NEW Seagull Cessna 337 Oscar Duece
  • WAYNE888
    • Jul 2018
    • 62
    • Coastal Florida
    VQ told me, late November at my door
      A month to go from Texas to Florida. :rolling_eyes:
      Ya maybe wanna check out Gator RC. Same price and in stock.
      https://www.gator-rc.com/seagull-ces...ymaster-sea146
      • WAYNE888
        • Jul 2018
        • 62
        • Coastal Florida
        ahh yes.....but VQ has my funds
        • WAYNE888
          • Jul 2018
          • 62
          • Coastal Florida
          the end of November came fast this year......it arrived today. Fed ex emailed me yesterday, it would be here Thursday....new email today.... SUPRISE!! and we need a signature...…. well it is here.....all intact and it looks pretty nice
          • TwistedGrin
            Hobby Squawk..... CLEAR!!
            • 376
            Sunday 10-25-2020 .....Assembled the Cessna 02 at the field for it's 7th flight of 2020 before the Texas wet winter cold drizzle set up just an hour later. Toggled my Hobby Eagle A3L to stabilizer Armed position. The aircraft took off with a little bit of wing rock...not too violent. I did notice some waggle and wing rocking in flight that was not present the last time I flew it with stabilizer. Landing at six minutes just doing normal pattern runway passes...I noticed that my DX8 Stabilizer Gain Knob was set to zero....so that explains the not so smooth flight. The stabilizer was on ZERO GAIN. At least the take off was not so violent as I used all of our runway to take off with a very long and shallow rotation......I think this is the best strategy for my bird. Next time I will not be so apprehensive and....will have the stabilizer engaged with the proper gain for conditions.
            At least another successful flight and landing is in the log book
            TwistedGrin
            • TwistedGrin
              • 376
              Posting some activity of my electric set up Cessna 336 02 from earlier this year and club member gasser set up:
              08-24-2020 Maiden Take off: https://youtu.be/G1clfdx1zK4
              08-24-2020 Maiden flight and landing: https://youtu.be/dYcDiP6_Rjw
              08-28-2020 Flight: https://youtu.be/WyvFZYwaj28
              03-22-2020 Bob Mueller gasser flight: https://youtu.be/G9FkgVGZ5sM
              Set up:
              E-flite Power 52's
              Dual 5s 35c 5200mAh LiPo (EC5)
              Dual 80amp ESC's
              6.0v 2300mAh receiver battery
              14x7x3 MAS tractor/pusher props
              Hitec HS -645MG servo's
              Hitec HS-225MG servo's
              Mpi receiver power switch
              Electro Dynamics "One Click" 3 servo wing wire connectors
              14.4lbs All Up Weight
              COG 80mm from main wing leading edge
              Motor Wattage readings: Both motors require connected in order for the RX to engage throttle....
              100% Throttle:
              72.17Ap
              1406.5Wp per motor
              0.071Ah
              1.4Wh
              Click image for larger version  Name:	The twin 02's.jpg Views:	0 Size:	107.0 KB ID:	282700Click image for larger version  Name:	09-06-2020.jpg Views:	0 Size:	39.7 KB ID:	282701
              • TwistedGrin
                • 376
ID:	282741Click image for larger version
ID:	282742Click image for larger version
ID:	282743Click image for larger version
ID:	282744IMG_3324.JPGIMG_3332.JPGIMG_3329.JPGIMG_3330.JPG The oddball nose gear steering servo placement is the only real detractive on this aircraft as the servo is mid-center fuselage under the cockpit floor. This requires a long control rod forward into the motor mount for the nose wheel which is prone to bending and prevents full movement due to the odd angle when full right input is required. Additionally the long nose wheel steering control rod is in competition for space of the tandem flight batteries. I am able to place the batteries in the forward bay but they must be placed as far rearward as possible to achieve the appropriate COG. The batteries are angled together towards aft and can't go back any further as they hit my ESC's mounted on flat on each side of the electronics bay tray. This is not optimal but it all works for access and COG.
                TwistedGrin
