  • John Bergsmith
    I just noticed something... you said Hobby Star packs... I would do a load test and see if you are not dropping a cell in flight. I haven't had good luck with those packs. The don't puff which is usually an indicator of a problem but they do tend to drop cells under load. I stopped using them as a result. That could make your esc cut off part way through the flight.
    Also medium timing works fine with stock outrunners but I usually drop it to low just to save on amp draw. I saw a 9 blade F-104 this weekend and it flew really well! I had mine out for the first time in a while too. Flew it at 2 different places in the same day! All good flights too!
    Yes the first pack was a 6200 Hobby Star, second pack was an Admiral 6000. Both performed the same, the ESC shutdown within seconds of each other. I haven't had any issue with HobbyStar until just recently. I bought three new 6s 5200 and they all puffed on the first run in a T-33. No idea what happened, others I've had for a year and they are perfect.
    I did set the cut off voltage to low, so I guess I'll experiment between medium and low timing.
  • gooniac33
    Originally posted by John Bergsmith
    T-CAT gooniac33 Evan D So I went through the settings on the esc, cut-off was set to soft, cut off voltage was set to medium which I set to low.
    Only other question is the timing, it's currently set to medium, is that correct? Again I'm running the 9blade 3748-1750kV, with the Hobby Star 6200 pack I believe Evan said he was getting close to 4 minutes.
    ​​​​​​​Thanks in advance guys!
    Sounds like good settings...
    Excellent! Medium timing on the stock outrunner motors are usually what the factory has set as the default choice and has worked fine for me in the past using the stock 130A ESC, and has provided smooth operation without any "hiccups" during throttle advancement.
  • John Bergsmith
    Originally posted by T-CAT
    Hi John, that's usually one of two things (and others have touched on), either an ESC "Cutoff Voltage", or an ESC over-temperature protection cutoff.
    If you have the ESC programming card (also sold under various brand names and some can look a little different) linked below, check your current ESC settings like Evan D said and let us know what each setting is currently at.
    Try setting your ESC "Cutoff Voltage" threshold shown on the programming card on slot #4 to "Low". Maybe the ESC is detecting insufficient battery voltage (whether it is accurate or not) and therefore begins reducing available power. Since you have used various batteries and another person at your field also has that issue, chances are that it less likely either of your batteries aren't up to the task, but it's still a possibility. If the batteries are up to the task by handling the voltage under load well, the ESC voltage cutoff could be triggering prematurely, and the "Low" setting may cure that. As long as you stay vigilant with flight time and proper end of flight battery voltage, a lower Cutoff Voltage threshold may help in this instance. If anything, and worst came to worst, I'd personally rather destroy my battery than potentially my airplane.
    If that doesn't fix it, check the ESC temperature via IR sensor post flight to see if it reads warmer than safe operation. Many ESC's have an over-temperature cutoff to spare the electronics until temps. become normal again to resume regular operation. I'm assuming the ESC hasn't been relocated, covered, etc., in any way, correct?
    https://www.motionrc.com/products/fr...ogramming-card
  • DCORSAIR
    You guys are making me miss mine, sold it because I lost both of my runways close to home, I had a bunch of flights on mine, even had the landings down to where I didn't dread that part anymore, lol. So, looking for another runway hopefully, joined a club, but I really hate driving more than 30 minutes so looking for something closer, great flyer once you get the gyro settings right, can't wait to get another one.
  • gooniac33
    Between you, Ray, and Evan I have the info to find the problem I’m sure. Thank you!
    Glad to help man!
  • John Bergsmith
    Awe, I gotcha . No problem. I hope you find the source of problem!
  • John Bergsmith
    sounds like you have cutoff voltage set to high. If you have the card set it to the lowest you can. Its better to mess up a battery instead of crashing a plane. Also make sure its soft cut and not hard...
    Thanks Ray, I will check it out tomorrow. I have the esc card so I’ll let you know what I find. Appreciate it!
  • gooniac33
    I did calibrate the throttle. Thanks the F-104 flies great, but I’m still not sure what’s going on with esc/short flight time. Another guy has one and his did the exact same thing last weekend. The throttle wound down at 2:30, I checked the voltage on the pack and it was 3.95. Can’t seem to find out the issue causing that yet.
    Great info T-CAT , thanks! I should be more specific when I say I can't find the issue yet. It really means I've been too lazy to dive into it yet. :) However, I appreciate the info you provided above and also info that Evan provided. Guess I should get to it!
  • John Bergsmith
    I did calibrate the throttle. Thanks the F-104 flies great, but I’m still not sure what’s going on with esc/short flight time. Another guy has one and his did the exact same thing last weekend. The throttle wound down at 2:30, I checked the voltage on the pack and it was 3.95. Can seem to find out the issue causing that yet.
  • John Bergsmith
    Have you calibrated your throttle? You may wanna do that as well... and congrats on the flights! I need to get mine out and will do that this weekend...
  • gooniac33
    I put the first two flights on the F-104 yesterday, amazed it actually flies very well. With some continued trimming I can get it flying better. The biggest issue I had was run time because both landings were deadstick which is a blast with the F-104.
    I'm running the 9blade 3748-1750kV, that Evan suggested, first flight was on the 6200mah Hobby Star pack. I set the timer for three minutes, at 2:30 I dropped the gear on the downwind and I heard the fan wind down. Turned sharp towards the runway and landed with no issue. The battery was only slightly warm, and the voltage on the cells was at 3.97. Flew it again on an Admiral 6000mah, flew it with even more throttle management, and the same thing at 2:38min I heard it wind down again. Again the battery was only slightly warm, and the voltage was at 3.94. I can't touch the ESC directly but I didn't feel any heat coming out of the vent on the bottom. The speed control is new and right out of a 6s F-4130A it does have the capacitors.
    The good thing is landing with power will be no problem now! :) I maybe the only one that dead sticked the F-104 twice and lived! LOL
    I haven't done any testing yet, any idea whats going on? The second flight I kept the throttle back so it should have been fine.
  • John Bergsmith
    Congrats John. As Beeg says it's probably ESC cutoff settings, set it to soft..
    I'll check the ESC out and see what it's set at.
  • Beeg
    I had that issue with my E-Flite Habu32. I could get it to start up again by closing the throttle all the way then advancing again. Still not sure why it happened. Probably an ESC setting but not sure..
  • John Bergsmith
  • Tom1980
    No big deal about the gear, it was sort of funny. $15 bucks and it’s working fine now. I finally bundled the wires up, not completely happy with it but it will work.
    interesting takeoff on grass no doubt!
    That day was about 85 degrees with no wind. And with a typical for July bumpy, dry, and recently aerated grass surface. The grass was freshly mowed but other than that it was about as bad as it gets. If the plane can take off in those conditions I say it handles grass pretty well.
    My Freewing Avanti and ME-262 don't have any issues at all with the grass but they have bigger wheels and much bigger wings. The 262 engine pods slide along the grass surface and seem to help it roll smoothly over the bumps. The disadvantage of the low mounted pods is I have to fish pieces of grass and weeds out of the fans after most flights. And I can't fly at all if the dandelions are bad because they are at a perfect height to go straight into the pods. The dandelions get so bad their stems will hit the wing leading edge and cause their flower heads to swing down and strike the top of the wing hard enough to punch big holes in the monokote on my low wing balsa models.
