Key Features
- A scale replica with STOL capability and all-terrain versatility
- More powerful brushless motor, 3-blade propeller and 40A ESC
- Receiver-ready with five-channel control including functional flaps
- Scale detail, authentic corrugation, rivets, plus a well-appointed cockpit
- Sleek turbine-power appearance features matching prop, intake and exhaust detail
- Functional LED navigation, anti-collision and landing lights
- Two-piece wing with carbon fiber spars, hinged flap and dual-servo ailerons
- Wing fences improve low speed performance and make landings easier
- Durable landing gear with large tundra-style tires and a steerable tailwheel
- Includes matching float set with water rudders for great surface handling
- Factory-finished with a vibrant paint scheme and graphics
- Easy assembly—can be ready to fly in less time than it takes to charge a battery
Overview
No other aircraft in the North American Territory has made greater community impact serving its pioneers than the De Havilland DHC-2 Beaver. Refurbished versions can be upgraded in many ways, including conversion to turbo-prop engine power. The Flyzone® DHC-2T Turbo Beaver 1.5m delivers a realistic looking model of the outback master with smooth running turbine engine power capable of speeding in and out of any terrain in the territory.
The Flyzone® DHC-2T Turbo Beaver 1.5m Rx-R is a scale replica of the legendary bush-plane equipped with the most popular STOL extras. Loaded with scale detail upon an authentic outline, from the well-appointed cockpit to the intricate surface features, you’ll be proud to show this model off. At the work bench, it’s a model that takes shape fast with assembly that’s basically a bolt-together process. Two-piece wings are a big part of this model’s convenience along with a completion level that includes a factory-installed power system and servos that are ready for your receiver and battery. The more powerful brushless motor and 3-blade prop deliver the performance punch that inspires bush pilots to take on all conditions and terrain, while operational flaps and built-in wing fences improve slow speed handling. And with the factory-installed LED navigation lights, you don’t have to stop the fun when the lighting gets low. Rugged aluminum landing gear equipped with large tundra-style wheels make it possible to fly from just about any airstrip. But if that’s not enough to excite you, you can also enjoy flying at a pond or lake by bolting on the included floats equipped with dual operational water rudders.
