Hello all,
New guy here with a problem concerning the Aero Scout.
The problem is the Scout will not come completely out of SAFE/AS3X, which ever the case. The plane has only been flown a few times because of this. The reason? It can be landed. It just wants to climb. The only way to get it back is to power it down. When I try turning off the SAFE mode, there's a slight improvement in the control surface movement, but for sure not enough for a roll a flip, or to bring it down.. Now I'm pretty sure that there's something not set correctly because there was one flight where everything was working properly. Since then the plane seems "stuck" in SAFE mode. I have tried re-binding...once removing the bind plug before binding the controller, and once with the bind plug installed. Nothing changed. I've checked the function of all switches. Here is what I feel is strange. When I use a servo tester to check the travel of the servos, the servos only travel half of the allowed travel. When the plane is powered up, and is self checking, the servos travel 100%.
I'm new to all of this, and to say that I'm really confused is an understatement. As I said, there's some change when SAFE/AS3X is turned off, but the system still remains in a guarded state.
Thanks in advance for any ideas, or information.
