2200mm C-119
    • 2818
    • Arlington, TX
    Originally posted by Beeg
    The B-58's gear would be difficult besides the small wheels and trucks on the mains. The nose gear main trunion moves aft on retraction which makes it look like the nose gear retracts forward.
    I would love a B-58 as well! The gear would be very difficult to say the least though, as you said:
      If it could be scaled up so it had at least 2 1/2" wheels, it could be flown at our field.
      Alot of cool "not done before" ideas here Freewing/FlightLineRC/MRC. Just sayin'.......
      I just did the number mining and a 1/10 scale gives you 3" dia wheels with a W/S of 68" and length of 115".
      Now I know you really want it now cause those numbers definitely put this jet into the Giant class. :Scared:;)
        Going to need a bigger vehicle :Confused:
          • 2818
          • Arlington, TX
          Naaah.. You just need a bigger B-36 to haul it to the field :);)
            Good point! You know, if MRC were to produce a big B-36, I'd pick that over the B-58. And those BIG wheels would make it a viable candidate for grass fields. Could you imaging the sound with 6 props and 4 EDFs!!!! You would need a truckload of batteries to fly it.
            Seriously, it could be done in a 2.2m format using smaller 4S based motors turning 10" 3-balde props. Have the motors run in pairs to each side using 3 ea. 4000mah 4S lipos. No EDFs, just dummy pods. Nobody's done that mass produced in foam before.
              • 2818
              • Arlington, TX
              I would definitely be interested in that as well. Actuated bomb bays would be sweet..
                I can hear the modding gears grinding on the both of you ! ! ! :Smug:
