No function
  • ddillon@barnhartcrane.com
    • Jun 2023
    • 7
    No function
    F 14 twin 80 mm has power and green light on reciever but I have no function. Tk6 transmitter and 8 channel receiver. Lights come on and plane just beeps. Battery’s full charge. New to this but followed book by directions. What do I need to do to fix this?
    • 5426
    BEC plugged into your receiver?
    • jasmith41
      EDF-obsessed
      • Sep 2021
      • 317
      • AZ and NE Ohio
      Every time that's happened to me it was either because my throttle trim and sub-trim weren't turned all the way down or i'd over-shot the ESC calibration and it went into the next mode before i could throw the throttle stick back down...
      I'm guessing it may be your trims though...
      New to this too, so Evan D is probably a much better resource...
      • jasmith41
        EDF-obsessed
        • Sep 2021
        • 317
        • AZ and NE Ohio
        Also, that's a tough bird to fly. If you're new to EDFs, you may want to start with something much smaller and cheaper... and whatever you do, don't swing the wings back until you're 120% sure you have the trims right. I watched a friend of mine who's been flying for 30 years put 2 into the ground within a week of each other last year due to these issues...
          • Jun 2023
          • 7
          What is bec plugged everything from E05 to receiver and everything frof plan to E05
            • 5426
            The ESCs have two battery connectors, probably EC5 and three connectors that look like servo connectors. Two have three wires and they are the throttle and get Y'ed into your receiver throttle channel. One has only two wires, red and black, this is the BEC power lead and is what powers you receiver, servos and retract and gives your motor the signal for throttle (through the receiver). You plug this into a spare receiver port or even on an appropriate slot of the E05. See attached drawing.
              • Jun 2023
              • 7
              Will check this evening after work
                • Jun 2023
                • 7
                  • Jun 2023
                  • 7
                  The bec is plugged up and both batteries plugged up it has a red light on but reciever has green light. No matter which way the on off switch is in the lights and beeping come on all of the e05 was either plugged up by motion rc or it was labeled by them
                    • 5426
                    Maybe a second set of eyes? Where are you located?
                    if not maybe posting a lot of detailed pictures
                      • Jun 2023
                      • 7
                      Turned all plugs over 180 and almost all functions
                        • Jun 2023
                        • 7
                        Don’t have the front steer on landing gear or alieons
