54" F4D-1 Skyray
  • Corsair nut
    Jets...warbirds...mmm hmmm
    • 218
    • Tehachapi ca
    80mm would fly this thing awesome, and you womt need a lame cheater hole! :p
    • Kloverzero
      JetManMichael
      • Dec 2015
      • 513
      • Conway SC
      The inlets are not going to be very big, probably 5 square inches each. It will need a cheater either way. It has plenty of duct space, but to keep the scale lines, I am going to have to go with the cheater.
      • Corsair nut
        • 218
        • Tehachapi ca
        .a 80mm only needs about 6 or 7 sq in. I think a 90 is around 8 or 9 sq in
        • Corsair nut
          • 218
          • Tehachapi ca
          Infact a 80 might be clpser to 6 than 7. Id need to look it up
          • Corsair nut
            • 218
            • Tehachapi ca
            Just checked. 80mm is about 5.5 sq in for fsa. 90 is about 7.5 iirc. Ive flown edfs sucessfully down to 65% on the inlet side, with properly designed ducts. My lil 28" 70mm skyray had plenty of inlet and they were maybe a lil bit oversized. Id be more than willing to bet a 80 would work just fine wothout a cheater..and a 90 would even work awesome, especially if you have anywhere near 10 sq in.
            • Boots Whirlygig
              • 560
              • Granville Ohio USA
              But seriously, as light as this airframe is, 3/4 oz fiberglass cloth and alcohol thinned epoxy would add considerable strength and little weight. Stay away from the Bondo which is a 6 oz HEAVY weave cloth!
              • Boots Whirlygig
                • 560
                The lightweight glass would be good on the intake ducting. That 90mm fan may try to ingest them, or intake the intake and spit them out the tail pipe! :Scared:;)
                • Corsair nut
                  • 218
                  • Tehachapi ca
                  Ive dont depron ducting before. If the inlet area is atleast 100% or more, it typically holds just fine. Or fff for tgat matter
                  • Oldensly
                    Help, I have purchased a couple iFLY 1806 2300kv motors that do not seem to turn up as they should. According to my calculations, 2300x7.4 they should turn up around 17000rpm and they are no where near that. What could the trouble be?
                    Any assistance will be greatly appreciated. Thanks Bob
                    • Kloverzero
                      JetManMichael
                      • Dec 2015
                      • 513
                      • Conway SC
                      HI Bob, and welcome to HobbySquawk.
                      Your calculations are correct, however, the kv x V = rpm is for the motors without a load on them. With the fans running, it will be considerably lower. This is completely normal.
                      We always welcome questions here, however, posting them on someone else's post that is unrelated is not the place for them. Please use the "New Topic" button in the future for any questions that you may have about any subject. That way, your question can be seen by everyone, and not just the people who are watching a particular post.
                      I hope the answer helps you, and have fun looking through the posts here, and commenting on anything you see that interests you!!
                      • Kloverzero
                        JetManMichael
                        • Dec 2015
                        • 513
                        • Conway SC
                        Okay, so here is what I managed to get done over my little "staycation"
                        The upper duct is in. I opted to go with the 3/16th foam, which put the duct at the perfect size for the 80mm fan. This all that this thing is going to need!! I also got the lower formers drawn and cut from the intakes back, and got the fan mounting plates installed.
                        Before I start gluing all of the lower formers on, I think I will tackle the wings. I have decided to make it a solid unit, the wings will not be removable. They also, according to my 3 view, have no dihedral or anhedral, so I felt it best to build the tops while I can still have the plane flat on the board. This will ensure that everything stays straight and true. Once I have the internal structure complete for both of the wings, I will glue them to the fuse, and then sheet the tops. I can then flip the model over, and route in the spars.
                        The front section looks a little wonky at the moment, as I want to sheet the sides of it in one piece, so I am waiting until I get the bottom formers on for that.
                        So, here you go!!
                          You are the Herr Frankenstein of bringing life to BlueFoam :Cool:
                          Still monitoring your :ov10thread for the plan PDF ;)
                            Nice work!
                            • Kloverzero
                              JetManMichael
                              • Dec 2015
                              • 513
                              • Conway SC
                              Don't worry Charlie, I will send you a PM when I have them ready. I am out of paper, and can't afford a roll until Friday. Once I get that, I will get them done. I am also just going to put them on a thumbdrive and send them as a PDF, and you can then take the file to your local print shop and have them printed. I also submitted a picture of me with the OV-10 to Model Aviations Focal Point section, so keep an eye out in upcoming issues for my ugly mug and beautiful model!!!
                                When you get the PDF just PM me for my email to send the file that way versus a piece of hardware by snailmail ;)
                                I've seen your mug and it didn't :Scared:me the first time but I will keep an eyeball peeled for the article
                                • Corsair nut
                                  • 218
                                  • Tehachapi ca
                                  Ansolutely love it! Perfect!!
                                  • Boots Whirlygig
                                    • 560
                                    Can't wait to see the finished creation take wing!
                                    • Kloverzero
                                      JetManMichael
                                      • Dec 2015
                                      • 513
                                      • Conway SC
                                      Alright!! I have the top of one wing done and attached to the fuselage!!! It is starting to become something now!
                                      I cut a slot on the inside of the center sheet right next to the two main riblet line so that I can route it out from the bottom and put longitudinal spars in, as well as the lateral spars that will span across the fuse.
                                      Hoping that I can get the other wing half done tonight, and get it sheeted and attached as well!!
                                      She really shows her 54" length in the last photo!! Hopefully I will have a new set of photos tomorrow!!
                                      • Kloverzero
                                        JetManMichael
                                        • Dec 2015
                                        • 513
                                        • Conway SC
                                        Success!!
                                        Then I flipped it over and set the formers on for effect!!
                                        • Kloverzero
                                          JetManMichael
                                          • Dec 2015
                                          • 513
                                          • Conway SC
                                          Last week and a half has been rather crazy around here, so I didn't get anything done. Blew the dust off it last night, and got started on the lower fuse. The rest of the ducting is not going to be any fun at all, but I will tackle it tonight after I get the Freewing 64mm F-22 that cam in today built and ready to go!!
