Official Freewing 80mm F-22 Raptor EDF Jet Thread
  • Wizardofpawgs69
    I’m having trouble with my 70mm Freewing F22. I cannot get the blue bridge lite device to power up from the Freewing 6 axis gyro. I can plug the blue bridge up from a different power source and it will turn on and I can connect my phone to the blue bridge. The gyro does power on and does work on auto leveling however I can not fine tune the gyro or adjust it due to power up issues with the usb c cable from the gyro. Have any of you gentleman ran into this issue?
  • Blackdog
    Ty
  • Gopher
    Originally posted by Blackdog
    After yesterday went to workshop to switch left elevator servo hooked up spare servo switch on radio then battery noticed flap on half way now it works great go fig still got fault in elevator servo
    I have made a cheat sheet to setup a new aircraft.. See step 17 about setting up flaps on my NX8 transmitter. Hope this helps.
    Blackdog,
    I have 2 complaints from Members In Good Standing against you this morning.
    Both relate to a deleted post of yours and both calling that post "Vulgar".
    If you want to use this forum, then you must be understandable and polite in doing so.
    This is a warning, any more complaints and you will be removed from the forums permanently.
    Respectfully,
    LB
    It's really hard to help you when nobody can understand you. See ya!
    :rolling_eyes:
  • Blackdog
    I try my best to deal with a abi
  • Blackdog
    Good bye
    I think some punctuation and better sentence structure would be very helpful for those reading to understand what the heck you are experiencing and doing.
    EG. You switched left ELE servo .......................... switched to/for what?????
    Hooked up spare servo switch on radio .................... what does this mean???? What is a "spare servo switch on radio"????
    "then battery" .................. HUH??????????????????????
    I don’t understand. You never mentioned a elevator issue.
  • Blackdog
    Not this plane. The MCBe is just a Y to the ribbon cables. No circuitry involved.
    This may be a possibility. Some planes with these "control boxes" will not allow for slow flap deployment if the time is set for more than 1 to 1.5 seconds.
    Antholy has said the JST is for their new AB module. Obviously it can also be used for other things.
    This connector is a great idea. In older planes, I'd have to solder the BEC leads into the power wires. This makes it so much easier when an external BEC is preferred or when OPTO ESCs are used.
    Have double checked wing type that is what I thought to just don’t know flaps still work just can’t adjust or slow them I think blue box is problem I have done this before had no problems Ty for reply
    The MCBe is just a pass through for flaps. The TX tells the RX what to do. The 8360 can have programming in it that could effect the operation of things but I doubt it is doing anything for your flaps. Then, if you have everything wired correctly, the RX sends the flap signal to the MCBe which sends the signal out through the "ribbon cables" to the wing connector. On the back of the wing connector are plugs and the flap servo plugs into one of those.
    In my opinion the flaps not slowing has to be in the TX. The one flaps servo could be a loose connection behind the wing connector, either end of the ribbon connector not seated properly, a bad MCBe or a bad servo. Easiest way to find out is to unscrew the wing connector and plug a spare servo in it (or swap the aileron and flap plugs).
    I have had well over a hundred FW planes and have had I think 3 servos go bad, one had no solder on an internal lead. I have never had a bad MCBe. The most common reason for others having a bad MCBe is powering their receiver with a non stock BEC or separate battery providing more than the maximum 5.5V it's rated at. Are you running yours stock?
    I just purchased a set of twin ESCs from RC Castle. On the power lead (Y'd together from the 2 ESCs) was this very same red connector. Plugged into it was an external BEC. You can see it here:
     - Suitable For FMS SU-27 & Other Twin 70mm EDF Jet.- Extremely low internal resistance.- Super smooth and accurate throttle linearity.- Size: 86 x 38 x 12mm ( Lx W x H )- Continuous current: 80A x 2- Peak current(10s): 90A x 2- Battery: 2 - 6 Lipo / 5-18 NC-
    The "center burners" I usually get are plugged into the balance lead of the battery, and generally tap into only 3 or 4 of the cells. "Afterburners" (ring type) can be plugged into that lead as they can take higher voltage.
  • Blackdog
    Removed stock gyro got everything thing working but flaps they work on switch but can’t adjust or slow them down running nx8 with 8360
    When this happens, it's usually because you did not declare in "wing type" ---- "1 AIL, 1 FLAP". Once you do this, it opens up the flap menu where you can then select elevator compensation if desired and deployment time and confirm which switch you wish to use. It is also in this menu that you can dial in how much flap deflection you want for each position (no flap, take off flap, landing flap).
    PS, the stock gyro has no relevance to the flap function.
    Click image for larger version  Name:	IMG_1873 (1).jpg Views:	0 Size:	66.5 KB ID:	433224 My friend has bought this 80 f22. And he is not sure about a wire.. it's a negative and positive. Around 1 mm in diameter. At the ec5 end( battery). Going into a red joiner
  • Blackdog
    Ps no flights yet just out of box
  • Blackdog
    Not impressed with free wing so far now left elevator servo died
