Corona Build 1/4 Scale BUSA SE5A
  • MikeT
    Here......Hold my beer.
    • 1060
    Originally posted by boomer108
    Your pilot definitely has a ghostly pale about him but not everybody is an artist I know I'm not. Hang in there.
    I've got some shading to do on it and I'm studying up on just how to do it. These guys were covered in dirt , grime and oil after a mission that's the look I'm after.
    Mike
    • MikeT
      • 1060
      Corona build. Been awhile since I updated this. Built a windscreen , started joining wings and finishing up the ribs for the center section. I'm running out of parts.
      Mike
      • Prowler901
        • 940
        • Gunnison, CO
        Coming along nicely.
        • MikeT
          • 1060
          Fitting the bottom wing and setting the incidence on the top wing.
          Mike
          • tomsza
            "Yes dear, another plane."
            • Dec 2021
            • 3
            How's your progress? I just started building this kit and wondered if you trimmed the back of the stab supports? Laid on the plans they look too long, but trimming that much from a laser cut piece is weird, and there's no mention of trimming it in the assembly manual.
            • Mad Baron
              132 Aviation
              • 547
              • McMinnville Tn.
              Is it a Balsa USA plane? I just recently completed my Balsa USA Fokker DVIII. I had a couple of discrepancies where the plans didn't match up exactly with a part, so I went with the dimensions of the part. In the manual under "About the Plans" paragraph it states to go by the parts since the plans can still expand and contract with temperatures and humidity. Hope this helps you out. Look at MikeT post number 10 on the first page it shows the part you have a question about.
              • MikeT
                • 1060
                About finished. Covering done. I'll post pictures in a couple of days . Plans shrink so I build to parts but sometimes adjustments need to be made. If I remember correctly I did trim the stab supports. Check the horizontal fit than adjust for there.
                Mike
                • MikeT
                  • 1060
ID:	333600Click image for larger version  Name:	IMG_0551.JPG Views:	0 Size:	58.5 KB ID:	333598Click image for larger version  Name:	IMG_0553.JPG Views:	0 Size:	54.9 KB ID:	333599Click image for larger version  Name:	IMG_0552.JPG Views:	0 Size:	62.0 KB ID:	333601 Here's a few more pictures. I made brackets and new struts because I just didn't care for the music wire ones.
                  Mike
                    Looking Good Mike!
                    • MikeT
                      • 1060
                      . Click image for larger version
ID:	334503Click image for larger version
ID:	334504Click image for larger version
                      Still plugging away getting closer to the end.
                      Mike
                      • MikeT
                        • 1060
ID:	336184Click image for larger version
ID:	336185Click image for larger version
                        Flying wires done. Need a few more odds and ends , mount the motor than go though it again. Ready for the maiden flights in a few weeks.
                        Mike
                          Turned out great! Best of luck with the maiden.
