DVIII
    Coming along very nicely!
    The D-VIII is such an iconic WWI bird. I still miss my 1/3 scale. Rumor has it that BUSA may be coming out with a 1/3 scale D-VIII kit. Just might have to build a new one.
Name:	Last Flight2A.jpg
    Click image for larger version  Name:	IMG_20190617_101241162_HDR.jpg Views:	0 Size:	227.4 KB ID:	290147
    • Mad Baron
      132 Aviation
      • 547
      • McMinnville Tn.
      Nice looking plane. Looking forward to getting mine finished and flying.
      • Mad Baron
        132 Aviation
        • 547
        • McMinnville Tn.
        Getting closer!
ID:	292617Click image for larger version
        Hopefully I will get it ready for the maiden flight soon
        • Mad Baron
          132 Aviation
          • 547
          • McMinnville Tn.
          It is 95% ready just waiting on graphics from Callie and a few more things to do on it.. I checked the balance on it and I just need to add a little nose weight, got the radio system working. Just have to wait on the weather now its too cold and windy here.
ID:	294866Click image for larger version
ID:	294867Click image for larger version
            Lookin' Good! Needs a pair of Spanduas under the wing though
              • 4865
              MB, Beautiful model and ditto on adding Spandau's Maxim LMG-08 gun, but was there one or two? Matters not...Bravo Zulu, Sir. Best, LB
              • Mad Baron
                132 Aviation
                • 547
                • McMinnville Tn.
                I have 2 Spandau gun kits that I have to assemble and install
                That is one of the items I have to complete on it.
                • Mad Baron
                  132 Aviation
                  • 547
                  • McMinnville Tn.
ID:	314467Click image for larger version
                  I have the Spandau guns installed and the graphics applied. Just got to wait for a decent weather day for the maiden! I have to clean up the aileron wires yet.
                    Looks great! Good luck with the maiden.
                    • Mad Baron
                      132 Aviation
                      • 547
                      • McMinnville Tn.
                      Here is some pics outside in the sun. I shouldn't have any problems seeing this one in flight.
ID:	314543Click image for larger version
                      • Mad Baron
                        132 Aviation
                        • 547
                        • McMinnville Tn.
                        A year of work shot:rage:
                          Mad Baron This doesn't sound good.
                          Does it look anything like this? You may remember my 1/3 scale D8. I feel your pain brother
                          Click image for larger version  Name:	IMG_20190620_145059237.jpg Views:	0 Size:	150.4 KB ID:	315269
                          • Mad Baron
                            132 Aviation
                            • 547
                            • McMinnville Tn.
                            Never got a chance to fly it. The plane is too tail heavy. I hung 6oz on the prop and it just barely was level. I feel that it would need 6-7oz of nose weight and that will add a lot of stress on the landing gear and the wing struts. It hurts to look at your plane I always hate when I plow one into the ground.
                              Mad Baron I know that seems like a lot of weight, but for this, and similar, airframes, it's not bad. A pound or more is normal for WWI birds at 1/4 scale. My 1/3 scale was flying with 7.5lbs of lead in the nose. Add what's needed and enjoy it. It's too nice a bird to be a hangar queen.
                              • F22trainer
                                Piper PhD
                                • Mar 2018
                                • 1484
                                • Sun City, Az
                                :cry:
                                • radfordc
                                  • 375
                                  • Lansing, KS
                                  Here is the problem...you need a bigger heavier motor. Will the 26 fly it....maybe. But a 35-45 would do so much better. Six ounces of weight on a plane this size is nothing. I added about 2 pounds to the nose of my BUSA 1/4 scale SPAD.
                                  • Mad Baron
                                    132 Aviation
                                    • 547
                                    • McMinnville Tn.
                                    I do have a Zenoa engine but it has the same weight as the NGH engine that I have in it. I moved the plane to the back burner for now. Have some other things come up that are a little more important.
                                    • Mad Baron
                                      132 Aviation
                                      • 547
                                      • McMinnville Tn.
                                      I finally got my DVIII balanced and ready for the maiden flight. I took off the NGH engine and installed my Zenoah 26 engine. The Zenoah was 2lbs heaver than the NGH engine. I still had to add 30oz of weight to it, it took a quite of more nose weight than I thought it needed. Looking forward to the first flight!
                                      Click image for larger version  Name:	dv8balance.jpg Views:	0 Size:	69.1 KB ID:	318382
                                      • Mad Baron
                                        132 Aviation
                                        • 547
                                        • McMinnville Tn.
                                        Got the maiden flight in today on the DVIII! It flew very well but still seems a little tail heavy but I did get a 5 minute flight in and greased the landing...it was a good day except for my OV10 it had a rough landing and snapped the pin on the nose gear
                                          Congrats Mad Baron ! Looks great out in it's natural habitat.
