54" F4D-1 Skyray
  • Kloverzero
    JetManMichael
    • Dec 2015
    • 513
    • Conway SC
    Last nights progress, the duct is finally almost finished!!
    I will be ordering the retracts tomorrow (A-4 rotating mains). I hope to have the rest of the lower fuselage structure complete before they arrive, so I can start concentrating on the electronics installation.
    More to come!!
    • Kloverzero
      JetManMichael
      • Dec 2015
      • 513
      • Conway SC
      And got some more done last night, switched ends of the plane though!!
      At this point, I do not know if I am going to put the retracts in it or not. I made a stick that symbolized the size of the mains for the A-4 and they are kinda too big. I am thinking about just engineering some grips into the belly, and hand launching.While this is a scary prospect for a scratch built, and otherwise unproven model, I am hoping it will be okay. It will also significantly cut the all up weight down
      Click image for larger version  Name:	1.jpg Views:	1 Size:	107.9 KB ID:	97582
      Click image for larger version  Name:	2.jpg Views:	1 Size:	111.2 KB ID:	97583
      Click image for larger version  Name:	3.jpg Views:	1 Size:	89.4 KB ID:	97584
      Click image for larger version  Name:	4.jpg Views:	1 Size:	100.2 KB ID:	97585
      Click image for larger version  Name:	5.jpg Views:	1 Size:	105.0 KB ID:	97586
      • Kloverzero
        JetManMichael
        • Dec 2015
        • 513
        • Conway SC
        Been kinda busy around here, so I haven't gotten a whole lot done, but except for the first bay, I have all of the lower fuselage structure done. Just need to be sanded now,
        • Kloverzero
          JetManMichael
          • Dec 2015
          • 513
          • Conway SC
          Well well, been quite a while since there was anything new to report on this fine lady, but there is now!! A lot of things and projects have kept this one on the shelf for a while, but she is stoked up and moving forward again!! I decided against the A-4 retracts. They were very deep, heavy, and there was no good way to have them retract into the scale position without some serious work. I opted for a set of Turnigy retracts that I have had in my bin for quite some time that have never been mounted on anything. I have them retracting into the wing (sorry for you ultra scale buffs out there), so while they are not scale, at least it does have landing gear, and I do not have to attempt a hand launch of an unproven design on a maiden flight!! So, with those in, and the servos mounted for the elevons, all the wires run, duct work completed, and everything tested thrice, I have started sheeting the bottom of the plane!! I have to run some shaping ribs on the wing tonight before they can be sheeted, but I hope to be working on the nose section by next week!!
            Looking good Michael. Glad to see you've picked this back up.
