Official Freewing 80mm F-22 Raptor EDF Jet Thread
  • Fast N Light
    Very interested to hear how it goes moving the CG back. My 5300mah lipos are ~685g so it sounds like they will have to be all the way back just to get the FW CG.
    I drafted up a 3DP battery tray with stanchions to make space below for the Rx. There is quite a lot of clearance under the hatch since cockpit is forward. 6mm and 12mm rise versions are shown. 6mm looks good in the plane. 12mm might be too much. Printing now to see. Splitting the difference from 6-8mm with foam cutting might give a good balance based on your experience.
Name:	G3 Tray 12mm.jpg
Name:	G3 Tray 6n12.jpg
    Curious about weight I weighed some planes. No batteries included in the weights and all fly on the same batteries.
    My 80mm F-22 is 2570g. Gripen w/ TV is 2540g. L-39 w/ drop tanks is 2300g. My 70mm (also flies on the same batteries) is 1730g.
    I can understand the lack luster vertical.​
    I moved it in anticipation of needing to move the battery back from the stock marks to get a desired in flight balance. Just about every EDF seems to need this, sometimes 25-30mm aft of the stated balance spot in the manual. The screws lined up so it was just where I placed it. Also, this covers the wiring mess at the back.
    All my first days flying was done about 5-7mm behind the marks. I flew two 540g 5000 and two 640g 5200 packs that day. All needed a bit of push inverted and the elevator needed 3mm of up trim. Today I am only taking the 5000's to see how moving balance back further is. Also taking out my 70mm which also flies on the 5000's.
    I do not anticipate going 8S, I have removed 8S set ups from my other 80mm planes, most notably my Gripens, and don't want to do it on this one. The vertical is really my biggest negative and I'll live with it.
    There is at least an inch of foam, I dremeled about 1/2", maybe a little less, 3/8". I also dremeled a little to the sides under the ply mounting plates to allow room for wires on either side of the receiver. I ended up dremeling out a lot more than in my picture above.
    In addition to moving CG back todays tests will be seeing how raising the flaps and maybe aileron up slightly effects flight and that 3mm of up trim I'm flying with.
  • Fast N Light
    The biggest mod is moving the MCBE aft and putting the receiver under the battery tray and moving the battery tray aft about an inch and a half over where the small ply MCBe mounting plate was. I removed the gyro mounting plate and it's mounts, removed the MCBe mounting plate and trimmed foam on the sides so the battery mounting plate goes all the way back. I cut foam under where the MCBe mounting plate was to run wires under the now moved aft battery mounting plate.
    I pushed a pin through the foam under the tray to make sure I can dremel foam to mount the receiver under the tray and there is plenty of foam to do so. After lunch I'll dremel that and start the receiver and MCBe mounting and wire management. The MCBe will be mounted vertically flat up against the very back of the bay.
    Doing all this will give me about another two inches I can move the battery back though I have no issue balancing as it was stock.
    Evan - Looks like a very clean installation. If you had the desired CG with the stock battery tray location, what was the reason to move it 1.5" aft? 8S? Different fan? Other motivations?
    How much additional depth was cut into the foam to make space for the Rx height under the tray?
    Yes agreed.
    Not to sidetrack the thread but I have the 105mm L-39 and with how it performs next to any 70 or 80 is horrible, I can't see having a F-16, which should be faster, ziipier than the L-39 being that fun. At least not without a megga EDF/ battery upgrade to a JF110 and 14S.
    The 8S 90 still has the best power out of the box though of course modified with a 10S and 12S it had even more, I did have a JetFan 8S in my first two but FreeWings new 8S 90mm fan is as powerful. They all, 70, 80, and 90 have plastic mounted very good gear and all have flaps. Cool to do this https://www.youtube.com/watch?v=0UtX...ature=youtu.be
    Which F-16 do you like best? I don't like the F-16 as much as the F-22 but have three of FreeWings new 64, one on 6S, their 70mm and the new V2 90mm 8S (I also had the V1 90mm). I also recently had the Eflite 80mm on 8S but didn't like how it flies. Do you have the 105mm? I was thinking of getting one, I like my 105mm L-39.
    I think you might like the f16 105mm, now it does fly heavy, not sure but I would think the freewing 8s 90mm v2 would have a better thrust performance. Just by my experience with the 105mm hsd in stock form.
  • shortround91
    Ready to fly.
    Gear sequencing
    Tailerons and full span ailerons
    .​ Click image for larger version
ID:	417869 Click image for larger version
ID:	417870 Click image for larger version
    Looks great, appears the 80 cockpit is just like the 70’s over course a little larger. Keeping my fingers crossed we get a 90 Raptor upgrade sooner than later along with some replacement parts coming available. In need of a wing set, flew in 20mph winds plus gusts on landing gust hit tipped her on a wing and wrinkle city. FW and Motion have really been knocking it out of the park lately can’t wait to see what else they have in store for us in 2025
    Ready to fly.
    Gear sequencing
    This morning I pulled the pin connector on the ribbon cables for the outer gear doors, Y'ed them and plugged them into a slot on my receiver and created a sequencer program in my transmitter. I made the sequencer match the nose gear timing and boy is it slow. Reminds me of the Eurofighter... I needed an extra channel to do so so I lost separate steering on my 10ch receiver.
    I'll have tailerons, flaps mixed to ailerons for full span ailerons and the main gear doors now closing after the gear are extended.
    I have no problem getting 20mm behind the 115mm mark with either my 5200 (545g) or 5000 (650g) packs. There is room for 8S and if you have lighter ones it should balance with them. You can delete or move the MCBe but it won't get you much.
    I bypassed the MCBe on mine for tailerons and full span ailerons, and separate nose steering.
    There is no clearance issue if we had dual stage doors on the mains and todays project is to figure out if I need to bypass the MCBe and make a sequencer program in my transmitter to do it or if an older MCBe can do it.
    I haven't buttoned it all up yet and also want to see if I can dremel foam under the battery tray to put the receiver there, on the 90 I didn't have to and there was plenty of foam depth under the 70's to do it but at first glance the foam under the 80's doesn't look thick enough.
  • shortround91
    Very interesting, when you finish up would love to see pics. Owning the 64-70 and 90 I’m just not sure if I for now need the 80, it’s very nice I just can’t see it doing anymore than the others minus the 64
  • shortround91
    Well can’t say I can agree with the 80 more power, I own 3 70’s a 90 6-8s. The 90 on 8s is so much more capable than on 6s but thrust wise I watched the speed run video of 117. My 70 Raptor box stock with tailerons runs 132 all day in a mild dive on a SMC hivolt pack with 90 Raptor doing exactly 117 on 6s then 127 on 8s again no steep dives. All GPS’d and witnessed by many club members. I love all the upgrades to the 80 but can’t see gear covers changing that much to handling or how much better it can fly. My second on this will be pack size, I run SMC 59/5100 hivolt packs in my 70’s all the way to the wall cockpit has been modified. If it’s tight with a admiral 5k I’m not sure I’d be able to get CG where I like it to be just my opinion and guys let’s make a 8s option on a 80 as well
  • EDF-Jetpilot
    That may be, I'm happy to believe you.
    I had the E-Flite 64, but I sold it because it was too small for me. I currently have the E-flite 70 and 80 on 6S and the Freewing 90 V2 8S. I've ordered the HSD Belgian F-16 105mm with a 134cm wingspan, but unfortunately it won't arrive until March 2025. I can hardly wait. I like flying the E-Flite 80 in grey with flaperons and tailerons the most... I fly it almost every day in the evening after work during the season, using 5-10 batteries. I'm still in the process of testing and adjusting the 90 V2, but it's going well.​
    I'll have to get the new F-22 80mm too... I can hardly resist.​
  • EDF-Jetpilot
    You have flown the 80? Do you have an 80? Do you have a 90 or the new 70?
    Flight performance in what way? I have the 90, on #3 and have a spare in the box #4. I've flown the 90 6S, 8S, 10S and 12S and have put TVs and lights on all of them and think it's the best flying EDF that FreeWing makes. I also have the 70 and for what it is it's pretty darn good. My 80 is due in tomorrow but it'll be a few days before I can fly it with the weather.
    How does "simple wing assembly" have anything to do with stability, handling and durability or "plastic reinforcements" for stability and handling? And how do you consider the undercarriage better? I think the 80 has a lot of improvements over the 90 but none for stability (except that it comes with a gyro, if you get the PNP, I can't use how I'll set mine up) or handling and yes durability should be a bit better with the plastic edging.
    Years ago I learned to fly jets with various Freewing F-22s. It is an absolutely great flying model and easy to control because, like the F-16, it does not stall. I can still remember the feeling of flying the Freewing 64mm without a gyro. All I meant was that the new 80 stays nice longer thanks to the plastics, that the 80 has more power out of the box than the two old 90s, similar to the new 70. The undercarriage is reinforced with metal plates and mounted more solidly (plastic), so it is better and also nicer (scale) with the additional flaps. That's all. So you are an F-22 fan... I can understand that, just as I am an F-16 fan, I love the F-16 more than anything and have every size of it ready to fly in the hangar. I fly the F-16 on about 90% of my missions!
  • EDF-Jetpilot
    You have flown the 80 and 90? Which 90 are you saying flies much worse, 6S or 8S? Why?
    In other words I don't believe you at least for flight performance. More durable how? More stable, how?
    The flight performance of the 90 is not really good, but the 8S is not bad. the 80 has a better power-to-weight ratio. The flight characteristics of the 90 are of course very good, that's not what I meant. In terms of stability, handling and durability, the new 80 owes its success to the many plastic reinforcements and the simple wing assembly, as well as to the better undercarriage. But in the end it's purely a matter of preference as to which one you like best.
  • EDF-Jetpilot
    True story on the 90mm pricing.
    Yes, but the 80mm is much better than the 90mm, more detailed, more beautiful, more stable, more durable and with better flight performance. So it can live up to 90mm.
