Official Nexa 1500mm P-47D Razorback "Touch of Texas" (Balsa ARF) Discussion Thread
    Nexa P-47 Razorback "Touch of Texas" 1500mm (59") Wingspan - Balsa ARF
    Click image for larger version  Name:	mastera.jpg Views:	17 Size:	69.6 KB ID:	253570
    Product Availability: The estimated time of arrival (ETA) for this product is late-May, 2020. Please click the "Notify Me When Back In Stock" button above to receive an email notification when the product is available for purchase.
    The Republic P-47 Thunderbolt was a World War II-era fighter-bomber aircraft produced by the United States. Renowned as a hardy and versatile machine, the P-47 could carry up to 2,500 pounds of external ordnance in addition to its eight .50 caliber machine guns. Propelled by the stalwart R-2800 Double Wasp engine that also powered the F4U Corsair, F7F Tigercat, and many other aircraft, the P-47 was one of the fastest and heaviest single engine fighters of the war, seeing service in all theaters of the war as a bomber escort, reliable ground attack platform, and lethal dogfighter. The P-47 Thunderbolt "Touch of Texas" was piloted in World War II by Captain Charles Mohrle of the 510th Fighter Squadron, 405th Fighter Group, circa 1944.
    We are proud to announce Nexa, Motion RC's in-house Balsa-specific brand that will showcase customer-favorites and new, never-before-seen models in various balsa formats and a wide range of sizes and price points.
    The Nexa P-47 is a .46–.55 size electric or gas option scale series warbird with a 1500mm wingspan, constructed primarily from balsa wood and covered with a fuel-resistant covering. This ARF requires assembly and installation of your choice of servos and power system, and includes flaps, painted pilot, machine gun, antenna and other scale details. The large battery hatch affords ample room for either electric or gas setups. To complete the scale appeal of this beautiful Razorback, the model includes electric retracts and scale struts. Impress at your flying field with this iconic stunner!
    Fully Covered and Detailed
    The Nexa P-47B comes fully covered in the "Touch of Texas" livery including simulated panel lines, rivets, nomenclature and weathering detail. The fuel-resistant covering is delivered in a satin finish.
    Scale Details Throughout
    There is no shortage of scale details with this P-47 including functional flaps, antenna, machine guns, painted pilot, electric retracts and metal main struts.
    Prehinged and Installed Control Surfaces
    All control surfaces come out of the box fully pre-hinged and installed for your convenience.
    For your convenience, electric main retracts with metal trunions are pre-installed. Say goodbye to servo-driven retract linkages!
    Center-Mounted Bomb and Wing Pylons
    To add to the array of scale detail, the Nexa P-47 includes a center-mounted bomb and wing pylons.
    FEATURES:
    • Attractive "Touch of Texas" livery flown by Captain Charles Mohrle of the 510th Fighter Squadron, 405th Fighter Group, circa 1944
    • Complete Balsa and lite-ply construction for rigidity and durability
    • Covered from tip to tail in scale details including weathering, printed simulated panel lines and rivets
    • Fiberglass cowling for strength and durability
    • The hand-painted pilot is ready for your added cockpit details
    • Center-mounted bomb and wing-mounted pylons for added scale detail
    • All control surfaces come out of the box pre-hinged and installed for convenience
    • Flaps, antenna, guns and more complete the fantastic scale appeal
    • Large battery hatch allows for your chosen electric or gas setup
    INCLUDES:
    • Nexa P-47 Thunderbolt "Touch of Texas" 1500mm (59") Wingspan - ARF
    • Electric retracts, wheels and struts
    • Fuel tank, hardware and servo trays
    REQUIRES:GAS REQUIRES:Customer Note
    Nexa ARF models are constructed out of balsa wood and plywood. These are not foam models. The assembly of balsa wood ARF aircraft requires basic model building skills including the installation of servos, ESC, and motor (or gas engine).
  • AceMigKiller
    Insta: Check5_Av8r
    • 175
    Super cool!
    Glad to see an in-house line of wood models!
      The ProFly Bronco, which will now come under the Nexa brand, was just the beginning. Much more to come, beyond what some of us may recognize. As I tell myself every day, "We're just getting started".
      • AceMigKiller
        Insta: Check5_Av8r
        • 175
        As I say when Alpha says stuff like that ---
        Aawwww yeeeeaaaa!
        • Nike_Belli
          • 38
          The Republic P-47 Thunderbolt was a World War II-era fighter aircraft produced by the United ... All the P-47s produced to this point had a "razorback" canopy configuration with a tall fuselage spine behind the pilot
          • ncflyer79
            Jarrod “P-47 Thunderbolt and Luftwaffe fanatic”
            • 42
            • Marion, NC
            Alpha I have their P47 Hairless Joe and i like it but it definitely needs some improvements on the wings. The main problem is the wheel wells. They have a wing rib running right where the wheel sits and because of it the wheels with gear doors on will not come close to sitting flush. Also the wheels are too small and grass operations are hard. The way the wells are made you cant enlarge to a larger wheel because the wells are too close to the leading edge of the wing. Also the wing has next to no dihedral and looks kinda odd. The top of the wing is flat across and the bottom has a little dihedral in it. In my honest opinion the entire wing needs to be reworked especially for long term grass flyers.
            • jwmulkey
              so how do this differ from the VQ model? it look 100% the same.
              • ncflyer79
                • 42
                • Marion, NC
                It is the same VQ model just renamed Nexa for Motion.
                • jrkennedy2
                  What is the optimum approximate weight of the brushless motor, ESC, and battery? I have a P-51 Berlin Express run as 6S. She was heavy and loved to tip-stall, possibly due to wing loading? But was she F A S T!
                  PS. Love the 4-blade on the P-47! My P-51 had a Master Airscrew 13x8 3-blade. I live at 6500' so the air is a bit thinner...
                  • Merry Boozer RC
                    Wesley
                    • Jul 2019
                    • 178
                    • Webster FL
                    🤦🏻‍♂️ Couldn’t take it I had to have it the crazy order button was officially pressed today. Really excited to get this one in the hanger hopefully we will unbox it live next week or the week after depending on shipping time. This plane has all the right lines and the paint job was calling me.
                    • ncflyer79
                      • 42
                      • Marion, NC
                      I had the hairless joe P47, I saw the touch of Texas scheme at Joe Nall last year at the VQwarbirds tent on vendor row. I about got it also lol.
                      • Johnnyrabuse
                        winner wolf
                        • Apr 2020
                        • 136
                        • NY
                        But it runs on fours :(
                        • ncflyer79
                          • 42
                          • Marion, NC
                          I ran mine on 6S. Wasn’t over powered but flew nice. Used the FMS 1500mm p47 power system and prop
                          • Merry Boozer RC
                            Wesley
                            • Jul 2019
                            • 178
                            • Webster FL
                            Sneak peek before the live unboxing Sunday. First impression is this airplane is gorgeous so glad I popped on this one servos are ordered and.... 6s power system on its way. I’m going to try to run the 1700mm FMS Corsair prop on her for scale looks. Anyway come by the live show Sunday for the unboxing and check it out in all it’s glory 😉
                            • ncflyer79
                              • 42
                              • Marion, NC
                              That is going to be a sweet setup!
                              • Merry Boozer RC
                                Wesley
                                • Jul 2019
                                • 178
                                • Webster FL
                                Papa did a fantastic build thread here on hobby squawk. But I wanted to add our final pictures here on the official thread. The airplane goes together super easy with just a little time and effort. We did deviate from the official recommendation of parts on this build. We ended up going with the FMS 1700 mm Corsair power system and prop to get a vary scale look and unlimited power. Also instead of using the expensive servos we used our trusty Freewing digital metal gear servos I fly 100mph jets on them with no problems I don’t see any reason why I shouldn’t save over half the cost by using them here. Guys the model is absolutely gorgeous and one of the easiest ARFs to assemble just take your time and she will fly fine 😉
                                  Very nice!
                                    Am looking forward to the ground handling characteristics report because of the pics on the main gear that shows no positive caster for the struts.
                                    • R Wenger
                                      • Jun 2020
                                      Is there a build thread or flight review for the nexa P-47
                                      • Merry Boozer RC
                                        Wesley
                                        • Jul 2019
                                        • 178
                                        • Webster FL
                                        Guys, I call this an assembly and not a built. Being an older fellow and started RC in the early 80's before ARFs, and building from a box of balsa. But first, I want to give Motion credit for providing a model that being of balsa, is almost as simple as a foamy. This model comes with almost everything that is needed for
