Official Freewing 90mm Ares 3D EDF Jet Thread
There are 6 total versions of this jet. 8S, 6S and ARF PLUS available in both Red and Yellow:
Freewing Ares 3D Red Ultra Performance 8S 90mm EDF Jet - PNP
Freewing Ares 3D Red High Performance 6S 90mm EDF Jet - PNP
Freewing Ares 3D Red 90mm EDF Jet - ARF PLUS
Freewing Ares 3D Yellow Ultra Performance 8S 90mm EDF Jet - PNP
Freewing Ares 3D Yellow High Performance 6S 90mm EDF Jet - PNP
Freewing Ares 3D Yellow 90mm EDF Jet - ARF PLUS
Version Note: This is the 8S version which comes with a 90mm 12-Blade EDF 8S Power System with a 4075-1350Kv inrunner brushless motor and a thrust reversing 120A ESC.
The Freewing Ares 90mm EDF Jet is a breakthrough in EDF jet design, built for pilots who want to push beyond speed or scale into the world of 3D and post-stall aerobatics. Developed in partnership between champion aerobatic pilot Sebastiano Silvestri and Freewing Model, the Ares is purpose-built for insane aerobatics including hovering, torque rolls, cobras, flat spins and pinwheels.
At the heart of its extreme capability is Freewing’s second-generation dual-axis thrust vectoring system. Using a redesigned nozzle structure, thrust loss has been reduced from 35% in the first generation to less than 6% - meaning far more usable power is available for hovering and post-stall maneuvers. Combined with twin onboard gyros and an adjustable CG weight system, the Ares gives pilots the precision, stability, and authority to perform maneuvers rarely seen in jets.
Practical innovations like quick-release wings with auto-connect wiring, a bright 7-light LED system, and durable CNC machined landing gear struts make the Ares both easy to transport and a joy to fly. Backed by a powerful 12-blade 8S EDF power system, and an advanced dual gyro setup, this jet delivers brute force and fine control in equal measure — opening the door to a new level of EDF aerobatics.
Unmatched 3D Maneuverability
The dual-axis thrust vectoring system gives pilots incredible control in pitch and yaw, allowing precise hovering, torque rolls, and complex aerobatic maneuvers that are impossible with a conventional EDF jet.
Unleash Extreme 3D Action
The Ares is built for hovering, torque rolls, cobras, pinwheels and so much more! Pilots can perform a plethora of post-stall maneuvers rarely seen in EDF jets.
Precision Control with Dual EG01 Gyros
One gyro fine-tunes the control surfaces to improve overall stability and responsiveness in every flight regime, while the other manages thrust vectoring for precise hovering and advanced aerobatic maneuvers.
Field-Ready Quick Release Wings
Wings can be removed or installed in seconds, and electronics connect automatically. This makes setup and transport fast and hassle-free.
Enhanced Flight Awareness with LEDs
Seven integrated LED lights provide orientation cues and enhance visibility during flight. Pilots can maintain control and confidence during complex or rapid maneuvers.
Superior Aerodynamic Design
Wing fences improve airflow attachment and add side area, boosting stability and control authority during aggressive maneuvering.
Fine-Tune Your Balance
The center of gravity can be easily adjusted using the included nose weights. Pilots can optimize performance for hovering and other 3d maneuvers or focus more on forward-flight maneuvers.Features:
High-Power 8S EDF Performance
The 4075-1350KV inrunner motor, 12-blade fan, and 120A ESC with thrust reversing deliver precise, agile thrust. Pilots can execute hovering, torque rolls, and other advanced 3D maneuvers with confidence and control.- The Ares 90mm EDF Jet features thrust vectoring, enhancing the performance to include extreme 3D aerobatics, featuring hovering, torque rolls, cobras, flat spins, pinwheels and more
- Its second-generation, dual-axis thrust vectoring system features a redesigned nozzle structure that reduces thrust loss from 35% to less than 6%, delivering more usable power for post-stall maneuvers
- Every detail of the Ares is built with the aerobatic expertise of Sebastiano Silvestri in partnership with Freewing to provide a jet designed for serious 3D flying
- Twin onboard gyros provide enhanced stability, with one optimizing the control surfaces and the other optimizing the thrust vectoring for precise hovering and advanced aerobatic maneuvers
- The gyro gain can be proportionally adjusted using a knob or slider to suit individual preferences, and a separate mode switch can be assigned for simple on/off control
- Quick-release wings with auto-connect wiring make field assembly fast and convenient
- The integrated 7-light LED system enhances orientation and flight awareness, helping pilots maintain control during complex maneuvers.The flap geometry allows optional, user-programmed flap-aileron mixing for increased roll authority at slow speeds
- Wing fences improve airflow attachment and add side area for enhanced knife-edge performance
- The high-power EDF setup, including a 4075-1350KV inrunner motor, 12-blade fan, and 120A ESC with thrust reversing, delivers both raw power and precise control
- The adjustable CG weight system allows pilots to fine-tune the jet’s balance for optimal performance in hover or forward flight
- Plastic-cladding protect high-wear areas from damage for long-lasting durability
- No bare foam! The Ares comes fully painted, including the white areas, for an improved appearance and professional finish
- Durable, retractable landing gear features CNC-machined, shock-absorbing struts and a reinforced nose gear to ensure reliable takeoffs and landings
- Freewing Ares 3D Yellow Ultra Performance 8S 90mm EDF Jet - PNP
- 4075-1350Kv Brushless, Inrunner Motor (Installed)
- 120A Brushless ESC with thrust reversing and EC5 connector (Installed)
- Servos (Installed)
- Instruction Manual
- 13 Channel radio (if using thrust reversing, both gyro controls, and flaps that can be used with the ailerons) - select a minimum 13 channel radio from our Aircraft Radio Collection
- 13 Channel receiver (if using thrust reversing, both gyro controls, and flaps that can be used with the ailerons) - select a minimum 13 channel receiver from our Aircraft Receiver Collection
- 2x 4-cell 5000mAh to 6000mAh LiPo batteries with EC5 connector in series - we recommend Admiral Pro 5000mAh 4S 14.8V 60C LiPo Battery with EC5 Connector Multi-Pack (2 Batteries)
- EC5 2-to-1 series adapter - BenchCraft EC5 2 to 1 Series Adapter with 10 Gauge Silicone Wire
- 4 Cell compatible battery charger - select a minimum 4 cell (4S) charger from our Charger Collection
AGE LEVEL :18 and up
SKILL LEVEL :Advanced
BUILD TIME :1 HourModel Scale N/A Wingspan 1156mm / 45.5in Length 1400mm /55.1in Empty Weight 2721g / 6lbs (w/o battery) CG (Center of Gravity) 122mm aft from the leading edge of the wing at the root Power System 8S 4075-1350Kv Inrunner Brushless Motor Electronic Speed Control 120A thrust reversing, EC5 Connector Propeller / EDF 90mm 12-Blade EDF Servos - Nose Gear Steering - (1) 9g Digital, Hybrid Gear Servo - FSS31093-700
- Nose Gear Doors – (1) 9g Digital, Plastic Gear Servo - FSS31091-800
- Ailerons – (2) 9g Digital, Hybrid Gear Servo - FSS31093-400
- Left Flap – (1) 9g Digital, Hybrid Gear Servo - FSS31093-200
- Right Flap – (1) 9g Digital, Hybrid Gear Reverse Servo - FSS31093R-200
- Left Elevator – (1) 9g Digital, Hybrid Gear Servo - FSS31093-200
- Right Elevator – (1) 9g Digital, Hybrid Gear Reverse Servo - FSS31093R-200
- Rudder – (1) 9g Digital, Hybrid Gear Servo - FSS31093-200
- Yaw Vectoring – (1) 16g Digital, Metal Gear Servo - FSS31172-100
- Pitch Vectoring – (1) 16g Digital, Metal Gear Servo - FSS31172R-100
Landing Gear Retractable landing gear with CNC-machined aluminum, shock absorbing struts Required Battery 2x 4S 14.8V 5000-6000mAh LiPo with EC5 Connector (required) Required Radio 13+ channels (for separating the flaps, 2 x gyro adjustments, and thrust reversing) (required) Ailerons Yes Elevator Yes Rudder Yes Flaps Yes Lights Yes Hinge Type Nylon Material EPO Foam Skill Level Advanced Build Time 1 Hour Recommended Environment Short grass or hard surfaces like asphalt or concrete
