PIC OF THE DAY..
  • hotrod23t
    tow sled v 3 replaced release servo with an old retract works great
  • Pauly
    That looks good Hippie!
  • Hippie 64
    Thank you Callie for the graphics
    Bryan
  • BluesDragon
    Lookin' good there, Hoomi... :Cool:
  • Hoomi
    Photos of the Dynam Waco getting closer to being ready for her maiden flight. I could balance and fly it as-is, but I want to finish my customization before her first lift-off. This morning, however, she got to pose in the sunlight, flex her controls a few times, and taxi a few feet under her own power. My wife is going to make my custom decals on her Cricut, which will include a custom plane number, rather than the stock N7020L from the decal kit. As such, I cut the side-stripe decals and just applied the front part, leaving me plenty of room for the planned custom decals. Once I have the pilot figure finished and installed, and the wing rigging installed, I can final-check the CG and adjust as needed.
    I'm really enjoying this project, even if Dynam's instruction manual leaves a LOT to be desired.
  • hotrod23t
    JUST FINISHED THE RELEASE AND SPRING LOADED DROP RAMP NO NEED FOR HOOK UP FLIGHTS OVER NO REASON TO SAVE BATTERY THEN.... DRIVE IT BACK
  • BluesDragon
    Very nice! Now if you can just make it hook and release on it's own... :Smug:
  • hotrod23t
    VERY COOL Dodger....... check out my new project a jet tow sled this is first test HAY GUYS CHECK THIS FORD BRONCO TOWS F5
  • Hoomi
    My current flying collection.
  • crankestein
    Four stroke day
    not mine, belongs to a friend
  • CZ Flyer
    Originally posted by hotrod23t
    dont know what haaped there..but yes thay survived with the heip of some glue and yes that is exactly what happed to the gear. might shim it up a little that works sometimes. hope to get in some flying this weekend weather been bad
    Me too! I just took off the flimsy plastic cover & pull that sucker forward. Flies fine without it.
  • hotrod23t
  • hotrod23t
    So your ventral fins survived the belly landing? Same thing happened to my brand new one on its 4th flight! 3rd landing was lousy so the nose gear got bent back a hair causing it to jam in the retracted position. I check for retract function after every landing now, but when I discovered the problem I opted to leave the mains down to save the ventral fins, but the nose cone dug in instead, so I had to fix that too.[/QUOTE]
  • CZ Flyer
    fouled nose wheel.:Angry:.%&*$$#@!&&^%$$.used plane ..no damage :):pop
    Weapons arrived
    Then shootem! Lol
  • crankestein
    Pic of the day...
  • hotrod23t
    Weapons arrived
  • hotrod23t
  • hotrod23t
    gear upgrade and weapons set arriving today:Cool::Cool::pop
  • hotrod23t
    THANKS.... just cant see them... old eyes ya know
