Byron Originals, Ryan STA Build and conversion to electric
  • F22trainer
    Piper PhD
    • Mar 2018
    • 1484
    • Sun City, Az
    Picked this up a few weeks ago. After buying the F100, I resolved not to buy anymore airplanes. (I have sold or given away 6 flying models this year) I was looking forward to finishing a ‘give away’ plane so I would have the space to begin the F100. (You know the other thread I resurrected) when a close friend tagged me in a post on FB, local guy with the Ryan needed to sell it. Partially built by a known builder in our circle, all of the parts are there, it’s just not in the original box. I had just responded with a reluctant “nope” when the ‘Operations Director’ (aka, my better half) said “…is it one you really want?” I showed her some of the materials about the Byron Models from Iowa ( very close by my father’s parents in Storm Lake) and the one NIB listed for $1200.
    She says “you need to see it before deciding. Go look at it and buy if you think it’s what you want”
    I thought I would have puppies right on the spot…and I got it for less than half of the prime listing I would have been required to ship from Sausalito.
    Got a Lanzo Bomber (another give away / raffle) to finish as the F100 also is getting underway, and then the new Ryan will move to the build table.
    With a Balsa USA 1/4 Sopwith Pup to follow, I’m hoping to start my retirement next year in a proper fashion.
  • boomer108
    Chief Boom
    • Apr 2014
    • 868
    • Chicago IL.
    Very nice! Good luck on the build.
      • 4874
      .....She says “you need to see it before deciding. Go look at it and buy if you think it’s what you want”.....
      Well that pretty well covers it.
      Presume you've picked out B-day, Mother's Day, and next Christmas Day gifts, already.
      Looking forward to seeing further progress. Best, LB
      • F22trainer
        Piper PhD
        • Mar 2018
        • 1484
        • Sun City, Az
        LB…
        • F22trainer
          Piper PhD
          • Mar 2018
          • 1484
          • Sun City, Az
          It’s on the way:
            Good choice. I've found DualSky motors to be quite well made and efficient.
              Man we got to get the Byrons together!
              • F22trainer
                Piper PhD
                • Mar 2018
                • 1484
                • Sun City, Az
                And the F100’s!
                • F22trainer
                  Piper PhD
                  • Mar 2018
                  • 1484
                  • Sun City, Az
                  Wow, regular shipping and 7 days - no complaints there. Click image for larger version
                    And the F100’s!
                    Yes! Absolutely
                    • F22trainer
                      Piper PhD
                      • Mar 2018
                      • 1484
                      • Sun City, Az
                      Nearing the finish on building and approaching the wing covering. Tail surfaces were easy and learned some new characteristics of my chosen material. Had good results with SIG Koverall over balsa applied with Minwax Polycryllic, and styrofoam is even better. The Byron kit came with older foam, not the tough stuff we’ve gotten used to now. What I discovered is that edges are a cinch with a trim sealing iron to overlap and it does shrink with it. Heat gun stretches it taught and bubbles just disappear. The wings have been slow process as no CA get near this foam, epoxy is OK but Titebond and soft clamps are definitely easier but slow to dry. Since it all gets wrapped with Koverall it was an easy choice to stick with aliphatic glue on the balsa and foam, but fiberglass and shell got the 2 part epoxy. Quite a thrill assembling this ‘old school’ technology but taking some liberties with newer tech when able. The tail wheel came from Hangar 9 Oscar, as the Byron offset design was short on the axle portion.
                      • F22trainer
                        Piper PhD
                        • Mar 2018
                        • 1484
                        • Sun City, Az
                        Been awhile gang, but progress is being made. Very close to paint actually but this stuff gotta do from scratch as I am not using the old technology it was designed for, with servos the size of cigarette packs and some clunky linkages. Wing and flaps were easy.
                        • F22trainer
                          Piper PhD
                          • Mar 2018
                          • 1484
                          • Sun City, Az
                          And just for fun, a few shots from earlier progress.
                          • F22trainer
                            Piper PhD
                            • Mar 2018
                            • 1484
                            • Sun City, Az
                            And if you’re curious about the Ol Timer Lanzo Bomber - it lives too! Flies great but looks like an octopus falling out of a tree during turns. Fun as hell!
                            • F22trainer
                              Piper PhD
                              • Mar 2018
                              • 1484
                              • Sun City, Az
                              hijacked my own thread
                              • F22trainer
                                Piper PhD
                                • Mar 2018
                                • 1484
                                • Sun City, Az
ID:	404124 Click image for larger version
ID:	404135 Click image for larger version
ID:	404125 Click image for larger version
ID:	404126 Click image for larger version
ID:	404127 Click image for larger version
ID:	404129 Click image for larger version
ID:	404130 Click image for larger version
ID:	404132 Click image for larger version
ID:	404133 Click image for larger version
                                primer going down real nice, and flying wires will be taking paint also, so got a fair taper on the fitting transitions.
                                • F22trainer
                                  Piper PhD
                                  • Mar 2018
                                  • 1484
                                  • Sun City, Az
ID:	405870 Click image for larger version
ID:	405871 Click image for larger version
ID:	405872 Click image for larger version
ID:	405873 Click image for larger version
ID:	405874 Click image for larger version
ID:	405875 Click image for larger version
ID:	405883 Click image for larger version
ID:	405877 Click image for larger version
ID:	405878 Think yellow wheels and spinner.Click image for larger version
ID:	405879 Click image for larger version
ID:	405880 Click image for larger version
ID:	405881 Click image for larger version
ID:	405884 Click image for larger version
                                    • 4874
                                    F22trainer, Beautiful Work, Sir. Pretty rare bird, as they say. Great build. Best, LB
                                    • F22trainer
                                      Piper PhD
                                      • Mar 2018
                                      • 1484
                                      • Sun City, Az
                                      The masks are coming off and final assembly begins
                                        • 4874
                                        F22trainer,
                                        Looking forward to seeing this beautiful green livery completed on your STA.
                                        Very interesting, he said scratching his chin with wonder.
                                        Best, LB
