Nexa L-4 Grasshopper Assembly
  • laryboy
    • Mar 2018
    did you have any problem screwing the self threading 3mm screw into aluminum wing tube ?
    • timmybeetle
      Warbird addict
      • 133
      • Netherlands
      Some thoughts about manual
      Bought me this second hand, was not finished completely.
      It had some damage but I repaired it allready.
      It's an easy build, just put the parts together.
      But I noticed during installing wing struts in manual #26 they say 3*15mm screw, but this is wrong.
      In fuselage there is a blind M3 nut installed and looking at covering in bright light I found where to puncture covering.
      See pics below.
      I installed a AL5055-400Kv motor, YEP 100A esc and will use 6S5000 LIPO, prop at the moment is a master airscrew 15 x 10 but I don't know if it will be on there in the future after some test runs.
      Grts Hans
      • timmybeetle
        Warbird addict
        • 133
        • Netherlands
        In manual it's explained very well?
        Grts Hans
        • timmybeetle
          Warbird addict
          • 133
          • Netherlands
          About CG
          In manual they say CG is 65-70mm form LE.
          But I have some thoughts about this, I fly a lot of planes.
          But when I fly a plane for the first time, also I fly new planes for fellow club members.
          I always keep the 30% rule from LE in mind as a starting point.
          For this plane wing has a dept of 27cm, so 30% = 81mm.
          Well I will see in first flight with this plane how it will behave in the air.
          For me I test this flying straight in the wind high altitude, throttle to zero and see what the glide path is.
          I want to see a glide path around 30-45 degree.
          A plane with a slight nose heavy CG is good to fly.
          grts Hans Click image for larger version  Name:	CG in flight.jpg Views:	0 Size:	31.0 KB ID:	294325
          • timmybeetle
            Warbird addict
            • 133
            • Netherlands
            Flying
            Today I flew my VQ L4.
            Used an FMS 14X8 and with 6S my telemetry gave me a current max 47A, Voltage 23.6V=1109watt max power.
            Cruising current is between 10-15 amps and reading my watts in flight around 100-150watt.
            It was a bit windy and performed CG in flight test, CG was around 70mm.
            In flight my LIPO moved a bit backwards so I had a plane slightly tail heavy but I could handle it.
            At home I modified my lipo area with a wooden stop for my lipo so it can not move more back for the next flights.
            Hopefully tomorrow it will be less wind so I can trim and balance my plane better.
            • timmybeetle
              Warbird addict
              • 133
              • Netherlands
              Update CG
              Flew today, securing my LIPO better than yesterday, CG=75mm and it flew just great.
              Grts Hans
              • JONESY
                JONESY
                • Apr 2021
                • 3
                • Kinsale,Ireland
                Recently finished L4 build.All good except dowels missing from kit but had some spare.
                Flies really well,looks good in air.Used OS Surpass 52 four stroke for motor.
                • JONESY
                  JONESY
                  • Apr 2021
                  • 3
                  • Kinsale,Ireland
                  Hi Folks,
                  Here is link to a flight with our Grasshopper.
                  O.S 4 stroke.Looks and sounds great.
                  Regards
                  Jonesy
                  Kinsale
                  Ireland
                  • JONESY
                    JONESY
                    • Apr 2021
                    • 3
                    • Kinsale,Ireland
                    Hi Folks,
                    Anyone out there have a Bowers Flybaby?
                    Here is link to short video.
                    Have a look at approx 2mins in to see his scarf flapping in the slipstream.
                    My drone pilot is getting better all the time.
                    Enjoy.
                    Regards
                    Jonesy
