Official Freewing 64mm A-10 Thunderbolt II V3 EDF Jet Thread
    • 8238
    A-10 Thunderbolt II V3 Twin 64mm High Performance EDF Jet - PNP from Freewing - FJ11711P
    Renowned for its battlefield dominance, the A-10 Thunderbolt II, affectionately known as the "Warthog," is one of the most iconic Close Air Support aircraft ever built. Freewing proudly presents the all-new A-10 Thunderbolt II V3 Twin 64mm, completely redesigned and retooled with larger dimensions, updated aerodynamics and stunning scale fidelity. This model combines jaw-dropping realism and commanding presence with a thrilling EDF flight experience rarely seen at this size.
    Setup and transport are effortless with screwless, quick-release wings that lock securely in place and auto-connect the electronics. A spring-loaded battery hatch and durable plastic-cladded compartment make battery changes fast and hassle-free, while glueless assembly and simplified wiring get you in the air even sooner.
    Scale realism is unmatched, with CNC-machined shock-absorbing retracts, highly detailed panel lines and rivets, and authentic gear doors. A daylight-bright LED lighting package, including formation, navigation, strobe, and nose-gear landing lights, brings every detail to life, while the full sliding-rail armament package and hand-painted pilot figure add mission-ready authenticity.
    In the air, the Freewing A-10 shines during scale maneuvers, from low-level Close Air Support runs and precision passes to tight turns and coordinated formation flying. Every flight showcases the Warthog’s commanding presence and immersive EDF performance, making this all-new model the ultimate scale experience.
    Screwless, Quick-Release Wings
    Forget hunting for tools or tiny screws. With a press of the push-button latches the wings snap firmly into place, and the built-in connectors automatically hook up the electronics. Setup and teardown become a quick, satisfying part of every flight session.
    Realistic Scale Armament
    The Freewing A-10 64mm comes fully loaded with a complete suite of scale weapons that slide effortlessly into place on the rail system. Each piece attaches and removes in seconds, letting you outfit the Warthog for a mission-ready look or strip it down for lighter, high-performance sorties.
    Brilliant Scale Lighting Package
    The fully integrated daylight-bright LED lighting system brings the A-10 to life with incredible scale accuracy. Formation, landing, navigation, strobe, and beacon lights enhance realism and make every detail stand out, both in the air and on the ground.
    Easy-Install Motor Pod
    The motor pod screws in place easily, and the neatly organized motor wiring makes connecting both motors fast and simple.
    Scale Retracts with CNC-Machined Struts
    The retractable landing gear features CNC-machined struts with built-in shock absorption for smooth, realistic operation. Every takeoff and landing looks and feels true to scale, enhancing the authenticity of the A-10.
    Highly Detailed Surface
    The A-10’s surface bursts with scale realism, featuring crisp panel lines, authentic rivets, and finely crafted details. Every curve and contour captures the look of the full-size aircraft, making it a standout on the ground and in the air.
    • Completely redesigned from the ground up, featuring all-new molds, larger dimensions, and updated aerodynamics for improved performance and scale accuracy.
    • Quick-release wings with auto-connect wiring make field assembly fast and convenient
    • Includes an exquisite LED lighting package, including navigation lights, strobe, nose gear mounted landing light as well as formation lights to further enhance scale realism
    • The highly detailed surface features crisp panel lines, realistic rivets, and other scale elements that showcase impressive accuracy.
    • Scale retracts with CNC-machined, shock-absorbing struts and authentic gear doors enhance realism and add a true-to-life appearance.
    • Included scale armament package allows you to outfit the A-10 for superb scale realism and is easily installed and removed with a simple sliding rail system.
    • Plastic-cladded battery compartment accommodates larger batteries and provides enhanced durability
    • Glueless assembly and simplified wiring provide a much faster and more convenient initial setup
    • Thrust reversing capable ESCs enable shorter landings and greater ground control
    • Twin, 2840-2200Kv Outrunner motors combined with 12-blade 64mm EDF’s provide incredible thrust, performance, and sound.
    • Spring-loaded battery and electronics hatch for quick, hassle-free battery access
    • Hand painted pilot figure adds a finishing touch to the scale details.
    • Clearly marked CG points on the wings make it quick and simple to check the center of gravity for perfect balance.
    • Ball linkages on all control surfaces provide precise handling
    • Long-lasting nylon hinges built for reliable performance
    • Officially licensed by Northrop Grumman
    • Freewing A-10 Thunderbolt II V3 Twin 64mm EDF Jet – PNP
    • Twin, 12-blade 64mm EDF Power Systems (installed)
    • 2x 2840-2200Kv Outrunner Motors (installed)
    • 2x 50A ESCs with reverse thrust and EC5 connector (installed)
    • Electronic, retractable landing gear (installed)
    • Servos (installed)
    • Instruction Manual
    AGE LEVEL :14 and up
    SKILL LEVEL :Intermediate
    BUILD TIME :1-2 Hours
    Scale 1/14
    Wingspan 1270mm / 50.0in
    Length 1143mm / 45.0in
    Flying Weight 2212g / 4lbs 14oz without battery and without armament
    CG 74mm from the leading edge of the wing at the root
    Power System 2x 2840-2200Kv Outrunner Motors w/64mm 12-blade Fan
    Speed Control 2x 50A Brushless ESCs with Thrust Reversing
    Propeller / EDF 2x 64mm EDF with 12-Blade Fan
    Servos
    • Nose Gear Steering – FSS31093-500
    • Nose Gear Door - FSS31091-500
    • Ailerons - FSS31093-400
    • Flap (Left) – FSS31093-200
    • Flap (Right) – FSS31093R-200
    • Elevator (Left) - FSS31093-100
    • Elevator (Right) – FSS31093R-100
    • Rudder (Left) – FSS31093-300
    • Rudder (Right) – FSS31093R-300
    Landing Gear CNC-Machined Aluminum, Shock Absorbing, Retractable Landing Gear
    Required Battery 1x 6S 22.2V 4000-5000mAh LiPo with EC5 Connector (EPR50006)
    Required Radio 6-7 Channel radio (7 channels for reverse thrust)
    Rudder Yes
    Flaps Yes
    Ailerons Yes
    Lights Yes
    Hinge Type Nylon hinges on all control surfaces
    Material EPO Foam
    Skill Level Intermediate
    Build Time 1 Hour
    Recommended Runway Surface Well manicured, short grass and hard surfaces
    • 8238
    Now in stock in the US...
    • Coconut
      • Apr 2019
      • 212
      In one of the videos, Wes said it has the same power system as the twin 64mm F14. This A10 has outrunners, and the F14 has inrunners.
        • 4865
        Lookin' good, Y'all.
        Best, LB
        • stitch
          • Dec 2014
          • 142
          Got mine today! Looks great putting together now!
          • stitch
            • Dec 2014
            • 142
            Need come out with some afterburner lights for this,I just received mine a few hrs ago it's cool got the 80mm too only thing missing afterburner lights fit these kind motors!😋
            • Woohoo\o/
              • Feb 2020
              • 186
              • Cape coral Florida
              Just ordered mine. Never stay up late surfing the web.
                • 8238
                This is one sharp-looking 64mm A-10!
                • Woohoo\o/
                  • Feb 2020
                  • 186
                  I would also like to know if it’s inrunner motors or outrunners. I know it states outrunners above but mistakes happen.
                    • 5402
                    It also says outrunner in the manual so I'm sure it is.
                    • Woohoo\o/
                      • Feb 2020
                      • 186
                      Cool. Thanks Evan.
                      • Jason lancett
                        • Oct 2025
                        Anyone know when this will be released in uk/Europe??
                        • Woohoo\o/
                          • Feb 2020
                          • 186
                          Hey guys are any of you experiencing the nose gear door popping out of place when it opens? I just finished putting it together and extended the gear for the first time and the nose gear door pops out of place (front hinge only) every time. I have to pop it back in. I created a support ticket but just thought I’d ask here to save both my time and theirs. Thanks.
                          • bcrc
                            Pilot
                            • Jun 2017
                            • 33
                            I would like to know the flight times of this version.
                            • shortround91
                              • Nov 2023
                              • 301
                              • Princess Anne, Maryland
                              Received my V3 A10 last week, after maidening then flying pattern with another brands 64mm A10 I decided to go inrunner. Now I was flying full ordinance he was clean but I couldn’t keep up, now talk about a trainer like flier yes she is very very scale flier. Took mine up today for the inrunner remaiden and a very very noticeable difference in a great way. I went duel 64 inrunners from the Banshee upgrade dept paired with 80amp esc’s and a 5amp external BEC. Gets up super fast along with an easy 4:30-5min flights on a SMC 5200 green label pack. Decided to do some scale missile bomb and rocket pods, here’s a few pics before I add more.
                              • stitch
                                • Dec 2014
                                • 142
                                So why can't u leave reviews on this plane,I have left 2 on it and they never showed up.they was good ones too! Been over a month since I left them they never show up so I'm done leaving anymore on any plane!
                                • stitch
                                  • Dec 2014
                                  • 142
                                  U kno if going change out those out runners for in runners I would use those 2949 2500kv in runners from 64mm f14 those are 6s motors!
                                  • stitch
                                    • Dec 2014
                                    • 142
                                    😆 now got me thinking bout changing mine!🤣 Deciding which now!
                                    • flyguysc1
                                      • Sep 2020
                                      • 42
                                      Looks kinda small maybe photo are deceiving
                                      • MMaarrkk
                                        • Jan 2025
                                        • 3
                                        Hi Guys, Congrats on your new V3 A-10s. This is on my list. How does this stock 64mm on 5000mAh handle 15 mph winds? Would love feedback and to view your videos as well. Thanks in advance! Mark
