Boeing P-12
  • jetfool
    • Nov 2022
    • 1350
    • Crawfordsville, Indiana
    Met the guys for a late breakfast then to the field. Perfect blue skies and no wind. Warmed up flying my trusty Air Tractor then made ready for the P12 test flight. After everyone, five of us, checked over the plane I taxied out and on the take-off run the foam rudder hinge completely gave way. I was able to abort and no other damage. I have less than 1 hour of in the shop time on moving the controls and glad This happened during run up and not at take-off which I was almost at speed. So back to the hanger for real hinges and will try again. Wonder if real test pilots had abortive take-offs during testing. I expect they did. We did fly for 3hr after because it is a beautiful blue-sky day. Pic of it back in the hanger4.
      • Nov 2013
      • 2776
      • Cody, WY
      Hi Rex: glad you caught that while still on the ground. You can give it another go after you have done the repairs. I've handed off my P-12 to Dan to see what he can do with it. Last takeoff attempt it rolled onto its nose before taking off, broke the propeller, and skinned the corners slightly of both wings. I'm done with this POS. For me, lesson learned. Such a beautiful looking plane, though...
      Cheers
      Davegee
        • 7408
        I've been rattling this one around in my head for a few days now and I'm convinced it's tail heavy. The plane just doesn't want to drag it's fat derriere into the air, so to speak.
        Wes kind of hints around about that when he mentions that a bigger battery aka more weight would be a way to go.
        Years ago, I had a small Waco that I went through the same thing with, so I have an idea of what to expect, but I want to check that CG!
        She's still hanging in the basement, flew great, but the plastic supports dried up and broke, danged Wyoming dry climate!
        Click image for larger version  Name:	20261023_175707.jpg Views:	0 Size:	111.7 KB ID:	453586
        (Dangerous Dan)
        • jetfool
          • Nov 2022
          • 1350
          Grossman56,
          I have several ounces of weight in the cowl of mine and it's now a little nose heavy. Too much wind today to test fly, I may get a gyro rec so I have that control. Right now, I have a 6-ch Lemon rec in it. Really want to fly this but want an almost perfect day to do it
          Best Regards, Rex
            • 7408
            Dave was saying that his wouldn't even get it's tail up, so that to me says waaaay tail heavy. If she won't lift her skirts and fly, makes you wonder. I ordered a 2200 4s but am wishing I'd gone bigger. I have several 3600 4s's and may try them or, like JF did, add some weight to the cowl.
            I ordered the 7 ch Lemon rx with the gyro.
            If you go that route, you have to set the gyro up with just the ESC plugged into the rx, once it's set up, then you plug the rest of the channels in. Not stated in the manual and I spent several frustrating hours figuring it out. They may have upgraded it now, but every one that I've got was the same.
            Oh BTW, where are you measuring your CG from?
            I was taught that the thickest part of the wing is where your CG is, with a biplane, figure the thickest part of both wings and split the difference. Worked great for the Pitts.
            (Dangerous Dan)
              • 7408
              I added just over an oz. of weight (29 gm) so we'll see if I can at least get the tail up. Once I get it figured out I'll find out where the CG really is and post it. Too bad airplanes have to be put out like this. I'm betting there is an inconsistency in the weight of either the tail section or the horizontal stab.
              Watching Wes bounce it in on the 'fun flight', knowing that he's a very experienced pilot tells me that it's not a beginner airplane.
              It occurred to me that it could be something as simple as a type-oh in the instruction manual on where to place the cg?
              (Dangerous Dan)
              • jetfool
                • Nov 2022
                • 1350
                Grossman56,
                I made a new c/g balancer and set the c/g at the manual recommendations. I'll take a picture and post later.
                Going to fly tomorrow so hope to test fly mine. If it's squirrely I'll put a gyro rec in, just need to order one. Mine has several oz. in the nose before it had a slight down nose position.
                Best Regards, Rex
                  • 7408
                  I reached out to Steffen RC who is a great guy and a great pilot. This is what he replied:
                  Click image for larger version  Name:	Screenshot 2026-10-26 115322.png Views:	0 Size:	33.2 KB ID:	453708
                  Good info, seems like we're on the right track.
                  (Dangerous Dan)
                  • jetfool
                    • Nov 2022
                    • 1350
                    Success! Today a blue-sky perfect day. The test flight of my P-12 went very well. The takeoff run was short because our grass runway has some mole lines in it so after a 30' rollout I gave it full power, and she lifted off with some left torque roll that I was able to override with ailerons. The high ail settings per the manual are very touchy and a lite hand is required. After gaining altitude 3 mistakes high my caller had to add down elevator because it kept climbing with no input. While I kept the plane under control. We had all the down trim in the elevator, but I still had to hold down on the stick to fly level. Flew around high for 4 min then set up for the landing. No wind and the landing was about perfect, and I taxied back to the pits. I turned the clevis in on the elevator, 4 turns, and tried a second flight after I relaxed a little. Second flight was better, but we still had to add all the down trim. Flew another 4 min and during landing we had a wind gust crosswind, and the landing was slow and good except the crosswind turned the plane at touchdown and I bent the right axle, no biggie I just need to straighten.
                    My thoughts on these 2 flights
                    1) Ailerons are very touchy, great for aerobatics but not landing. I will set my low setting half of what the high rates state
                    2) Definitely still tail heavy so will add another ounce to the nose. I have almost 4 oz now in the front side of the cowl
                    3) has all kinds of power for aerobatics or speed but slows down and fly's well slow, I flew circles mostly at 1/3 throttle
                    4) turns do need rudder to make a nice turn, ail. only and it drops the wing more
                    More testing and tweaking will follow but it looks great in the air and think I will enjoy it once it's dialed in.
                    My .02 worth, Rex
                      • Nov 2013
                      • 2776
                      • Cody, WY
                      My .02 worth, Rex
                      Great report, Rex. I was talking to Dan yesterday about the P-12 and mentioned that the tail seemed "glued" to the runway. It was obvioulsy way out of wack CG wise. Very interesting that you put 4 oz in the nose. We'll remedy this one and hopefully can get the tail off the ground next time. It shouldn't have been that hard to fly, but maybe with some trimming and weight adjustments, it will be easier like what you reproted.
                      Cheers
                      Davegee
                        • 7408
                        Hmm, good to know, I may have to add even some more, the cowl ring is hollow and might be a good place to start.
                        Are you using a bigger battery than the recommended 2200??
                        (Dangerous Dan)
                          • 7408
                          I can pick up 2 oz. by using a 3000 4s but it right on the supposed CG so it's not going to help much.
                          I tried to find the lead weights on MRC, does anyone know where they are on the site?
                          I have a bullet that weigh in at 102gm that might do in a pinch, also, some leftover props from the Waco, same length and .5 difference in pitch. I'm thinking of sacrificing those on the alter of experimentation, no to fly but to see if I can get her butt off the ground.
                          Can you get a pic of the elevators when at radio neutral, I'd like to see how much down you had to add. Now that might be corrected with more weight in the nose, but it might also be that the angle of attack is off on the horizontal stab.
                          I'll have to go through the manual and see what the build looks like. Any extra material where the rear end attaches to the tail might throw it off.
                          (Dangerous Dan)
                          • jetfool
                            • Nov 2022
                            • 1350
                            Grossman56,
                            I'm using the Admiral 2200 45c recommended battery. I am back in the hanger re-balancing after the first 2 flights. I will remove the original weight and weigh it, so I know what I have so far but feel I need at least another 1 oz. Going to check at a friend's auto shop and see if he has any old wheel weights. I can melt the lead and form it to fit inside behind the cowl at the bottom. less noticeable if anyone looks. I may have miss read my existing weights as I look at them tonight, they may only be 1/2 oz. weights so not 4 oz. total. I will report what I find. I'm including some pics of my C/G balancer. Homebuilt and adjustable for bigger planes. Base would be better with a 1 x 12' board but I used what I had so I need weight when balancing the bi-plane.
                            We will tame this baby before we are done, Rex Click image for larger version  Name:	IMG_4429.jpg Views:	0 Size:	166.1 KB ID:	453746
                            Click image for larger version  Name:	IMG_4431.jpg Views:	0 Size:	153.2 KB ID:	453744 Click image for larger version  Name:	IMG_4430.jpg Views:	0 Size:	161.7 KB ID:	453745
                            Click image for larger version  Name:	IMG_4428.jpg Views:	0 Size:	163.6 KB ID:	453747
                            I put a 1/64' ply 1" square under the wing at the 75mm balance point so my point on the balancer won't dig into the foam.
                              • 7408
                              Okay, here's what I get from the build video. The two screws that hold the vertical and horizontal stab in place. Is it possible that having the front screw tighter than the rear screw would throw the angle of attack off slightly?? I'd be tempted to back off the front one half a turn and see if that helps. the front end being lower than the rear would tend to give the airplane a climb attitude. You could even put a strip of paper under the front end where it snugs onto the fuse and change the angle of attack ever so slightly.
                              It would be nice to be able to use a torque wrench here.
                              This was done with all the wires that the real ones had, twist and loosen to dial in the airplane, we don't have that luxury.
                              (Dangerous Dan)
                              • jetfool
                                • Nov 2022
                                • 1350
                                Grossman56,
                                I hadn't thought of that, you might be on to something. Might be why the added instructions to align the elevator were added. I'll try the re-balancing first and if I still need down elevator for level flight, I'll check that. I have an incidence meter (Robart) I can use. Hopefully we can get good flights without any major crashes.
                                Best Regards, Rex
                                • Randy H
                                  • 66
                                  • Surprise AZ
                                  First of all I appreciate all the comments on this model it was very helpful. I balanced the model on my great plains balancer to get the proper CG. Put about 3 ounces of lead in the nose ring and using a 4 cell 2500 battery. It seems to balance a tad nose heavy but not much. Added a bit of down elevator as per the plans. All throws as per the instructions with 20% expo on ailerons and elevator. I currently have three biplanes including and oldy but goody Sig Smith biplane. Maiden to be in a week or so. Click image for larger version
ID:	453756 Click image for larger version
                                  • jetfool
                                    • Nov 2022
                                    • 1350
                                    Randy, thanks for joining in. All of us working together will get this flying well. I feel it is a great little plane, and we just need to get the short, coupled plane ironed out. I flew the test flights on the high-rate setting per the manual. The ailerons are very sensitive, and I will set my lowest rate to half of what the high rates are for take off, my middle rates will be set at the manual low rate. I had to accelerate to full power to avoid some mole lines in our field and it torque rolled to the left. With gentile aileron movements I was able to level out and climb but the nose kept going up and all the down elevator trim was used. I was able to land well enough but turned the clevis in 4 turns on ele and flew again, better control but still had to hold down elevator. Hopefully all of us working together will find the correct solutions. Please post your findings to help us all. I will add another 1oz. weight to the nose cowl.
                                    Best Regards, Rex
                                      • 7408
                                      Hi guys:
                                      One other thing I want to check is the P factor, does she tend to pull to the left when taking off? Some pull is to be expected but if it's bad, you can shim the motor to angle slightly to the right, I did that with my Pitts and it really helped.
                                      I'm really thinking there may be an incidence problem, it sure would explain a lot. Once it balances up, that may be the one thing that needs adjustment. Speaking of CG, I gather you guys are still aiming for the 78mm CG?
                                      (Dangerous Dan)
                                      • Randy H
                                        • 66
                                        • Surprise AZ
                                        Hello Rex and Grossman yes I am trying to hit the CG recommended by the instructions. Jut trying to be a little nose heavy to be on the safe side. My Sig Smith miniplane is set up this way and fly's fine.
                                        • jetfool
                                          • Nov 2022
                                          • 1350
                                          Once I get the C/G correct and a little nose heavy I will fly it again. I know I can control with down stick on the elevator if needed. I will set my low rate at 9mm on the ailerons, didn't take much throw on ail stick to roll and I was very easy on movement. Up high it did row fast on high rate. The incidence on the elevator as Dan stated may be off some and I will look at that after next flight. Just seems like a tail-heavy problem that may have crept in the manufacturing process. It is a very sturdy airplane
                                          Best Regards, Rex
