Tengarang's Avenue concerning Lord Emperor Teng's Weekly Field and Hangar Maintenance Activity
For information Only, my recommendations for places to fly in the Californian Bay Area
https://www.hobbysquawk.com/forum/rc...225#post193225
Dynam Gee Bee Dropping Bombs
Future modifications. Hook up each bomb bay compartment to its own Auxilliary port such that two bomb run passes can be made and also assign a switch to both auxiliary ports to mix the function for dual bomb drop release at the same time. 10 Channel Lemon RX, is currently out of stock at Motion RC. But the receiver and satellite combo can be purchased at Amazon.
Note the 10 channel Lemon RX will not be equipped with a stabilizer like the lemon 6 channel counterparts. I also recommend adding the dsmx satellite receiver in any case.
Modified EFL8950 E-flite P-51D 1200mm // 1050KV BL15 Eflite Outrunner // FMS/Eflite/RocHobby 10.5x8x4 prop
Exciting news on the fifteenth of May 2019
MRC has released the Heinkel He111 1750mm (68.9")
I will be moving forward with the following setup BOM (Bill of Materials Below)
-Motor 3648 770KV with M6 threaded shaft to fit the stock spinner qty = 2: https://amzn.to/2LGqvLY
-FMS 10.5x7 3-Blade Propeller qty = 2: https://amzn.to/2YAxh7N
-Castle Creations CC Bec 10A 6S Switching Regulator: https://amzn.to/2LULoD8
-retracts standard qty = 2: https://www.motionrc.com/collections...pare-parts-tab
-Digital high torque Servos: https://hobbyking.com/en_us/turnigyt...sec-22-5g.html
-Motor shaft without hex for the 4 screw footprint of the 3648 770KV qty = 2: http://smallpartscnc.com/index.php?r...product_id=175
-Battery 3s qty = 2: https://www.motionrc.com/products/ad...xt60-connector
-Battery 4s qty = 2: https://amzn.to/2VBnL7j
-ESC first choice: FMS 70A with 5A SBEC https://amzn.to/30vSoKe
-ESC second choice: https://www.motionrc.com/products/zt...c-with-5a-sbec
-6800uF bypass cap to combine esc SBEC and 10ACC BEC external voltage stablization to rx for insurance: https://amzn.to/2LYw5tx
-Miscellaneous power cables and Y-harness
- Likes 7
ki-61 spinners can for the HE-111 can be found on amazon. they are 50mm at the back plate of the diameter which should look scale to the German version of the HE-1112 Photos
https://www.facebook.com/groups/moti...0843884397198/
Before I start another post about the HE-111 i want to say if you plan on using a motor with M6 or 6mm Shaft and you are not planning on doing any custom CNC machining to elongate the prop adapter for the 6mm threaded shaft such that the FMS STUKA Spinner (65mm) https://amzn.to/2LSEEG8 and 3-piece prop https://amzn.to/2W5ZFB2 could be used then my suggestion is to go ahead and go with the stock spinner that comes with the ARF kit which is what I am likely to do since I plan on using the Eflite BL15 850KV motors (https://www.motionrc.com/products/e-...utrunner-850kv) with the standard shaft size. which is pretty much equivalent in dimension to the recommended motor Admiral GP2 3520-950kV Brushless Motor (https://www.motionrc.com/products/ad...rushless-motor)
After learning about the open diameter of the cowling is slightly larger than 75mm, I revisited this topic again to come up with an even better solution to help achieve the scale look as much as possible. Reference the .pdf manual below.
https://cdn.shopify.com/s/files/1/10...111_Manual.pdf
When using the Dynam hurricane Spinner which is measured to be 65mm. The cowling opening itself is a bit larger than 75mm, which means there will be a ( ~10mm = 0.4inch) gap between the spinner and the cowl opening. In my opinion, this would look a lot better than the aforementioned KI-61 FMS spinner because it's only either a 50mm or 55mm maximum diameter which in turn will leave a gap that is bigger than I would have liked. Hence taking another look at alternatives with regards to the spinner backplate diameter. This also means the scale look will also call for a fitting prop which brings me to the conclusion of using the 13x7x3 Dynam one-piece prop and the Dynam hurricane spinner set. The center hole for this mechanicals requires an M8 or 8mm diameter opening which means we will then need to pair these components with a motor that will employ an 8mm or M8 threaded shaft. I have seen pictures from a fellow hobbysquak member shows his Graupner HE-111 which I have come to learn is the predecessor model of the black horse release shos a 11x7x3 MAX prop. Go to post #3511.
https://www.hobbysquawk.com/forum/rc...900#post194900
As you can see from the photo with the 11-inch prop, there is still a bit of clearance between the prop tip and the fuse itself.
I have a few motor combinations I found online below to drive the 13x7x3 dynam prop, depending on your budget and or component availability inside your hangar/manufacturing plant.
Dynam Hurricane Spinner
Dynam 3Blade 13x7x3 prop
3s and 4s will require at least two 4000mah 3s or two 3300mah 4s packs. Required ESC will be 80A
FMS 4258 650KV
Freewing 4250-580kV
3s and 4s will require at least two 4000mah 3s or two 3300mah 4s packs. Required ESC will be 70A
Turnigy Aerodrive SK3 - 4240-620KV Brushless Outrunner Motor
3s and 4s and 5s will require at least two 4000mah 3s or two 3300mah 4s packs or two 5s 1800mah to 2800mah packs Required ESC will be 80A
PROPDRIVE v2 4258 500KV Brushless Outrunner Motor
FMS 4258 550KV Brushless
https://www.motionrc.com/products/fm...rushless-motor
Originally posted by OV10 View PostA vessel is a ship or a large boat ;)and I didn't see any seaplanes in that list LOLDirected by Erik Nelson and featuring newly restored footage shot by Oscar-winning director William Wyler, The Cold Blue is a meditation on youth, war and tr...
I have started the accumulation and testing of parts for the soon to come HE-111 twin-engine German Bomber from the second world war.
The Dynam Hurricane Spinner (65mm diameter) with the Dynam standard prop 13x7x3 will be employed to load the NTM 4238 750KV outrunner. Two 3s (12.6V no load // 11.1V under load) in parallel will be powering the twin bomber
NTM prop drive 4238 (42mm diameter) x (38mm Can Length)
https://hobbyking.com/en_us/propdriv...ner-motor.html
Dynam FW-190 5mm shaft to 8mm (M8) pressure fit prop adapter https://rover.ebay.com/rover/1/711-5...UAAOSwHMJYGkTl
Lemon 7channel RX with Satellite https://amzn.to/2HtwPSO
According to various sources on https://www.hobbysquawk.com/
the 13x7x3 inch prop will be big enough to clear the ground on take off as long as the tail does not go above the horizontal horizon.
If somehow there is an unforeseen mechanical issue with the 13x7x3 prop which has a prop loading factor of 21749.19038
We can also retrofit the HE-111 with a smaller parkzone prop 10.6 x 7.8 x 3 which has a prop loading factor of 13137.93765
The difference in prop loading facto is a whopping 8611.25273
which means if the smaller prop is used then a 4s 4000mah pack will be employed for flight operations.3 Photos
Originally posted by Marco Polo View PostWhere is this field?
