Flight 1 was probably the scariest maiden I have done. Only needed one turn on the elevator linkage to trim out. But the wing rocking was a bit unnerving.
Flight 4 shows the current settings in action.
All landings were at full flaps. I don't think I need any elevator mixing with flaps.
Takeoffs and landings were really not a challenge so much as trimming the wing rocking with our gusty crosswinds today. On flight 1 I had the gyro set at about 10-15%. Too little.
Flight 2 had the gyro set at close to 50%. Too much. Flights 3 and 4 had the gyro at about 25-30%. It seems just right now. I may dial it down when I get more flights on her.
The landing gear was perfect for our rough field.
My settings are as follows:
Gyro approx 25% all channels
Ailerons 100% travel, 30% expo
Flaps 0, 50, 100% whatever that works out to in mm.
Elevator by the book 100% up, 80% down to clear rudder, 20% expo No mixing with flaps
Rudder by the book, 20% expo
had to go in one hole on servo arm (4th hole from outside) for both elevator and rudder to make the travels work out.
Admiral 6s 5000 50C (new version) all the way forward.
CG appears to be at about right on the forward wing bolt, within the width of my fingertips. Worked great!
Maiden
Flight 4
