View Post
That's what I'm considering doing, as the manual for the MicroVector says that the GPS needs to be mounted at least 3.5" away from anything that could produce RF noise (antennas and high current-carrying wires the big 2), and for it to be higher than any other antennas. I was originally going to run a super long lead and mount the GPS on the horizontal stabilizer, but then I realized I could feed the antenna wire down through the canopy and leave it pointing downwards at the very back of the component bay. So then if I mount the GPS where you did it's higher than the vTx antenna. The only thing I'm worrying about now is interference. Do batteries put off the same field that battery wires do when current is passing through them?
I wonder if I could get away with mounting the GPS on the foam about 2" back from the batteries on the extreme right side, run the power cables down the extreme left side, and using two ferrite chokes at both ends of the GPS wire harness.
