    Yeah, I'm using a frsky receiver with a built in gyro. On landing I flew it flat to the ground and last second pulled the nose up enough I scrapped the tale just a bit. But it did come down with some speed to it. Took off with 15° of flaps, and also landed with 15°. There was a 90° cross wind so that made things interesting. I hope the way I landed this will translate to the f16. It definitely felt better to me.
  • DCORSAIR
    Finally took my 104 to the sky's, she's fast, but really fun to fly I butted the 5200 up to the connection board seem to be spot on with the cg. Really enjoy this plane.
    Great, knew you would like it once you flew it, you must have figured out the landing really quick, I sure didn't on my first one, I beat the poor thing to death trying to figure out the landing, I was not using the gyro on it, but on my 2nd one, I hooked up the gyro and it made it so much better to fly and land.
  • the snake
    Adding some details after letting the enamel paint cure.
  • the snake
    Project Italian Special in process, waiting for Callie next month though
  • rms
    Have some of you done anything with the blinking Nav lights?
    I want to put the navigation light on the 5volt if possible? Have any done this? It looks to be 2 volts.
    Will keep the beacon blinking..
  • toothbuzz@hotmail.com
    Those are good ideas, too. Where there’s a will, there’s a way.
  • Beeg
    If you're not opposed to some surface work, instead of jamming rods in there why not use strips of G10 or 1/64th plywood and cut perpendicular slots across the seam and push them down into the fuselage if you're concerned about the joint?
    Nope, I’ll push small diameter rods through the joint wherever I can find a place from the canopy area and use a little epoxy to the close the hole. I’d never intentionally break something just so I can fix it. Carbon fiber strips laid across seams and glued in place using epoxy thinned with denatured alcohol also works well. The alcohol evaporates during the curing cycle and leaves a very light weight adhesion.
    We’re talking about a joint glued by the factory, not the one we glue. So you’ll break apart a perfectly good plane to put rods in it????
    Should be easy enough to stick a couple of carbon fiber rods through the joint and glue them in place. I think I'll do it just to be on the safe side.
    Yeah this was the first I really heard of it.
    I don't know if it really was an issue. I've only heard of one with the seam issue.
    Is it still an issue with the updated model? I guess the only actual update is the power system.
  • Beeg
    I see it now just aft of the intakes. Never noticed it before.
    He was asking about another seam that is factory glued
  • Beeg
    Originally posted by toothbuzz@hotmail.com
    Gonna get the 104 out of mothballs and take to the EDF Jet Jam next month. I saw a post on here warning people about fuselage weakness due to poor gluing at the factory. My fuse came two pieces I glued them together myself. Were the first ones assembled at the factory?
    No, those of us that received the first ones had to glue our own fuselages together. I used epoxy and it's still solid as a rock. There are already supposed to be two carbon rods reinforcing the fuselage.
    https://www.rcgroups.com/forums/show...&postcount=735
    Ah..... I see it now. I'm gonna reinforce that with additional carbon fiber before I fly it again.
    The picture I saw posted shows the fuse broken where it joins just in front of the wing's leading edge. Also, there are no carbon tube joiners there in the pic. (page 7, post #126 of this thread.
    There is also a factory seam other than the one you had to glue.
