though.
Also is anyone using the two small intake ducts on each side of the fuselage?
I was actually wondering when did they start including the retracts in the kit? I purchased one in Oct - Nov time frame but I didnt completely take everything out of the box yet so im not sure if I should expect a set or not. I opened it to make sure none of the major parts were damaged in shipping but was planning on waiting until spring to start putting it together.
