New E-Flite AT-6
  • uscanuck1xa
    Looks very nice! Love to see these in yellow!
    Looks Great! Good luck on the maiden. My wife is doing the maiden on hers this weekend too.
  • wvrailfan
    Finished the wrap on this plane, with help from Callie. With a little luck I will maiden this weekend. The scheme is actually a little on the boring side, but I like stuff with a local flavor. The up side is, it should be easy to see against about any sky;-)
    Jim
  • MikeT
    Originally posted by ICM
    Anyone try Dubro Low Bounce wheels on the AT-6 to mitigate the tendency to bunny hop?
    I took mine out yesterday for the 1st time in months and nailed every landing. With practice there's no reason why you can't grease your landings just keep flying the airplane.
    Mike
  • ICM
  • Dewey H Lee
    Always keep in the back of your mind while heating the bolts to watch the heat being transferred to the magnets. To much cold also affect the integrity of the glue holding them in place. The heat on the screws though are a must to insure almost guaranteed removal 90% of the time.
  • Boots Whirlygig
    Yes my hind site (20/20) tells me I could have left the smaller X mount on the FL motor and use a 1/2 inch ply to mount to, rather than swap the mounts and use spacers to move the motor forward.
    I will never stop complaining about all the different prop adapters the companies use on electrics. It sure makes mods difficult for prop and spinners!
  • Ole-Timer
    Now that’s a job for a machinist. An easy out will likely break. Suggest taking a dremel and cutting a straight slot into it so you can insert a screw driver. Heat it as much as possible with a soldering iron and have a go. You need a big handled screwdriver with a small end, make one if need be. Grip that motor with a heavy leather glove!
    I think the only other option is drill em out and tap oversized.
  • Ole-Timer
    Yep, I just took a look at the post. Indeed I pulled the aluminum mount off. I would have used a soldering iron to heat the screws first. It is hard to extract fasteners installed with red permanent thread lock.
    Im sorry to hear of your plight and have had similar issues at times. The 880Kv motor I used was one I had on hand so it was easy to ensure the prop shaft was adequately long. I do not recollect having any significant issues on the motor mod. What you could do is make a plywood stand off spacer, leave the aluminum mount on the motor, and adapt the spacer to both firewall and mount. I’d be finding a way to percevere no matter what my course of action is.
  • Boots Whirlygig
  • Boots Whirlygig
    You said on post #50 you removed the X-mounts from both motors and swapped them. The small counter-sunk screws used to attach the mount on the FL motor are what broke and unless I can disassemble the motor and extract them I need a new motor.
    Another issue is the FL 3648 830 motor has a much shorter prop shaft that does not clear the cowl. Maybe the prop adapter is longer on the 880 motor.
  • Ole-Timer
    If I did remove it then I would have done what has become standard practice. So many of these motors with the mounts attached have had the red permanent thread lock used on them. That coupled with cheap screws can cause issues. Direct heat must be applied to each screw to break down the thread lock first. I use an old soldering gun and really heat the screw up before I attempt to remove them.
    So the mount holes are different to the firewall? I don’t remember, I thought I just used the mount that came with the motor. Rather than buy a new motor I’d just fill the holes in the firewall and drill new ones to match at this point if they are a different hole pattern.
    Without taking my model apart all my similar motor to firewall mounts in stock have the same hole patterns. Unless something has changed recently...
  • Boots Whirlygig
    So Ole-Timer, did you run into any trouble removing the X-mount screws from the FL3648?? I decided on using a FL3648 830 and when trying to remove mine, two out of the four broke off! Now I have to order another motor!:Angry::Loser:
    Any suggestions before ruining another motor would be much appreciated!
  • Boots Whirlygig
    Originally posted by Ole-Timer
    Spot on but...
    He has turned his AT-6 into a Zero and as they had 3 blades, hence his need for some proverbial custom parts. Although Hollywood AT-6 Zeros still used the two blade...
    :Silly:
    Well it’s a work in progress. A couple made for the movie had geared R-1340 with constant speed 3 bade Hamilton’s and were used for the close up glamour shots!
    It would be hard not to bounce on that pavement.
  • Ole-Timer
    While both are available I used our rough runway as it provided the most bounce factor, grass will help muffle it a bit. Grass will have to be trimmed short as the prop really hangs down on this bird.
    You can see how rough our pavement has gotten. It’s why I’ve been shifting to bigger models. We have no control of paving as it’s owned by County Parks... Perhaps we’ll be all grass with a rock runway soon.
ID:	162643Click image for larger version
    Taming the AT-6 kangaroo hop during landings...
    Looks like good info. Are you flying from/to paved or grass runway?
  • Ole-Timer
    I would like to point out that the T-6 never had a three bladed prop, so if you're wanting to keep the scale looks stick with two blades.
    Spot on but...
    :Silly:
  • Ole-Timer
    I just got back from flying this bird and wanted to share my experience with hopping down the runway as I just performed 20 some landings and caused it to bounce!
    As a personal rule for landing all my prop airplanes, I do not drag my final legs out. By the time I make my turn from base to final I’m within 50 to 100 ft of the end of the runway and I already have the airplane configured gear and flaps so I can focus strictly on the final glide slope, I have just a whisker of power on as necessary, and I’ve now picked my spot where I expect to enter ground effect then glide to touchdown. Ground effect occurs when you’re within one wingspan of the ground. The general effect is like riding on an extra pillow of air and your model now floats longer than you had expected... Heavy warbirds with high wing loads require more power on final glide slope and power during the entire transition through ground effect. Medium weight warbirds also require some power throughout landings. This AT-6 has a light wing load, even with the 4s set up. It needs only the smallest amount of power during its final decent and before you enter ground effect, kill the power and learn to just glide it in through ground effect. As she settles toward the ground begin to flair about 6 inches above the ground but don’t let it stall until her wheels are literally on the runway. Once you learn this technique on the AT-6 all your landings will be greasers. If you try to ride power in with the light wing load she just does not want to settle properly and the end result will be hopping. It doesn’t matter if flaps are up, half, or fully deployed, the results are the same. Kill the power before entering ground effect and ride her down or your most likely gonna be hopping. It’s a lot more like landing an Apprentice than a warbird...
    I strongly recommend if you are the type that flies really long and drawn out final approaches like a jet would, to please reconsider and adopt a closer pattern. Unless of course your actually flying a heavy jet model.
    I have just one propeller airplane that I use a slightly longer approach with and that is the P-38 due to its heavy wing load and higher landing speeds. She’s power on all the way to touchdown.
  • dkalwishky
