Official Freewing 70mm F-104 Thread
  • scooter genie
    Got the wings done today, now working on weathering it with the airbrush.
  • scooter genie
    still working on the wings. the foam got a little fuzzy in places where the decals were removed.
  • scooter genie
    Well, the paint and decals that were on it out of the box looked like a child's toy.....couldn't bring it to the field looking like that.
  • Felixs10
    It's going to be a mean looking bird
  • scooter genie
    Tip tanks done. Decals on order.
  • scooter genie
    Callie said it would be no problem to make the livery that I need . She's really great to deal with ! Wouldn't have known about her if not for this forum.
  • scooter genie
    Got the dark color on today, and emailed Callie to see if she can do the decals for the German navy livery.
  • scooter genie
    Started on the paint today. I always start with the lightest color. Since that's done, off to lowe's to get more paint.
  • scooter genie
    Something like this.
  • scooter genie
    oops.....forgot the pics.
  • scooter genie
    The joys of masking ! Almost ready for paint. When I mask the canopy, I like to run a ball point pen around the edges. It seals them down, and gives me a reference where to make the cut. I'm hoping Callie can make the German livery for me. I figured it to be about 1/10th scale. Hard to believe the full scale bird only had a 21.9 foot wingspan ! I'm trying to copy the look of the 2016 Top Gun winner.
  • scooter genie
    I am going to do a repaint on this plane before I finish assembly, or install the power system. I will go with the German version. Since I can't stand to paint over decals, I use the old packing tape method to remove them. Rub the tape real good for maximum pull. The waterslide decals come off without damaging the paint....not so, with the sticky back vinyl ones, but I am painting it anyway, so who cares.
  • scooter genie
    BTW, I need some help guys. Since I got the arf version, I have no idea where they put the ESC, or where to rout the long rudder / elevator wires inside the ducting. I don't see ant pocket or wire chase.
  • scooter genie
    It's Here ! And I've been busy with the upgraded landing gear. It was so simple. The nose gear strut had to be rotated 180 to allow the trailing link to face forward, and had to switch the wheels on the mains because the wheels that came with the upgrade were too big, and wouldn't fit in the wheel well. That's it ! Easy cheesy......So for all you 104 jockeys, The F16 upgraded gear works great on the 104 !
  • scooter genie
    Airframe will be here tomorrow ! Yee haa ! The only other potential issue with the mains is if the strut pin is the same size.
  • scooter genie
    OK, While waiting for the airframe, I am tinkering with the gear. The first obvious difference is that the F16 nose gear retracts aft. the F104 retracts forward. So the first thing that has to be done is to loosen the grub screws on the nose strut, and rotate the strut so that the trailing link is pointing down. That way, the trailing link will be forward in the down position. Also looking at the 12 blade fan and 2200Kv inrunner combo from edf hobbies, and hobbywing 100a ESC.
  • scooter genie
    bench tested the out runner setup on 6s and it got way too hot. I already ordered the kit version of the 104, so.....can anyone suggest a nice inrunner setup for 6s ? I'll be using a 3300 to keep the weight down.
  • scooter genie
    Well, I ordered the upgraded struts for the F16....hopefully they will fit without too much work. I am going to get the kit version of the 104 because I have a changesun V3 70mm 10 blade with a cyclone power CS480-2800Kv outrunner with an unusual shape that puts the motor in the airflow of the fan. It was left over from a LX TV F16 I had a few years back. That plane flew very fast on 5s, but will be using 6s on it this time.
  • scooter genie
    I was slumming around in Motions parts section, and noticed that the stock nose retract fits the following planes...70mm Fi6, and 70mm F104. Then I cross referenced the part nos. for the mains. The numbers between the planes is different, But the stock mains look identical from the pictures. I'm thinking that the upgrade struts for the F16 should fit the F104. I sure hope so, because I'm on the fence, and if I could put those struts in the 104, it would seal the deal for sure.
  • scooter genie
    Has anyone tried the 70mm f16 upgraded gear struts in this Bird?
