Official Black Horse 2276mm P-40 Warhawk thread
  • Michael Rader
    • Nov 2020
    • 27
    • Chicago
    Started hinging
    • Terminater007
      • 109
      For a Spinner u could get the one from Sark Hobbies its 113mm
      Curtiss P-40E Kittyhawk (65.25") - Aluminium Spinner Set - Sarik Hobbies - for the Model Builder
      • Michael Rader
        • Nov 2020
        • 27
        • Chicago
        Made some progress last week. Wing surfaces hinged, servos and retracts done. First test fit with the fuselage.
        So far a great kit and a lot of fun during building.
        Michael
        • Michael Rader
          • Nov 2020
          • 27
          • Chicago
          Motor arrived today.
            • 8218
            I think you could launch the Space Shuttle with that thing.
              • 4845
              Originally posted by Michael Rader
              Made some progress last week. Michael
              MR, Looks like you're making good progress. That motor is enormous, which prop are you planning on using? I really love the "Warhawk" and in RAF desert camo it's a beauty. Best, LB
              • Michael Rader
                • Nov 2020
                • 27
                • Chicago
                Hello Elbee,
                thank you, doing the best I can in between working and homeschooling of my little ones. I ordered an XOAR 24x10 wood WW2 Prop pre drilled for an DLA 55. I measured it and this should fit for the motor. If this is successful I will share this with Motion as the Customer Service did not know if this will fit. 😜
                I put my electrics to the fuselage yesterday. I will share a picture later today.
                • Michael Rader
                  • Nov 2020
                  • 27
                  • Chicago
                  Servos are in the fuselage.
                  • Foxbow
                    • Jan 2021
                    • 8
                    Definitely following. I’m thinking about the electric vs the gas and highly interested to see your setup and hopefully video. Flying 12s I assume? Also check the ply servo tray, a YouTube video shows one crashed because of little or no glue securing the tray.
                    • Michael Rader
                      • Nov 2020
                      • 27
                      • Chicago
                      Hi,
                      yes I will start with 12s 5000mAh. Ordered a Graupner 160A+ ESC, so I have Full Telemetry with radio.
                      I recognized that the trays for the elevator a bit weak, did not reinforce so far but I will.
                      Do you have a link to this You Tube, very interested in.
                      Some small progress, test fit the horizontal stab 1000 times, tomorrow I I will Epoxy it.
                      • Foxbow
                        • Jan 2021
                        • 8
                          • 4845
                          Foxbow, Welcome to Hobby Squawk, Sir. Thank you for the short video, though was the loose servo tray the 'cause' of the crash or part of the result? Glad to have you onboard. Best, LB
                          • Foxbow
                            • Jan 2021
                            • 8
                            According to the comments in the guys video channel, he said that he neglected to check the glue and it caused the servo to lose its base which meant that when he applied inputs it was not able to allow the plane to respond to them causing the crash
                            • Foxbow
                              • Jan 2021
                              • 8
                              It was the elevator service by the way or least what caused the crash
                              • Michael Rader
                                • Nov 2020
                                • 27
                                • Chicago
                                Horizontal Stab is fixed.
                                Test fitted the Prop.
                                • Michael Rader
                                  • Nov 2020
                                  • 27
                                  • Chicago
                                  Small progress this week.
                                  Rudder and elevator in place.
                                  Next step pushrods and tail gear.
                                  ESC arrived this week🤩.
                                    Elbee commented
                                    Editing a comment
                                    One step in front of the other. Looking good. Best, LB
                                • Michael Rader
                                  • Nov 2020
                                  • 27
                                  • Chicago
                                  Some progress the last days. I love this plane.
                                    • 4845
                                    Michael Rader, very nice. Best, LB
                                    • Michael Rader
                                      • Nov 2020
                                      • 27
                                      • Chicago
                                      Thank you
                                      • Michael Rader
                                        • Nov 2020
                                        • 27
                                        • Chicago
                                        The motor met the fuselage today.
                                        Put my receiver and gear battery to the front, hope this will help with the CG. Did some wiring in the fuselage.
