Official Freewing 1400mm Pandora 4-in-1 Thread
  • Jay454
    • Mar 2021
    The Pandora is the plane I was trained on and would consider myself an intermediate pilot at this time but I still like flying this plane in the low wing tail dragger configuration. However, I would like a little more power by using a 2200 4S instead of the recommended 3S. I'll be updating the ESC to 50AMPs but was wondering if anyone had any recommendations on a motor as I assume the bigger battery won't be good with the stock motor.
    Thanks.
    • NHcowboy
      • Apr 2021
      Just a quick PSA - I used a little purple loctite (the weakest one) on the screws holding the wings on (the small screws that go into the plastic tabs) and 3 of the 4 tabs broke. No impact or stress on the tabs - literally broke while sitting on a table. Looks like Loctite made the plastic swell & break right at the metal threaded inserts. I'll be permanently glueing this set of wings on. If you want to put something there to keep these tiny screws from loosening, try something else.
      • boomer108
        Chief Boom
        • Apr 2014
        • 868
        • Chicago IL.
        Use Foam Tac on plastic surfaces. It will keep the screws tight but you can easily remove them. All Loctite products will melt plastic.
        • Steve53
          • May 2021
          Hi I love flying my Pandora, I did have a little crash and now I have a problem. I hit a power line and I was moving at a pretty good clip. Anyway my problem is now my motor mounting plate in the plane is loose. I need to figure out how to make this more steady, way to loose to fly this way. I am thinking of putting some spray foam behind it to push it forward. Any thoughts would be grateful. Thanks in advance.
          • boomer108
            Chief Boom
            • Apr 2014
            • 868
            • Chicago IL.
            Steve53 welcome to the Squawk. Foam will eventually wear down from vibration and the mount will be loose again. Try epoxy or gorilla glue and hold the mount in place until the glue sets up. Good luck.
            • Steve53
              • May 2021
              Thanks I'll try glue first.
              • use2busa
                • May 2021
                • 12
                I was really enjoying this plane all the way up till I flew it into a tree way down at the end of the field that I fly at. Kinda sucked. ok well not kinda. it did. loss of depth perception. Never could find the darn thing. The problem was made even more difficult because the tree line is covered up with underbrush and debris from a series of tornado's that came through a few years ago. I thought about buying something else but decided that this plane is still the best plane for me as a beginner. Have to order another one now. Was doing pretty good too otherwise. Its funny to say but I really did not see that one coming. lol. I really thought I knew exactly where it was in the sky. Clearly not. I just dont know how to correct that kind of mistake. Oh well Ill figure it out.
                • chaepli
                  • Sep 2021
                  Hy guys. Any insights | experience | feedback using a TWO blade prop (= APC 11 x 7) with the standard ESC - motor combo - instead of the 3 blade one?
                    • 8835
                    Stock prop is 11 x 6 x 3. Rule of thumb ................... If you go down one blade, you can go up one diameter OR go up one pitch without changing motor or ESC, so IE ................... 11 x 7 x 2. Always balance any prop.
                      • 7438
                      Stock ESC is 30 A if I remember right. It's pretty close to the lower limit of acceptance. I upgraded to a 50 A and one of mine is using the motor out of an E Flite Spitfire. I could run that one 4s with a five blade prop on it, might be interesting... problem is the spinner.
                      • boomer108
                        Chief Boom
                        • Apr 2014
                        • 868
                        • Chicago IL.
                        I did the same with my Pandora. I upgraded to a 50A ESC and put the motor from the Roc Hobby Waco. A definite improvement.
                          • 7438
                          Did the same with P-1 Waco motor and 50A ESC. Great combination!
                          • heliguy67
                            • Aug 2020
                            I have misplaced my 2 wing mount screws. Does anyone know the size of the screws?
                            • boomer108
                              Chief Boom
                              • Apr 2014
                              • 868
                              • Chicago IL.
                              They are PM3 25MM.
                              • Brian L.
                                • Dec 2024
                                I'm thinking about buying this bird for my son. will it work with Tactic TTX600 radio and receiver?
                                • ridgerunner
                                  • Nov 2017
                                  • 275
                                  • Central Utah, USA
                                  Yes. Any radio with 4 or more channels should work (the Tactic TTX600 has 6 channels). The Pandora is a very good first plane.
                                  What a great Dad!
                                    • 7438
                                    I agree, a great way to start! Still have my two and they are like 10 years old by now. Haven't flown either in a while now, but every once in awhile they're worth taking out and playing in the wind.
                                    • FR4-Pilot
                                      • Aug 2019
                                      • 6
                                      • Lombard, IL USA
                                      Flying this plane again after 7 years hiatus. Upgraded power system to 4S - what a difference!
                                      Forgot how awesome this plane flys - now it has respectable climb out capability.
                                      Good to see it and parts still in stock at MotionRC :)
                                        • 7438
                                        I've been thinking the same thing, what size battery did you use?
                                        • FR4-Pilot
                                          • Aug 2019
                                          • 6
                                          • Lombard, IL USA
                                          I’m using these small Ovonic 4S 1300mAh 100C packs. Good for about 3-3.5 minutes. They’re only like 150g.
