Official Nexa 1730mm Fokker D.VII ARF Thread
    • 8218
    Click image for larger version  Name:	master.jpg Views:	125 Size:	113.8 KB ID:	411307
    Click image for larger version  Name:	master.jpg Views:	110 Size:	114.1 KB ID:	411308
    Fokker DVII 1730mm (68.1") Wingspan - ARF from Nexa
    Step back into aviation history with the Fokker D.VII, one of the most formidable fighter planes of World War I. Designed by Reinhold Platz and introduced by the Fokker-Flugzeugwerke in 1918, the D.VII quickly earned a fearsome reputation for its superior handling and performance. Many regarded it as the best aircraft of the war, even prompting a special clause in the Treaty of Versailles that required all Fokker D.VIIs to be surrendered to the Allies after Germany’s defeat. Known for its stability, climb rate, and ability to maintain control at high altitudes, the Fokker D.VII was favored by many of the top aces, including the famous Red Baron’s flying unit.
    Now, you can experience a piece of this legendary aircraft with the scale Fokker D.VII from Nexa. Perfectly suited for pilots of intermediate to advanced skill levels, this model blends historical accuracy with modern RC performance. Take to the skies with this scale masterpiece and relive the glory of one of aviation’s most iconic fighters—the Fokker D.VII.
    Intricately Detailed Dummy Engine
    Stunningly crafted scale engine detail delivers unmatched realism, capturing the essence of the original Fokker D.VII.
    Factory Covered and Painted
    Flawless factory covering, and precision painting ensure a show-stopping finish, ready to impress right out of the box.
    Highly Authentic Cockpit with Scale Gun Details
    Immerse yourself in true-to-life detail with a meticulously designed cockpit and realistic gun replicas, taking scale realism to new heights.
    A Size That Just "Feels Right"
    Not too small and not too large, the Fokker DVII can fit in any reasonably-sized vehicle for transport.
    • Enhance your scale model with the included scale dummy engine for added realism
    • Includes an intricately designed cockpit with a scale pilot figure and instrument panel to capture the essence of the original fighter
    • Scale gun details add an authentic touch with included scale replicas of the D.VII’s twin machine guns
    • High-quality printed covering achieves a professionally detailed and authentic finish that replicates the original plane’s markings
    • Model supports electric, gas, or glow engines, giving you flexibility to power it the way you prefer
    • Precision laser-cut construction – Built from laser-cut balsa and light ply, this model combines strength with reduced weight for enhanced performance
    • Nexa Fokker D.VII Red-Blue 1730mm (68.1'') Wingspan - ARF
    • Instruction Manual
    • Complete hardware package including pushrods
    • Scale details including pilot, instrument panel, dummy engine and gun details
    • Main Wheels and Struts
    • Tail wheel assembly
    Requires (Electric):Requires (Glow or Gas):Customer Note
    Nexa ARF models are constructed out of balsa wood and plywood. These are not foam models. The assembly of balsa wood ARF aircraft requires basic model building skills including the installation of servos, ESC, and motor (or gas engine). Product Specifications:
    AGE LEVEL :14 and up
    SKILL LEVEL :intermediate
    BUILD TIME :6+ hours
    Model Scale 1/5
    Wingspan 1730mm / 68.1in
    Length 1350mm / 53.2in
    Weight 5.5-5.8kg / 12.1-12.8lbs
    CG (Center of Gravity) 85mm (3.3in) from the leading edge of the wing's root
    Power System (Electric) 6320-295Kv Brushless Outrunner Motor (required)
    Power System (Gas) 17 to 20cc (required)
    Power System (Glow) .90 cu in 2-stroke or 1.20 cu in. 4-stroke (required)
    Electronic Speed Control 65A Brushless with 8A SBEC (required)
    Required Propeller (Electric) 17x10 Electric Propeller (required)
    Required Propeller (Gas) 16x6 Gas Propeller (required)
    Required Propeller (Glow) See your engine manufacturer’s manual (required)
    Servos
    • 5x standard size servos for ailerons, elevator and rudder - HRC6005-010
    • 1x standard size servo for throttle (gas/glow only, required) - HRC35085S
    Landing Gear Scale, wire main landing gear with steel wire struts and tail wheel
    Required Battery (Electric) 2x 4S 22.2V 3500-5000mAh LiPo Battery (required)
    Required Battery (Gas) 2x 2S 2100mAh LiFE Battery (required)
    Required Battery (Glow) 1x 2S 2100mAh LiFE Battery (required)
    Required Radio 6+ Channel (required)
    Ailerons Yes
    Elevator Yes
    Rudder Yes
    Flaps No
    Lights No
    Hinge Type CA, fiber hinges
    Material Balsa and plywood construction
    Skill Level Intermediate
    Build Time 6+ Hours
    • 8218
    Red/Blue:
    Black/White:
    • firefly
      • Oct 2024
      Are batteries to be in parallel or series? Recommend ESC is only rated up to 6 cell and seems too weak. At 48 amps with 6 cell.
      • firefly
        • Oct 2024
        14 lb 6 oz (with 1 lb of lead in nose)
        18-10 wood propeller
        6 cell (2 x 6 cell 5900) mounted forward of CG as possible.
        it flew as scale power - 70 watts/lb
        I believe recommended ZTW Mantis G2 65A ESC with 8A SBEC is a mistake.
        • kelly2uk
          • Nov 2020
          Another model not in stock?????Grrr 😊
          Looks like the VQ model here in the UK, is Nexa and VQ the same company???
          The VQ D7 is also out of stock 😕
          • PilotTony
            • Jun 2016
            • 18
            Just picked up the "black and white" version. Anybody try any different power setup then what MRC states?
            • Jdcrow
              • Mar 2019
              • 193
              • Bentonville AR
              She’s a beauty
              • aferree61
                • Mar 2023
                • 5
                Alrighty then...THE TRUTH AND HARD FACTS OF THE INSTRUCTION MANUAL AND ASSEMBLY OF THIS PLANE.
                1)
                Main Landing Gear installation, it is damn near impossible to insert the wire struts into the cut outs unless you remove a small section of the plywood Land Wing on each side of the bottom openings.
                2) Electric Motor Installation, Unless you have a curved set of needle nose pliers or a Surgery Forcep, you will not be able to insert the 5X80mm bolts into the 2 bottom openings.
                3) Landing Gear Wire Strut Covers, nix the "CA" per manual and use epoxy!
                4) Pay Attention to Instruction # 25-Center Wing because later on in Section #31 you'll be cursing out Motion RC and the Asian Factory Workers who put this thing together :) :)
                5) Section #31...THERE IS NO WAY IN HADES TO INSTALL THE HEX BOLT AND TIGHTEN IT PER THE PICTURED INSET ON THE FORWARD SECTION OF THE CENTER WING!!!!!!!!!YOU'LL HAVE TO REMOVE 1R AND 1L TURN THE CENTER SECTION UPSIDE DOWN, REMOVE THE FORWARD SPECIAL STRUT CLAMPS AND INSTALL 1R/1L AND TIGHTEN HEX BOLT/NUT THEN REINSTALL CENTER WING.
                There seems to be a standing issue with who ever Motion RC is hiring to QA NEXA Products because the process is lacking and that person needs to be assembling these NEXA Products themselves to verify ir can be done! If you need a Master Builder to sample these then I'm Available, just send me the proct and I"ll do a thorough and truthful review!
                ( I say NEXA Products because I have bought a few, Banshee, Fokker DVII, Space Walker and there were instruction issues with each one).
                • aferree61
                  • Mar 2023
                  • 5
                  As far as Electric Motor Setup DO NOT USE THE RECOMMENDED ADMIRAL MOTOR, ETC. I use the BadAss 4530-440Kv Brushless Motor, Rebel V2 Series Brushless ESC, 100A and Wood Electric Propeller, 17x8​. This setup uses a single 6S Lipo Battery and has plenty of power!​​
                  • marty 72
                    • May 2021
                    • 36
                    Unfortunately, I have to agree with everything aferree61 has said, but I am surprised he stopped where he did. Several major issues with this "assembly". Over the last 4 years, I've put together 20 or so ARFs, Extreme Flight, Hangar 9, Seagull, Phoenix, Dancing Wings and Black Horse. This is my first and probably my last Nexa (VQ). Instead of ranting about all the terrible instructions and bad fits, I have a question before I go off in one of two directions to try and make this work.
                    Center wing fitment: I took great care to make the wing fitment templates. With the existing center wing attachment "bars", no way I can get these two to agree (even with all the screws loose}. To anyone who has completed this, is the wing fitment template correct? If so, the bars or holes through the fuse must be changed. Any guidance would be great, as to how you completed what seems to be an impossible task (without making serious modifications).
                    I am used to things needing some massaging to fit together, but this has been crazy. It's as if this was a prototype given to me, that no one had ever fit checked and asked me to assemble it. The piece parts are nicely done, covering is extremely well done, but things don't fit.
                    I really hoping someone can tell me whether I should trust the template or not.
                    Marty
                    So after playing with it more, I believe the wing fitment templates are correct. If I just install the two "#1" bars on each side, the center section lines up with the template without much fuss. However, if I attempt to install the #2 and/or #3 bars, they are both too long, even with all the adjustments available. I've tried multiple combinations, assuming the instructions are incorrect, but the problem still exists. You will have to look at the illustration in the manual for this to make any sense. I'll make a work around and go on, not sure what that is yet. My model is the red and blue one.
                    If you buy one, be prepared, it's going to be very challenging. If you go in knowing this, it will probably be less frustrating. It's not going to be as simple as a Hangar 9 assembly by any means.
                    Motion Rc is an excellent supplier, but this is a VQ model and it appears that Motion RC is just selling them as Nexa without any Motion Rc input or changes. The Black Horse and Flightline/Freewing stuff is top notch.
                    • Harvey Bledsoe
                      • Aug 2025
                      Marty
                      i hade to remove the locknuts to shorten the #2&3 struts so they would fit with a little bending on the wire end. i left the center wing screws lose until I had the "N" struts in place then tighten everything up.
                      have fun LOL
                      • marty 72
                        • May 2021
                        • 36
                        I did get the wings to assembly by doing the following: I used the template, I loosely attached the #1 struts, and I loosely attached the "N" struts on the outer side of the wings. I tightened all the #1 struts and then the "N" struts. I did not use the #2 and #3 struts as they were too long and messed everything up. This approach line up well, and the wings looked correct. I then only used the #2 strut on each side. Because it was too long, I slid it into the place the #3 strut was to attach and it worked. I found the center wing stable and stiff enough, so I left the #3 out (for now). Harvey had the same problem it seems and bent his to make it work.
                        Today, I had my second day of flight with the Fokker D7, overall, the plane flies very well for a WWI plane. The wing alignment is correct as I needed no aileron trim on my maiden flight. The visual mechanical trim was perfect. I have several large bi-planes and this one lands the easiest of all of them. It requires very little coordinated rudder to turn and flies slow without objecting. Note: I used 25% differential for the ailerons (100 % up, 75% down) and the plane will actually turn without rudder.
                        Here's a video of today's flight, it's not great video, bad sky, first timer using my phone to video but you can get an idea of what the plane can do besides simple flying (which it does extremely well).
                        I can't get the youtube video to upload, so if you're interested, go to youtube search for Nexa 68 in Fokker D7 Second Day Flight
                        Nexa Fokker D7 Second Day Flight
                        • marty 72
                          • May 2021
                          • 36
                          Much better video, fantastic flying WWI plane!
                          Nexa Fokker D7 Flight Mash Field
