LP........you n I need to team up on the drum beating so that Alpha clearly hears the message we are sending. ;)
How about a OV-10 Bronco or a OV-1 Mohawk
Dan........IP's looks to be the BIG BOY BRONCO(1/6) of Uravitch's and mine is the (1/9).Originally posted by Grossman56 View PostIpcustom73, that looks pretty cool to me, is that the same planes that Charlie used??
Just remember Alpha.....a 1500mm is a perfect 1/8 scale ;)Warbird Charlie
The pictures are of my plane, built from Uravitch OV-10 plans, with an extra wing bay on each end. Increases the wing span 6". Great flying twin, but I would like to see Flight line scale one out. I think it could be a lot better. The changes to the Canopy area were to accommodate batteries, and other electric stuff.......
Grossman, It would appear Charlie's is a Scale Tech, which used Uravich's plans to create their ARF. They use the same plans with a few tweaks..... The only problem this plane had were the landings. You have to fly it to the ground. If you tried to float the plane in with the nose up, it would blank out the Horizontal stab, and drop like a rock...... but lots of fun.
That right guys.....we gotta keep this in front of Alpha.
Pat....... You must have some form of persuasion with Alpha up your sleeve !?!? ;)Warbird Charlie
I wish. But then again that's probably a good thing. Otherwise I'd be broke from buying all the models I want! :DOriginally posted by OV10 View PostThat right guys.....we gotta keep this in front of Alpha.
Pat....... You must have some form of persuasion with Alpha up your sleeve !?!? ;)Pat
I think we'll see one from FMS as a result of that poll over on the "other" forum. Jim has been pretty good about following through with his word on new releases, just not timetables. Either way, between FMS and Flightline, I'd hazard a guess that one will be realeased at some point in 2017.
I'd hazard it won't be FMS, read my post #16Originally posted by F106DeltaDart View PostI think we'll see one from FMS as a result of that poll over on the "other" forum. Jim has been pretty good about following through with his word on new releases, just not timetables. Either way, between FMS and Flightline, I'd hazard a guess that one will be realeased at some point in 2017.
https://www.hobbysquawk.com/forum/mo...3204#post53204
He slammed that thread down shortly after the announcement and that has been better than 10 weeks ago. I'm putting my faith in an organization that has NEVER blown smoke in my eyes and having FL/Motion is a much better path for this bird to become reality..............GO ALPHA.......GO ALPHA........GO ALPHA :DWarbird Charlie
He did more or less the same thing albeit to a lesser extent with the FMS Tigercat. He mentioned it once, and people moaned and complained that it wasn't what they wanted. Never mentioned (over a year later) it again until FMS posted the CAD on Facebook. Although it is all speculation from me. Like you said, only Alpha knows what the companies are actually planning..
HAAAAAAAAAAAAA! I'd gladly pose for that tattered but still gettin it veteran figurine............thanx for that suggestion Westy !!!Warbird Charlie
