Step back into aviation history with the Fokker D.VII, one of the most formidable fighter planes of World War I. Designed by Reinhold Platz and introduced by the Fokker-Flugzeugwerke in 1918, the D.VII quickly earned a fearsome reputation for its superior handling and performance. Many regarded it as the best aircraft of the war, even prompting a special clause in the Treaty of Versailles that required all Fokker D.VIIs to be surrendered to the Allies after Germany’s defeat. Known for its stability, climb rate, and ability to maintain control at high altitudes, the Fokker D.VII was favored by many of the top aces, including the famous Red Baron’s flying unit.
Now, you can experience a piece of this legendary aircraft with the scale Fokker D.VII from Nexa. Perfectly suited for pilots of intermediate to advanced skill levels, this model blends historical accuracy with modern RC performance. Take to the skies with this scale masterpiece and relive the glory of one of aviation’s most iconic fighters—the Fokker D.VII.
Intricately Detailed Dummy Engine Stunningly crafted scale engine detail delivers unmatched realism, capturing the essence of the original Fokker D.VII. |
Factory Covered and Painted Flawless factory covering, and precision painting ensure a show-stopping finish, ready to impress right out of the box. |
Highly Authentic Cockpit with Scale Gun Details Immerse yourself in true-to-life detail with a meticulously designed cockpit and realistic gun replicas, taking scale realism to new heights. |
A Size That Just "Feels Right" Not too small and not too large, the Fokker DVII can fit in any reasonably-sized vehicle for transport. |
- Enhance your scale model with the included scale dummy engine for added realism
- Includes an intricately designed cockpit with a scale pilot figure and instrument panel to capture the essence of the original fighter
- Scale gun details add an authentic touch with included scale replicas of the D.VII’s twin machine guns
- High-quality printed covering achieves a professionally detailed and authentic finish that replicates the original plane’s markings
- Model supports electric, gas, or glow engines, giving you flexibility to power it the way you prefer
- Precision laser-cut construction – Built from laser-cut balsa and light ply, this model combines strength with reduced weight for enhanced performance
- Nexa Fokker D.VII Red-Blue 1730mm (68.1'') Wingspan - ARF
- Instruction Manual
- Complete hardware package including pushrods
- Scale details including pilot, instrument panel, dummy engine and gun details
- Main Wheels and Struts
- Tail wheel assembly
- 6 Channel radio - select a minimum 6 channel radio from our Radio Collection
- 6 Channel receiver - select a minimum 6 channel receiver from our Receiver Collection
- Brushless outrunner motor - we recommend the Admiral GP20 6320-295Kv Brushless Motor
- 65 Amp brushless ESC - we recommend the ZTW Mantis G2 65A ESC with 8A SBEC
- 5x high torque standard servos - we recommend the Hitec HS-645MG Ultra Torque Ball Bearing Metal Gear Servo Airplane Multi-Pack (5 Servos)
- 2x 4 Cell 14.8V 3500-5000mAh LiPo battery - we recommend TWO of the Admiral 4000mAh 4S 14.8V 40C LiPo Battery with XT60 Connector
- 17x10 Electric propeller - we recommend the APC 17x10 Thin Electric Propeller
- 4 Cell compatible battery charger - select a minimum 4 cell (4S) charger from our Charger Collection
- 17-20cc Gas Engine (or .46 cu. In. 2-Stroke / .50 cu. In. 4-Stroke glow engines) – we recommend the NGH GT17 Pro 17cc Two Stroke Engine
- 4.8V to 6.6V 2000mAh receiver battery – we recommend the Admiral 2100mAh 2S LiFe
- 4.8V to 8.4V ignition battery (gas engine only) – we recommend the Admiral 2100mAh 2S LiFe
- 6x Standard servos – we recommend 5x Hitec HS-645MG servos for control surfaces and 1x Hitec HS5085MG for throttle
- Propeller – we recommend the APC 16x6 Gas Propeller for gas engines. Consult your manufacturer’s manual for glow propeller recommendations.
Nexa ARF models are constructed out of balsa wood and plywood. These are not foam models. The assembly of balsa wood ARF aircraft requires basic model building skills including the installation of servos, ESC, and motor (or gas engine). Product Specifications:
AGE LEVEL :14 and up
SKILL LEVEL :intermediate
BUILD TIME :6+ hours
| Model Scale | 1/5 |
| Wingspan | 1730mm / 68.1in |
| Length | 1350mm / 53.2in |
| Weight | 5.5-5.8kg / 12.1-12.8lbs |
| CG (Center of Gravity) | 85mm (3.3in) from the leading edge of the wing's root |
| Power System (Electric) | 6320-295Kv Brushless Outrunner Motor (required) |
| Power System (Gas) | 17 to 20cc (required) |
| Power System (Glow) | .90 cu in 2-stroke or 1.20 cu in. 4-stroke (required) |
| Electronic Speed Control | 65A Brushless with 8A SBEC (required) |
| Required Propeller (Electric) | 17x10 Electric Propeller (required) |
| Required Propeller (Gas) | 16x6 Gas Propeller (required) |
| Required Propeller (Glow) | See your engine manufacturer’s manual (required) |
| Servos |
| Landing Gear | Scale, wire main landing gear with steel wire struts and tail wheel |
| Required Battery (Electric) | 2x 4S 22.2V 3500-5000mAh LiPo Battery (required) |
| Required Battery (Gas) | 2x 2S 2100mAh LiFE Battery (required) |
| Required Battery (Glow) | 1x 2S 2100mAh LiFE Battery (required) |
| Required Radio | 6+ Channel (required) |
| Ailerons | Yes |
| Elevator | Yes |
| Rudder | Yes |
| Flaps | No |
| Lights | No |
| Hinge Type | CA, fiber hinges |
| Material | Balsa and plywood construction |
| Skill Level | Intermediate |
| Build Time | 6+ Hours |
