Official RocHobby 1100mm NXT Nemesis High Speed Thread
    Hi JamesonC, welcome to Hobby Squawk! The Nemesis is a well balanced racing plane. It follows well in Strega's footsteps. Keep in mind though that the Nemesis' 2B stock prop is a 10x10, which is closer to the Strega's 4B stock prop in speed than a 10x12 would be. If you're after speed you want the second number (pitch factor) to increase, not necessarily the first number (diameter). I haven't tried a higher pitch factor prop on this Nemesis personally. If you don't already have one, I recommend using a wattmeter to monitor your experiments, as using anything but the stock prop is not covered by the manufacturer's warranty.
    • JamesonC
      MRC fanboy
      • 619
      • Laurens, SC
      I've got two 12x12 props ready for flying tomorrow. One cut to 10x12 and one 11x12. My strega flew 89mph all stock on the 4 blade that's why I was expecting a little more performance stock vs stock with a higher kv motor and 2 blade prop. I'll keep toying with it and see what I can get out of it. Really miss my strega and I got this one to fill the void. I will admit ground handling and landing is much better on the nemesis. Just gotta figure out how to get the 100mph+ out of the ol' girl!
      • JamesonC
        MRC fanboy
        • 619
        • Laurens, SC
        Hey guys, I'm stumped and need a little help. I had a small mishap with my Nemesis last time out and stalled it coming in to land. It nosed in from pretty low and wasn't a hard hit. Initial inspection looked like it was just gonna need a prop adapter and spinner (didn't even break the prop.) After installing the replacement parts from Motion, the gap behind the cowl is larger than what I remember and the down angle seems to be too large as well. I pulled everything apart again and double checked and nothing else seems to be bent or broken and everything is tight. Am I missing something here??
          Hi JamesonC, I'm sorry to hear about your stall. Have you compared the original shaft length to the replacement? Also, it's difficult to tell from your picture, but is the spinner backplate fully seated against the prop shaft? They are hexagonally keyed, and must be aligned so that the backplate slips over the shaft. In your picture, it looks like that isn't happening.
            JamesonC.........check your motor mount area.
            Base on the exterior foam wrinkling/fracturing in your pics I would wager that you have some pretty good foam compression internally around that bulkhead which is causing the down thrust to be apparently more than normal.
            Best regards,
            • JamesonC
              MRC fanboy
              • 619
              • Laurens, SC
              Yes it is. It is fully seated on the hex. It worried me that the replacement prop adapter is listed for the 980mm line and doesn't have the Nemesis listed but when compared to the old one, it did appear correct but I couldn't measure exact since the old one is a bit bent now!
              • JamesonC
                MRC fanboy
                • 619
                • Laurens, SC
                Best regards,
                I will look again, I saw nothing back there while I had it apart. It barely hit and barely wrinkled the foam. And, the battery hatch still fits right so I know it didn't compress the front really. My thing is IF it did push some foam in back there, why is my gap so much larger now?
                  I'd recommend calling into the Service Team at 224-633-9090, M-F 9am-6pm CST, or submit a service ticket at https://www.motionrc.com/pages/contact , asking them to measure the stock prop shaft on the PNP aircraft and ensure that length matches the prop shaft in the Spare Parts section. This information is provided from the manufacturer but sometimes they make a mistake and amid 20,000 part numbers we can't always catch the error before a customer sees it. In the case of the 980mm class, they did have a couple variations of prop shaft length, so hopefully it's as simple as sending you the longer one and adjusting the website to match.
                  • JamesonC
                    MRC fanboy
                    • 619
                    • Laurens, SC
                    Some more pictures of my spinner and all. I just can't find anything wrong no matter how hard I try! I'll contact motion tomorrow and see. The prop adapter would need to be smaller not, longer though!
                    • kenelder
                      Never enough planes!
                      • 28
                      • Largo, Fl
                      Originally posted by xviper2
                      Do you recall by how much more than 70A was the highest draw?
                      Sorry for the delay, I was out of town. 75 amps was the max the telemetry showed.
                      • kenelder
                        • 28
                        • Largo, Fl
                        JamesonC, did you ever resolve the motor angle issue? The pictures you sent look to me like the metal X motor mount is bent or else the plastic mount has been bent or moved. If it were mine, I'd pull out the motor and check for a bent mount.
                        I thought mine was pretty slow using the stock prop and my old batteries. But once on 6s, it screams!
                          • 7349
                          Sounds similar to what I ran across after a mishap with my FW P-51, I replaced the original motor with an FMS 650kv afterwards and it seemed to sit a bit funny, with hardly any foam compression. Ended up shimming it so it was more in keeping with my other FW P-51, flys fine. If everything checks out in regards to the motor mount and the shaft is spinning true, then it has to be the firewall mount that is out of place for some reason, is all I can think of.
                          • roys001
                            • Sep 2015
                            • 105
                            • Glendale CA
                            I've been doing some research and I think it's time for a color scheme change. I'm liking N777XT.
                            • JamesonC
                              MRC fanboy
                              • 619
                              • Laurens, SC
                              No. Flown it twice like that and it flies fine. I'm assuming it's the foam compressed making it look that way. I checked everything there was to check and couldn't find anything wrong.
                              As for the speed, yeah I'm still disappointed. After flying my strega on the stock setup with a 11x12 prop... this isn't close! But, it handles better on the ground and does fly pretty great!
                              • kenelder
                                • 28
                                • Largo, Fl
                                Plunk in a 90 amp esc, a 9x9 and 6 cells, it will blow Strega away! and still land just as nice as stock.....
                                • JamesonC
                                  MRC fanboy
                                  • 619
                                  • Laurens, SC
                                  I haven't gone to 6s yet. Trying to stay at 4s for as long as I can!
                                  • waytooslow
                                    Too many Hobbies -- not enough time!
                                    • Oct 2013
                                    • 17
                                    • DFW Texas
                                    Sadly, I killed my Strega number 2 in a high speed mid air, destroyed the HK Excaliber,
                                    I push the envelope pretty good, running a 6S and a 10x10 (yes the esc and motor handle fine). Question -- how much room is in the fuse of the nemesis? I can wedge in a 2700 mah 6S 45C in the Strega with minimal mods.
                                    • Westsider
                                      Fly more, work less.
                                      • Nov 2015
                                      • 333
                                      • NorCal
                                      Not sure of the dimensions on the battery you mentioned, but a 6s Turnigy Nano-Tech 2700mah, approx. 140mm l x 45 mm w x 37mm h, fits just fine. You may need to drop the rear of the battery tray a couple mm depending on the height of your battery, but plenty of room long and wide.
                                      • \o/woohoo
                                        • 54
                                        Grrrr motion is out of stock right when i was about to order one. Any idea when they will restock?
                                        • rogerb
                                          • Dec 2017
                                          • 5
                                          I have a new RocHobby Nemesis and I can't get the CG right. With a 4S 2700 all the way forward against the firewall, it is still at least 5mm tail heavy (50mm from the front of the wing). Even with a 4S 3300 all the way forward, it is almost the same. It requires some down trim to fly, but on take off, it noses over without the immediate application of some up elevator immediately. Any ideas?
