Tired-Iron's P-38 Build
I just got my 3300 mah, 60C, 4S Turnigy battery packs from HobbyKing and noticed that they have these weird plugs on them. They have a male on one side and a female on the other. What the heck is this? I want to put Deans on them but I'm told by my local hobby shop that the wires on these batteries are rated at 10AWG and the Deans could overheat. What about it guys, a little help here.Bob Duncan
The only real helicopter is the CH-47 Chinook. The rest are just sling loads!Comment
Bob, here's the main P-38 thread.I just got my 3300 mah, 60C, 4S Turnigy battery packs from HobbyKing and noticed that they have these weird plugs on them. They have a male on one side and a female on the other. What the heck is this? I want to put Deans on them but I'm told by my local hobby shop that the wires on these batteries are rated at 10AWG and the Deans could overheat. What about it guys, a little help here.
Thanks TI.Bob Duncan
Would appreciate comments from people currently flying the Flightline P-38 Lightning regarding CG location. I am not able to get the CG far enough forward to put it according to instructions even with two batteries. Has it been typical to add weight to the nose of the P-38?Comment
Aero dale if you will look back through earlier post of the p38 you will find numerous post on cg. BTW there's alot of reading but alot of good information that you might need. Somebody else may be able to chime in to help you Zero in on it. Also maybe PM Lon or Aros 2 very Knowledgeable men on the plane.Dewey lComment
These post will be on the announcement of the p38 and not just those two. There is a bunch of knowledgeable people that posted that information. I don't want to take away from anyone.Dewey lComment
What size washer did you use?I found a solution for getting the nose gear door to shut when adding washers under the rear mounting tabs to correct the rake, if you move the door pull rod to the other side of the mounting tab it will allow the door to shut.
[ATTACH=CONFIG]n35741[/ATTACH]
Stock position.
[ATTACH=CONFIG]n35743[/ATTACH]
New position.
[ATTACH=CONFIG]n35742[/ATTACH]Bob Duncan
TI, this is a really great build/mod blog. Thank you for doing it. I have to admit that after reading all 7 pages, I am still a tad unclear about what mods have to be made to stock and FMS P-51 struts. Are you somehow grafting (for lack of a better word) the lower shock-absorbing end of the P-51 strut onto the base of a stock strut? I apologize if I'm being overly dense.---
WarbirderComment
